Re-map recommendations?
BenR
PostPosted: 21:15 - 24 Apr 2022    Post subject: Re-map recommendations? Reply with quote
Hi all just wondering if any of you have had a remap done? Where did you go to get it done? Any recommendations? Costs involved etc? I've now fitted the DNA airfilter & airbox lid & akrapovic exhaust on the MT & obviously need to get the fuelling correct. I popped into A&M motorcycles in Letchworth who want £485 plus VAT which I thought sounded rather expensive plus they want the bike for two days which I can't really do. I don't want a power commander or any other "piggy back" tuning boxes as I wouldn't use the extra features. Any help much appreciated ta! Thumbs Up
Hong Kong Phooey
PostPosted: 10:11 - 25 Apr 2022    Post subject: Reply with quote
I used BSD in Peterborough, they were recommended as having good results on the RC8. It was tuned for ridability rather than power, smooth as silk now at lower RPMs and did gain a few HP throughout the range. This was all done on a rolling road over a few hours, I can't remember the cost, a few hundred is about the going rate. They flashed direct to the ECU. This capability depends on the bike, if the ECU hasn't been cracked then you'll be stuck with a piggyback like the Power Commander boxes.
They do other bikes too, I would check in bike specific forums as they'll normally have printouts of results, and know if the ECU can be flashed direct (best way).
Wherever you go, make sure it's done on a rolling road with exhaust gas analysis. A lot of places just flash a generic tune and don't further tweak it for the best results.
Oh and if you're doing further mods like breather/cat delete, do it all now, then get the tuning done at the end.
ThunderGuts
PostPosted: 11:51 - 25 Apr 2022    Post subject: Reply with quote
If it's a bespoke map I wouldn't be surprised if it's close to £500 to be honest. When I was into cars more, had quite a few remapped. Custom maps were usually in that ballpark as it involved lots of dyno runs, adjustments, more runs etc. to get it right. You've got a technician (who will be fairly skilled), the equipment cost etc.. so it does add up. Off the shelf maps (do these exist for bikes?!) are cheaper but only ever approximate and make assumptions. With bespoke combination of mods like you've got, custom is the way to go.
A few days though sounds like they can't schedule effectively; a custom mapping session is half a day usually (for cars, don't see why it'd be much different for bikes).
TG.
BenR
PostPosted: 14:22 - 25 Apr 2022    Post subject: Reply with quote
I thought it a bit unnecessary too & being the only mode of transport I have at the moment I can't do it. I'll have a look into the company mentioned above. Cheers guys. Thumbs Up
Easy-X
PostPosted: 19:27 - 25 Apr 2022    Post subject: Reply with quote
If you've fitted "known quantity" parts the cheapest would be posting off the ECU:
https://www.wizperformance.co.uk/product-page/2015-2017-yamaha-mt-07-ecu-flash
BenR
PostPosted: 20:32 - 25 Apr 2022    Post subject: Reply with quote
Hi thanks for the link but as stated above I can't do without the bike at the moment as currently it's my only means of transport I would also prefer to see what the bike's doing under various loads. That website is interesting though. Thumbs Up
struan80
PostPosted: 22:12 - 25 Apr 2022    Post subject: Reply with quote
I just don't get tuning a bike Rolling Eyes I would just have gotten one with more HP in the first place. I can understand it for fuelling I suppose and yes the exhausts may make it look nice I suppose. I always prefer stock exhaust on all of my bikes. I think I'm in the minority
yen_powell
PostPosted: 23:09 - 25 Apr 2022    Post subject: Reply with quote
Chris Steedman did my Super Tenere last summer, it cost £365 and took most of the day. He is based between Bristol and Bath. I wasn't after more power, just smooth glitch free riding and that was achieved perfectly. The ride home was a delight and I have not had the bike in touring mode since then as sport mode is now perfect at all speeds, even around town and threading through London traffic. I am one gear higher for most speeds now.
https://www.cjsracing.co.uk/index.html
XT1200Z and a DR350 in bits
ThunderGuts
PostPosted: 07:47 - 26 Apr 2022    Post subject: Reply with quote
I do get it to be honest; most bikes have room for improvement somewhere in their performance as bikes as mass produced and have to meet certain blanket criteria, emissions, commercial etc.. - a bike might be a 90% fit for performance, it's quite fun chasing the last 10%, even if it's something as basic as sorting out the fuelling (for example my VFR has an annoying bit of flatness in the midrange that's only present on partial throttle - I keep thinking about looking at ways to tune that out).
TG.
xX-Alex-Xx
PostPosted: 08:00 - 26 Apr 2022    Post subject: Reply with quote
Extra power is just a bonus of mapping for a lot (most?) people ... Even a stock map on a stock bike isn't exactly perfect, there's always room for improvement (emissions, power, smoothness etc). Stock maps typically have a flat spot or dip in the torque curve part way up (usually where emissions are measured) - getting the bike mapped will get rid of that flat spot and give you a better ride.
DILLIGAF
trevor saxe-coburg-gotha
PostPosted: 09:27 - 26 Apr 2022    Post subject: Reply with quote
most of that comes under the "fuelling" heading
however from what i can gather the fuelling on the 07 is right - unlike the 09 (which, at the very least, used to be not good, apparently). I think the first thing i'd do to an 07 is the front end - get some emulators or whatever to improve the damping rod oem set up, and leave everything else alone (that said, I do like the sound of the 07 so might - MIGHT - be tempted to put a can on it, but then that's your fuelling fucked, probably).
ThunderGuts
PostPosted: 10:06 - 26 Apr 2022    Post subject: Reply with quote
Except the OP has changed parts though, hence it's probably off now as the ECU can only adapt within certain parameters, e.g. it'll assume the components are stock and any variables are down to atmospheric or fuel conditions.
I know what you mean about the 09 though; a colleague had one (completely original parts) and it was burning that rich it smelt like it had carbs not fuel injection.
TG.
PostPosted: 10:14 - 26 Apr 2022    Post subject: Reply with quote
Except the OP has changed parts though,.
yeah but for performance not fuelling issues, i think?
ThunderGuts
PostPosted: 10:24 - 26 Apr 2022    Post subject: Reply with quote
TG.
PostPosted: 14:52 - 26 Apr 2022    Post subject: Reply with quote
But those were performance mods weren't they? They weren't fitted to correct poor OEM fuelling, were they?
BenR
PostPosted: 20:59 - 26 Apr 2022    Post subject: Reply with quote
Not really they still suffer from a snatchy throttle (if I'm being really picky). Don't really see the point in spending thousands on new suspension I'm quite happy with the stock stuff the bike handles beautifully although it could do with a steering damper as it can get "flighty" especially crossing Ware viaduct in windy conditions. Thanks for the input.
struan80
PostPosted: 00:49 - 27 Apr 2022    Post subject: Reply with quote
My VFR1200 is a pain in the arse at roundabouts and stuff. The throttle is like on/off switch. Would any tuning sort this out to make it more linear?
PostPosted: 04:47 - 27 Apr 2022    Post subject: Reply with quote
Okay - interesting. But just to be clear, why did you make the modifications originally? Was for performance purposes? You don't actually spell that out.
Interesting.
yen_powell
PostPosted: 09:59 - 27 Apr 2022    Post subject: Reply with quote
One of the things I asked for was a throttle movement that matched exactly what the engine did. Before this there seemed to be a drop off in revs just as I pulled away even though I was opening the throttle, a bit disconcerting. This only happened in tour mode. If I put sport mode on I revved the bollocks out of it instead as I pulled away. Now I leave it in sport mode all the time and pulling away is smooth as silk and small roundabouts are no longer the snatchy affair they could be before.
BenR
PostPosted: 11:10 - 27 Apr 2022    Post subject: Reply with quote
Obviously I wanted more sound & better running if I get a bit of extra shove that'd be great. I'm already considering swapping the akrapovic system for a termignoni one though. Personally I think the akra is shite, far too loud & not very well thought out plus even though I sealed all the joints I'm pretty sure it's sucking in air.
The last post was made 4 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 113.06 Kb
