| A100man |
 A100man World Chat Champion
 Posted: 21:34 - 01 Apr 2022 Post subject: Isolation service valve fail? |
working on a friends bathroom shower. suspect poor function is due to low pressure
on the cold feed (gravity system header tank). There are service valve that isolate the bathroom on both hot (gravity copper cylinder) and cold. Has anyone known a service valve to fail by significantly reduce flow?
It worked oK once apparently.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| A100man |
 Posted: 22:18 - 01 Apr 2022 Post subject: |
| ZebraDriver wrote: | Had a gate valve fail recently. Shut the water off and it wouldn't open fully afterwards - the spindle just kept spinning. Had to go out and find the street stopcock and change the valve. |
In this case it a simple screwdriver 1/4 turn ball type.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Islander |
 Islander World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| A100man |
 Posted: 07:49 - 02 Apr 2022 Post subject: |
| Islander wrote: |
Some of those have a significantly reduced bore. You can get full 15mm bore types that allow full flow. |
Thanks, noted - that fact it worked Ok once makes me think the bore size is not the (whole) problem. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 07:51 - 02 Apr 2022 Post subject: |
| Polarbear wrote: | I've only once in many years of using ball valves seen one fail like that. It was an old type with the ball in a plastic lining rather than seals and the lining turnrd partially in the valve, blocking off some flow.
So, yes, depending on the valve construction it is possible. |
I was thinking along those lines or perhaps some dislodged debris stuck in it..
Cheers ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| WD Forte |
 WD Forte World Chat Champion
| stinkwheel |
 Posted: 01:03 - 03 Apr 2022 Post subject: |
Electric shower?
They usually have a gauze sock filter on the cold water inlet that can get clogged and massively reduce flow. Had that happen a couple of times with them. Very easy to get at. Remember to isolate the electric before you open it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| grr666 |
 grr666 Super Spammer
 Posted: 05:45 - 03 Apr 2022 Post subject: |
Yes, ball valves can fail/leak. Normally pretty easy to replace, just use the nuts and olives from the old one and a good few
layers of ptfe tape and just replace the guts. In my experience the full bore valves have a lever rather than a slotted head
control and usually aren't chromed. Fine for use in a loft or something but not especially nice to look at if it's on view due
to it's bulky design. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| A100man |
 Posted: 09:51 - 03 Apr 2022 Post subject: |
Thanks all..
Eventually traced lack of flow to a gate valve further upstream near header tank that 'someone' had turned (almost - but not quite) off.. FFS.
All very ancient pipework with spurious poor quality work additions. Still can't figure out why hot flow was good and cold not..from the same tank. Not sure I can be bothered to investigate further  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 4 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
