 Posted: 13:18 - 12 Apr 2022 Post subject: Heated grips on small scooter (and oddball electrics!) |
Long and technical.
Just got a Honda Wave 110 for Mrs stinkwheel for a commuter and she would really like heated grips on it. This is a bit of an ask for the wee thing but I'm thinking through it and will need to do some more testing.
It's pretty much the same setup as a Honda Innova 125 (although not interchangeable). This took me some time to get my head around. It's a "modern" bike with electric start and fuel injection however it only has a single charging coil and has direct lighting just like the older hondas... Except it isn't like that.
The coil feeds into the reg/rec and there is one take-off for the 12v 4Ah battery charging and another for the lighting which is a separate circuit. The lighting only comes on when the engine is running. I had it on good authority that the lighting was actually DC rather than AC, albeit "dirty" DC. I put an LED taillight bulb in and the brake light worked but the tail didn't. I put an LED numberplate bulb in and that did work.
Long story short. It takes a single phase input, half rectifies and regulates it for the battery charging as you'd expect. The lighting (rather cleverly I thought) uses the OTHER HALF of the output. Rather than a split single coil system using half the coil for one and half of it for the other and dumping the bottom half of the waveform like the older ones did, it uses all of the output, the only wasteage is cropping of over-voltage. Put another way, the charging is negative earth and the lighting is positive earth on the same bike!
Not sure how this will play with the LED taillight bulb. A negative earth one definately won't work. A positive earth one shouldn't be polarity sensitive but I have no idea how it will play when asked to be both positive and negative earth (stop light is -ve earth, tail light is +ve earth).
Anyway, to the heated grips. By using LEDs throughout, I'll free up a good 2A of constant draw. Most grips are 4A on full power but I'll check how much they draw on lower settings. What we need to avoid is them drawing so much it stops the FI working. Although these bikes will apparently self-excite and start on a flat battery with the kick-start providing there is fuel in the injector line (again, a marvel of electronics!).
My thoughts are to use the lighting output to trigger a relay for the grips, hopefully halfwave DC will keep the coil energised. Then I can have the grips on a fused "clean" DC supply from the battery but they can only be turned on when the engine is running. My concern is I'm saving most of the power on the lighting side then drawing extra on the charging side.
Then there's the danger of flattening the battery. At a basic level, it'll be doing about 25-30 miles a day tops so simply plugging it into a trickle charger every night would most likely keep on top of it. Another option is a charging indicator lamp (the ones that show green for charged and red for low voltage) so the grips can be shut off if it goes red.
Another thought is one of those voltage sensitive relays like they use for charging leisure batteries on camper vans. Most trip in at 13.8V and cut off at 12.4V. If I fitted one of those it would only allow the grips to be on once the power hits 13.8 and they would turn off if it drops below 12.4. Could be a pest though because I suspect idle voltage will be pretty low and might make Mrs stinkwheel ride it about with the engine screaming to keep the grips on. I'm also not sure if they have any parasitic draw when off. Although combined with the switching relay, it wouldn't be able to draw anything with the engine off.
Or do I run grips on the lighting circuit? Heating elements won't worry about polarity or the cleanliness of the power supply BUT the electronics on the grip heater will probably have a tantrum. That leaves the low-tech sticky pad grip heaters but they are less flexible for low power settings.
Thoughts?
TL;DR
Will a +ve earth LED stop and tail bulb have a tantrum if asked to be positive and negative earth similtaneously?
Will a normal automotive relay trigger properly off "dirty" DC?
Is a voltage sensitive relay likely to be useful?
Should I run electronically controlled grips off the battery or basic grip heaters off the lighting circuit?
These questions may have to be answered by experimentation... ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Easy-X |
 Easy-X Super Spammer
 Posted: 14:21 - 12 Apr 2022 Post subject: |
Given the recent discussions on Lithium-Ion batteries how about an entirely independent system.
Grips > manual switch > li-ion battery
For example, run the grips cable to the underseat storage and use a cheap jump-start pack (which usually have a powerbank feature.) Unplug the pack, stash helmet, surreptitiously charge pack at the office and save £££
You could probably even dispense with rigging up a switch if you just get into the habit of disconnecting the power pack when not using the bike. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| A100man |
 A100man World Chat Champion
 Posted: 16:47 - 12 Apr 2022 Post subject: |
.. or go old school and fit one of these for the grips..
https://fawkes-cycles.co.uk/images/axa-trio-dynamo-steel-wheel-right-p11427-800_image.jpg ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| Nobby the Bastard |
| Nobby the Bastard |
 Posted: 17:45 - 12 Apr 2022 Post subject: |
In this case, this.
(Top picture)
This is true full wave rectification. You just need 4 diodes, but I believe a suitable capacitor to flatten the output from spikes to nearer a flat constant voltage is preferable. It's called Bridge rectification.
https://www.electronics-tutorials.ws/diode/diode_6.html
Further down is full rectification using a coil but that's harder to do by the hobbyist. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050
| Nobby the Bastard |
 Posted: 18:52 - 12 Apr 2022 Post subject: |
Good, lots to think about. Complicated by the fact that it's complicated. I'm ok with the electrics but not so hot on the electronics of these things
There aren't actually only two outputs from the reg/rec, others go to the main relay and directly to the ECU which I think may be to allow self-excitment on a flat battery. I'm not actually sure what these are outputting or their exact function.
I've attached a circuit diagram for an innova which is broadly similar. There is a distinct lack of any sort of manuals specifically for the FI Waves.
I'm actually moving towards the idea of a seperate removable battery for the grips with a charge relay to allow battery overspill to top it up, a bit like how they rig leisure batteries on camper vans.
I'm going to get more into it at the weekend and see how much it's actually drawing from the battery normally.
If this seems like a lot of faffing, it's because Mrs stinkwheel has pretty bad reynauds and needs heated grips AND bar muffs on her bikes. Especially if she's going to arrive at work in a fit state to do surgery. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nobby the Bastard |
| Nobby the Bastard |
| Islander |
 Islander World Chat Champion
| A100man |
 Posted: 11:47 - 13 Apr 2022 Post subject: |
| Islander wrote: |
A decoupling capacitor is fairly standard on a full wave bridge rectification circuit when a smoothed DC output is required. On a bike or car the decoupling function is normally provided by the battery.
In this case, just the bridge rectifier will suffice - the LEDs won't care that they're being fed what is effectively a pulsed feed and the frequency will be high enough that it shouldn't be detectable visually - if it is then a fairly high value electrolytic capacitor can be added - say, 4,700 uF rated at 25v or higher. |
Just for clarity I'm not sure 'Decoupling Capacitor' is the right terminology. These are generally on logic circuits to suppress noise on power rails. 'Smoothing capacitor' might be better.. no offence like. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| Islander |
| MarJay |
 MarJay But it's British!
| WD Forte |
 WD Forte World Chat Champion
| sickpup |
 sickpup Old Timer
| Nobby the Bastard |
 Posted: 18:25 - 13 Apr 2022 Post subject: |
Empirical experimentation now shows positive earth stop and tail lamps do not work in this application either, you get the tail light but not the brake light.
I might have a fiddle with a bulb some time, in theory just a case of desoldering the tail light inputs from inside a standard -ve earth LED bulb and flipping them round (assuming they don't just have a common earth on the PCB). It's getting the bulb apart without destroying it that'll be the tricky part.
I have a set of R&G grips on Mrs stinkwheels CBR6. Battery is flat just now but once I get it started, I'll measure the current draw at the different power levels and post it up here. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
| sickpup |
 sickpup Old Timer
| Nobby the Bastard |
The last post was made 3 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
