2008 Honda s-wing fes125 head gasket problem
bazzaboy2010
PostPosted: 16:39 - 27 Apr 2022    Post subject: 2008 Honda s-wing fes125 head gasket problem Reply with quote
My honda fes125 2008 s wing scooter has already had 2 new metal head gasket and i am now putting on a 3rd. The head is straight and I really don't know why the head gasket are failing.
Any advice would be great
Cheers
jaffa90
PostPosted: 18:19 - 27 Apr 2022    Post subject: Reply with quote
Hi, how do you know that the head is straight? Also is the engine block surface straight? Are you tightening the head bolts as spec?
Q, which part of the gasket is failing and is it in the same place?
bazzaboy2010
PostPosted: 19:18 - 27 Apr 2022    Post subject: Reply with quote
We have put a ruler along it and it is perfect. When we remove the gasket it would seem that there is some black on the gasket that just looks like it's failed. But that maybe because it's been tighten down
jeffyjeff
PostPosted: 20:54 - 27 Apr 2022    Post subject: Reply with quote
Tightening your head bolts will not cause the gasket to blacken; the black is most likely from a combustion leak. Checking head deck warpage with a ruler won't cut it, you need a precision straight edge. Check the cylinder deck as well, as the leak could result from imperfections there. Make sure both sides are squeaky clean before you assemble the new head gasket, then install the head and tighten the head bolts to specification. Absent specific instructions, I would tighten in a star pattern, in stages to draw the head down evenly. First to 50%, then to 100% final torque.
History shows again and again how nature points out the folly of men - BOC
The last post was made 3 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 40.08 Kb
