| A100man |
 A100man World Chat Champion
 Posted: 19:18 - 09 May 2022 Post subject: GT250 Misfire |
Odd one..
Was running OK last summer, first ride this year - misfire onto one pot then none. short walk/push home...
Tried new plugs.. nope but noticed spark was weak.. so got some new coils. NIce fat spark, great but not the solution.. It starts and runs on two but after 20-30 second starts to misfire and then drops onto one and teh plug oils up. New condensors last year.. points cleaned to no avail..
Thoughts? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| bypass2 |
 bypass2 Spanner Monkey
| A100man |
 Posted: 20:07 - 09 May 2022 Post subject: |
| stinkwheel wrote: | Crank seal drawing gearbox oil? |
Ugh.. I hope not.. It is the right hand side but not smoking more than the right as far as I can tell. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 20:19 - 09 May 2022 Post subject: |
One other thing..about it the only part of the ignition that hasn't been replaced (yet) is the RHS points they were slightly pitted but better after a sanding clean and gap set.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| B1N |
 B1N Scooby Slapper
| A100man |
 Posted: 22:11 - 09 May 2022 Post subject: |
Battery at 12.7 so good I reckon, new last year also.
Running oil pump premix not advisable on these CCI motors
Also remember that i added some baffle wrap which wasn't there last year.. I wonder if it's strangling the motor.. easy enough to check, Then I'll try some new points .. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 23:15 - 09 May 2022 Post subject: |
| bypass2 wrote: | Old petrol. when you put the new coils on do you get new HT leads and plug caps. petrol tap working ok |
Thanks. Caps are relatively new but might swap over to see if the fault moves. Old fuel possible but not sure that explains why it's only missing on one side?
Thanks all a few more things to try.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
 Posted: 23:43 - 09 May 2022 Post subject: |
Maybe worth giving the points a blast of contact cleaner too in case they've got oil on? I once cleaned mine with brake cleaner and it turns out that their claim to leave no residue is a blatant lie, it apparently does leave a residue and furthermore, that residue is non-conductive. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| B1N |
 B1N Scooby Slapper
| blurredman |
 Posted: 14:51 - 10 May 2022 Post subject: |
New coils don't necessarily mean good coils.. I've had them bad out of the box...
Swap the coil and spark plug over? Clean those points! File them down a bit perhaps, then re-adjust gap width to compensate. Two condensers? Swap them over?
Sorry, just recently been messing with this sort of thing myself.  ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| jeffyjeff |
 jeffyjeff World Chat Champion
| B1N |
 B1N Scooby Slapper
 Posted: 11:21 - 11 May 2022 Post subject: |
Yeah you could be right, difficult to diagnose without being there but personally I'd change the plugs first thing of course and if I see a good spark I don't waste time looking for more spark, check other things first then come back to ignition later if needed.
Go for the low hanging fruit first, spray a bit of carb cleaner around the inlet rubbers while it's running, if the engine increases RPM then it is sucking in air.
We all have our own way of doing things.  |
| B1N |
 B1N Scooby Slapper
 Posted: 17:55 - 11 May 2022 Post subject: |
I gave up the fags 21 years ago.  |
| A100man |
 Posted: 12:36 - 12 May 2022 Post subject: |
small update..
Took out the baffle on the offending side (no difference) then changed the plug (again!) it ran ok for a minute or two but was too loud to continue (for the neighbours). I couldn't then get the unwrapped baffle back in cos the internals of teh exhaust had collapsed..
.. I have spare (pattern) exhaust for that side will now fit and then try a road run. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 4 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
