| Screw Loose |
 Screw Loose Scooby Slapper
| Pete. |
 Pete. Super Spammer
 Posted: 18:07 - 22 May 2022 Post subject: |
If the neutral light is on it's going to be the clutch switch, the run switch or the start button.
Or the alarm. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 18:21 - 22 May 2022 Post subject: |
Follow the green line in the image below it shows the electrical path from fuse 3 to the starter.
Given that the bike fires, it's not the stop switch (run switch) because that also feeds the coild and if they weren't getting power then the bike would not even attempt to fire. That leaves the start switch/button and the clutch swith. It's most likely the clutch switch. Most probably it's just stuck in. ____________________ a.k.a 'Geri'
| Screw Loose |
| Pete. |
 Pete. Super Spammer
| Screw Loose |
| Pete. |
 Pete. Super Spammer
 Posted: 22:33 - 22 May 2022 Post subject: |
You don't need to. The orange and white wire that comes out of the run switch (labelled stop switch on the diagram) feeds the coils. You say that it is popping and trying to start when you bumo it, so that switch must be working.
Do you have access to a basic test meter/multimeter? If you do it will help diagnosis. ____________________ a.k.a 'Geri'
| Screw Loose |
| Pete. |
 Pete. Super Spammer
 Posted: 13:53 - 23 May 2022 Post subject: |
If you put the negative on the battery -ve you can trace the electical path with the +ve. ____________________ a.k.a 'Geri'
| Robby |
 Robby Dirty Old Man
| stevo123 |
 stevo123 Nitrous Nuisance
| Pete. |
 Pete. Super Spammer
The last post was made 4 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
