Bandit turns over, will not start.
Crashhere
PostPosted: 19:07 - 02 May 2022    Post subject: Bandit turns over, will not start. Reply with quote
Hi guys.
I've had a bandit gsf600s in storage for around 8 years. I decided to try and get it back out on the road so I have giving it an overhaul. Initially it fired up but very rough as you can imagine. I replaced the battery and the plugs and the next day, I noticed that fuel had leaked into the oil, so I did an oil change and rebuilt the petcock and decided to clean the carbs out incase the float valves were stuck. I took the opportunity to do a full jet service and rebuild of the carbs. The bike continued to run to the point I did a full tune up on the carbs, making sure they were balanced. All good at that point (last weekend). I even rebuilt the forks and got my self a new helmet, lol!
This weekend she won't fire up........? The starter turns but will not fire. I've checked all of the novice stuff, kick stand, kill switch, fuel is on. Nothing. I tried bump starting her in 3rd gear and itsounds likeshe wanted to fire but it's very feint and as soon as I release the starter the engine immediately stops trying to fire.
I was worried that I had a load of fuel sat in the bottom of the cylinders so I decided to do another oil change? This time I replaced the filter to get all of the old oil out, I removed the plugs and checked them, it's sparking and are even wet from the fuel vapour. Whilst I had the oil and plugs out, I turned the crank over manually to push the rest of the oil out of the pistons.
Still nothing, exactly the same. Any ideas, could this be a compression problem?
Thanks in advance.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:25 - 02 May 2022    Post subject: Reply with quote
Spark?
Triumph Sprint ST 1050
Crashhere
PostPosted: 19:32 - 02 May 2022    Post subject: Reply with quote
Seems to be ok. New plugs sparks ok.
doggone
PostPosted: 20:57 - 02 May 2022    Post subject: Reply with quote
Your next job
https://www.youtube.com/watch?v=oLyqoMeFceg
A100man
PostPosted: 10:37 - 03 May 2022    Post subject: Reply with quote
Keep at it. You've got spark so there's only fuel left..
You could try and tempt it with some 'Start Ya Bastard' (or similar) - might as well check valve clearances too now you have some momentum going.
defblade
PostPosted: 08:43 - 04 May 2022    Post subject: Re: Bandit turns over, will not start. Reply with quote
Possibly flooded? Can take days and days to clear on its own.
Burn the plugs dry with a blowtorch (or fag lighter) and leave them out for a day or 2 to let the cylinders dry out a bit.
If it didn't do this previously, I'd be worried I'd messed something up cleaning the carbs, leading to overfueling...
Pete.
PostPosted: 13:30 - 04 May 2022    Post subject: Re: Bandit turns over, will not start. Reply with quote
Crashhere wrote:
Hi guys.
Thanks in advance.
Service the carbs. I gave up riding those damn things all year round because I got tired of doing the carbs every 6-12 months (that and the coils breaking down in heavy rain). It would become more and more reluctant to start from cold until eventually it would not start at all then I would strip and clean the carbs and all would be well for another while then the cycle would repeat.
https://www.banditforum.co.uk/forum/index.php?topic=69488.0
a.k.a 'Geri'
Robby
Dirty Old Man
PostPosted: 19:16 - 09 May 2022    Post subject: Reply with quote
8 years. Any fuel in the tank will have gone off, and there's probably a fair amount of water sitting at the bottom. If you put it on reserve at any point, you'll have carbs full of rusty water, which doesn't burn.
So my preference is to drain the tank, drain the carbs, fresh fuel, charge the battery and try again.
The last post was made 4 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 58.1 Kb
