Clutch Issues, Yamaha MT-125
jpno5
PostPosted: 22:40 - 23 Apr 2022    Post subject: Clutch Issues, Yamaha MT-125 Reply with quote
Hey guys, parked my bike up for 10mins, came back and went to start my bike and the clutch lever is pretty solid. I did manage to drive it home, literally only a couple of mm movement but enough to change gears.
Any ideas ?
Islander
PostPosted: 22:50 - 23 Apr 2022    Post subject: Reply with quote
Check the adjustment. It's possible someone fiddled with it while you were away from the bike.
jpno5
PostPosted: 23:04 - 23 Apr 2022    Post subject: Reply with quote
will check properly tomorrow, but had a look there and that doesn't seem to be the issue, i backed it off as much as i could, still clutch only goes in a little then its rock hard.
cheers
jaffa90
PostPosted: 23:43 - 23 Apr 2022    Post subject: Reply with quote
Sounds like a new clutch cable needed, also is the engine oil level ok?
jpno5
PostPosted: 01:09 - 24 Apr 2022    Post subject: Reply with quote
The cable is moving albeit not very much, had a quick look at the oil, it's not showing on the dip stick so definitely low, possible engine damage from low oil? Think my last oil change was about 5months ago.
I did drive it like almost 2 miles home, apart from not being able to pull the clutch in it did seem ok, engine sounded ok. And it was fine before I parked up.
WD Forte
PostPosted: 03:08 - 24 Apr 2022    Post subject: Reply with quote
Here's the Honda MT125 clutch parts diagram
you can probably guess the offending part
hth
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fimages.cmsnl.com%2Fimg%2Fpartslists%2Fhonda-mt125r-roadracer-1977-usa-clutch_bighu0103e5004_a80b.gif&f=1&nofb=1
bikers smell of wee
The last post was made 3 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 46.36 Kb
