Gear Oil - 2010 Honda CBF600
flyingcbf
PostPosted: 16:09 - 05 May 2022    Post subject: Gear Oil - 2010 Honda CBF600 Reply with quote
Hi Folks,
Does this bike come with gear oil?
Want to change it to make the shifting more smooth.
I'm constantly pulling in the clutch lever to smooth the ride.
Smile
2019 Suzuki V-Strom 250
2020 Cb125F @ 5k miles and going up!
Nobby the Bastard
Harley Gaydar
PostPosted: 16:15 - 05 May 2022    Post subject: Re: Gear Oil - 2010 Honda CBF600 Reply with quote
flyingcbf wrote:
Hi Folks,
Smile
Surely the clutch is to make shifting smoother....
Triumph Sprint ST 1050
jeffyjeff
PostPosted: 16:40 - 05 May 2022    Post subject: Reply with quote
Honda motorcycle transmissions, to my knowledge, share the engine oil. Use the recommended oil. Stay away from additives and energy-conserving oils to avoid clutch problems, which could arise from using oil that is too slippery.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:56 - 05 May 2022    Post subject: Reply with quote
Oil too slippery. Very Happy
PostPosted: 17:05 - 05 May 2022    Post subject: Reply with quote
The gearbox and engine use the same oil.
You're probably riding in too high a gear, try riding one gear lower. The redline is at 11,000rpm and unlike cars, it IS a target Very Happy. Anyting below 5,000 on a medium inline 4 and it will be snatchy.
Also worth reading up on rev matching if you want a smooth gear shift.
flyingcbf
PostPosted: 20:42 - 05 May 2022    Post subject: Reply with quote
All gears I use, the ride is not smooth. Lot of jerking about until I pull the clutch in.
Not sure what the previosue owner used, but I;m looking at changing the engine oil if they both (gear and engine) share the same oil
It's on 42,000 miles. Any recommendations on which oil? Sorry, don;t want to start a war again.
BUt looking at castrol power 4 stroke for this bike
PostPosted: 20:59 - 05 May 2022    Post subject: Reply with quote
Check the chain tension, and make sure it doesn't have any tight spots. This sounds like that might be the case.
PostPosted: 21:09 - 05 May 2022    Post subject: Reply with quote
In donkeys years of riding bikes I have never had a transmission issue that could be laid at the type of oil in the engine. There has always been some other reason be it clutch, cable, chain or whatever.
Sure, change the oil so you know the correct grade is in there but I absolutely guarantee it won't be the cause of your issues.
Triumph Trophy Launch Edition
PostPosted: 21:57 - 05 May 2022    Post subject: Reply with quote
As above. Whatever is causing your problem, it's not the oil.
Dodgy sidestand switch making the engine cut in and out?
MCN
PostPosted: 09:07 - 08 May 2022    Post subject: Re: Gear Oil - 2010 Honda CBF600 Reply with quote
flyingcbf wrote:
Hi Folks,
Smile
Most motorcycle gearboxes use the enging oil as the lube. Thats why it is considered problematic to use 'car' engine oil. Car engine oil is blended to work only in engines and can have friction modifiers incorporated.
The additives in car engine oil can interfere with motorbike clutch performance.
(Not all motorbike clutches are immersed in the engine-gearbox oil. Dry Clutch of Ducati as example.)
Snatchy clutch may be an indication of the clutch basket or other parts failing/failed.)
In a wet clutch the oil is part of the drive flow. The clutch plates shear the oil which creates friction.
Changing the oil replaces the worn oil where the shear forces deplete the lubrication qualities.
Changing the oil is simpler than changing the clutch plates.
Try changing the oil for the O.E.M. recommended oil. (Not some oil spouted from an internet forum. People on an internet forum do not run major manufacturing corporations. Wink
They may, of course, be very intelligent, well informed and post interesting shite based on personal experience though.)
Internet information can compliment O.E.M. Specifications and Recommendations.
PostPosted: 22:35 - 08 May 2022    Post subject: Re: Gear Oil - 2010 Honda CBF600 Reply with quote
Directly from the Hionda service manual:
Code:
API classification: SG or higher
(except oils labeled as energy con-
serving on the circular API service
label)
Viscosity: SAE 10W-30
JASO T 903 standard: MA
So a very low bar there...
The last post was made 3 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.94 - MySQL Queries: 13 - Page Size: 71.56 Kb
