| Scotch10 |
 Scotch10 Borekit Bruiser
| bikenut |
 bikenut World Chat Champion
| Scotch10 |
| Islander |
 Islander World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 10:49 - 12 May 2022 Post subject: |
Only way for pistons to clatter the head is:
Worn big ends. (Piston connecting rod to crankshaft bearings)
Worn small ends. (Piston rod to piston bearings)
Massive layer of combustion deposits on crown/head.
I'd rule out the zost manifold leaks 1st.
We had a cnut put a main engine off-line for 10 weeks until a brand new cylinder head could be slow-boated into a rig in Iran.
Uncle MCS checked the Zost gaskets on that head. No gasket to be found.
New gasket fitted. Tappy noise now missing.
New head kept as spare.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| A100man |
 A100man World Chat Champion
 Posted: 12:29 - 12 May 2022 Post subject: Re: tapping |
| Scotch10 wrote: | The tapping was not there before. .. |
Can you put the old head back?
Did you check the clearances (plastiguage) of the old cam in new head?
Any chance you could have stripped a cam-cap thread? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| stinkwheel |
 Posted: 12:45 - 12 May 2022 Post subject: |
Are those heads not line-bored? So the camshaft caps go with the head? Many 70's and 80's jap bikes were.
Like A100man, my guess would be excessive play on the cam, only way to find out is to measure it with plastiguage.
Other classic small honda twin thing is loose camchain. The CCT spring isn't really strong enough to properly tension it in many cases. The done thing used to be to loosen the adjuster nut then nip it up again while pushing down on the tensioner slightly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jeffyjeff |
 jeffyjeff World Chat Champion
| Scotch10 |
 Posted: 14:58 - 12 May 2022 Post subject: |
| MCN wrote: | Only way for pistons to clatter the head is:
New head kept as spare.  |
I have put old exhaust gaskets back on due to exhaust having to come back off for the clutch. Thanks for tip will let you know when I put the new ones on. |
| Scotch10 |
| bikenut |
| stinkwheel |
| Scotch10 |
| jeffyjeff |
| Scotch10 |
The last post was made 4 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
