Which Threadlocker?
TravisBickle
PostPosted: 02:16 - 14 Apr 2022    Post subject: Which Threadlocker? Reply with quote
Need to order some as certain things are starting to rattle loose! Also threaded my master cylinder clamp by overtightening the mirror so had to order a new bracket end at the cost of £26! Not impressed. Thinking maybe be less heavy handed from now on but threadlock everything as standard practice?
What's best for general purposes on a motorcycle?
I'm thinking 243 as it's oil resistant (with the best will in the world I'm never gonna toothbrush every nut and bolt with IPA).
Any suggestions?
Also can anyone recommend a decent but inexpensive torque wrench? Had cheap ones in the past, load of crap.
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
Islander
PostPosted: 09:34 - 14 Apr 2022    Post subject: Reply with quote
I use Loctite 270. You don't need to toothbrush everything just use some brake cleaner on a rag and twist it into the thread for female threads or twist the thread into it for male threads.
If you don't remove oil and grease then don't expect the thread locker to be effective.
Cheapish torque wrenches? Draper or draper professional aren't too expensive and are reliable.
By the way, you didn't need to buy a new bracket. A helicoil would have sorted that and if you're that hamfisted then you should keep a few sets of the common sizes handy anyway. Laughing
Hong Kong Phooey
PostPosted: 16:03 - 14 Apr 2022    Post subject: Reply with quote
KTM specify 243, and that holds up well in a vibey v-twin no bother.
270 is stronger, something you'll remember well when you need to dismantle something in future.
Islander
PostPosted: 17:39 - 14 Apr 2022    Post subject: Reply with quote
A bit of heat sorts that - it's not always needed though Smile
struan80
PostPosted: 18:46 - 14 Apr 2022    Post subject: Reply with quote
Thread lock is only useful on tapered fittings like NPT, arguments welcome.
Edit Have googled it and it seems can do more, so I take my comment back. Wrong again.
PostPosted: 18:53 - 14 Apr 2022    Post subject: Reply with quote
243 and a torque wrench.
Threads want to either be greased or threadlocked. Thumbs Up
PostPosted: 19:35 - 14 Apr 2022    Post subject: Reply with quote
I use this, it's really good and lasts for AGES.
https://www.amazon.co.uk/Loctite-248-Medium-Strength-Stick/dp/B002T96AAY/ref=asc_df_B002T96AAY/?tag=googshopuk-21&linkCode=df0&hvadid=309859586326&hvpos=&hvnetw=g&hvrand=14967757156614473785&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006807&hvtargid=pla-697463419382&psc=1
Also as an ex-serial Buell owner I can vouch that it's all you'll ever need unless you're doing stuff inside an engine.
MCN
PostPosted: 19:37 - 14 Apr 2022    Post subject: Reply with quote
***Warning***
This is Not an Argument but FFS google B4U post next time. Wink
MCN
PostPosted: 19:40 - 14 Apr 2022    Post subject: Reply with quote
***Warning***
This Is an Argument.
Some 'fasteners' specifically require no lubricant (or locking compound.) Wink
(We already know that you refuse to use google. Rolling Eyes )
PostPosted: 22:36 - 14 Apr 2022    Post subject: Reply with quote
Yes and people could also find things where you're meant to use red lockthread on. Razz
No argument from you about the torque wrench though. Razz
PostPosted: 22:40 - 14 Apr 2022    Post subject: Reply with quote
A proper manufacturers workshop manual will tell you what, if anything should be on every fastener and how tight to do them up. If you follow these instructions, they shouldn't come undone.
PostPosted: 22:46 - 14 Apr 2022    Post subject: Reply with quote
The Buell one basically says "Threadlock anything that isn't safety critical".
PostPosted: 23:59 - 14 Apr 2022    Post subject: Reply with quote
I see no contradiction in these two statements.
I suppose it illustrates the difference between motorcycle and tractor engines.
MCN
PostPosted: 02:16 - 15 Apr 2022    Post subject: Reply with quote
I no longer debate torque.
Every cunt can do their own thing now.
What with The Rona, Anti-Vax and the War in Ukraine, theres much more important issues than how much torque to put into a bolt. Rolling Eyes
PostPosted: 08:33 - 15 Apr 2022    Post subject: Reply with quote
Depends if you're heading up a motorway slip towards a roundabout at 100mph and it's the bolt holding your front brake master cylinder to the handlebars. Then it's the single most important thing in the world at that moment... Ask me how I know some time.
F18
PostPosted: 18:11 - 16 Apr 2022    Post subject: Reply with quote
Late to parade (apologies).
A43 has done me proud of the years. Especially things I want to undo in the future (but go steady, not too much at a time).
Summer is just around the corner
xX-Alex-Xx
PostPosted: 19:15 - 16 Apr 2022    Post subject: Reply with quote
Last time I ordered threadlocker online (I was lazy and didn't need it immediately), I was sent a bottle of Korean super glue. eBay seller literally closed his account too so couldn't get money back (not a massive issue as it was only a few quid but still...).
DILLIGAF
PostPosted: 19:19 - 16 Apr 2022    Post subject: Reply with quote
Narp.
The seller closing their account and so not responding to the dispute makes it really straight forward to get your money back using the eBay guarantee as the item you received was not as described. Thumbs Up
xX-Alex-Xx
PostPosted: 20:02 - 16 Apr 2022    Post subject: Reply with quote
Yeah literally couldn't be arsed though. Ended up using it anyway, just not on the bike.
DILLIGAF
carbon90
PostPosted: 06:40 - 20 Apr 2022    Post subject: Reply with quote
Alright, I'll grab Loctite 270 when we start working on my uncle's new bike project. Hope the new tires from 4Wheelonline would arrive before the weekend so we'll do everything this weekend.
PostPosted: 07:56 - 20 Apr 2022    Post subject: Reply with quote
At sea we used to use nutlock, threadlock and studlock. I can't for the life of me remember the Loctite numbers but I'm pretty sure they were blue, green and red!!!!!
Nutlock if need to undo it later, threadlock if in was pretty rarely apart and needed to be secure. Studlock of it was never ever in the whole wide world meant to come apart again.
Of course studlock was the most popular with us primitives. Laughing
Triumph Trophy Launch Edition
PostPosted: 12:27 - 20 Apr 2022    Post subject: Reply with quote
Then there's bearing fit compound, which may as well be weld.
Islander
PostPosted: 13:46 - 20 Apr 2022    Post subject: Reply with quote
Loctite bearing retainer? Awesome stuff. Thumbs Up
I used it to sort out a rear wheel bearing that was no longer a proper interference fit and was rotating in the housing under load. Years later it's still holding as tight as ever - I'm dreading having to replace it although some judiciously applied heat should do the job.
TravisBickle
PostPosted: 03:02 - 21 Apr 2022    Post subject: Reply with quote
I got 243 in the end. I ordered mine from Ebay as it seems REALLY expensive, for what it is, from most mainstream sources like RS and high street retailers. The very cheapest ones on Ebay had Chinese writing on them in the photos, so at least it shows they're not trying to hide anything, probably is legitimately the real stuff and genuine, just intended for sale in the Asian market. Still I shelled out a few quid more for a bottle that was clearly from the UK market. Expiry December 2023. Had a bottle of green stuff in the shed that's been there for years, globbed a load on the mirror stud in the hope it'll hold while I wait for the new clamp to arrive then promptly launched it in the bin.
2024 BMW M1000XR
MCN
PostPosted: 10:59 - 21 Apr 2022    Post subject: Reply with quote
Loctite High Strength Retaining Compound. Does wot it sez on the bottle.
I was fitting new bearings in the lift arms of a Caterpillar wheel loader. The bearing bores of the frame (Bucket Control Arm) was wallied oot and the customer didn't have time to line bore the frame.
I suggested retaining compound as a get-around temporary fix as I had it in the van.
Lift cyl. Bearings slipped in perfectly.
I fecked up on the Tilt cyl. and had to remove the bearings after fitting.
Shocked I had to go back to the depot for hydraulic puller to pull the hoowuring bearing back out.
Customer was very impressed.
We got the job of line boring about two months later. Still had to remove all the bearings using hydraulic pullers.
Equipment was loading trucks and a conveyor belt hopper at a Sand Quarry.
I use loctite pipe sealant when I have it. If used, as directed, it seals better than thread tape.
There are similar products but having used many others and observed their limitations, I only use Loctite sealants.
And Loctite Threading compounds.
Study the tech info on the Loctite website for the best results too.
The last post was made 3 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 135.78 Kb
