benelli bn 125 starting problems
PostPosted: 10:34 - 23 May 2022    Post subject: benelli bn 125 starting problems Reply with quote
hi,
ive got a problem with my bike. it wont start unless i bump it down a really long hill. then it wont idle very well. i have checked both plugs and they have a spark. it this a common problem? i suspect a fuel blockage somewhere. also the plugs were quite carbonized when i took them off. any help would be appreciated. also the amber engine warning light is on most of the time but sometimes goes off. also it splutters when you open the throttle fully.
xX-Alex-Xx
PostPosted: 10:53 - 23 May 2022    Post subject: Reply with quote
Warning light seems like an obvious place to start? Have you been able to pull the code? The manual should show you how to do it...
DILLIGAF
777
PostPosted: 12:06 - 23 May 2022    Post subject: Reply with quote
i think i need a diag instrument for that
xX-Alex-Xx
PostPosted: 12:38 - 23 May 2022    Post subject: Reply with quote
Have you checked the manual? Often you can short out a couple of pins on a dedicated connector and it'll flash the code ... You count the flashes to get the code.
DILLIGAF
777
PostPosted: 13:12 - 23 May 2022    Post subject: Reply with quote
theres no service manual that i can find for it at least not online
WD Forte
PostPosted: 13:43 - 23 May 2022    Post subject: Reply with quote
Try turning the ignition on-off on in quick succession
and leave it on for bit too see if the eml flashes out codes
bikers smell of wee
777
PostPosted: 13:53 - 23 May 2022    Post subject: Reply with quote
i dont think it has that feature
WD Forte
PostPosted: 14:12 - 23 May 2022    Post subject: Reply with quote
/interest
ahm oot
bikers smell of wee
xX-Alex-Xx
PostPosted: 14:39 - 23 May 2022    Post subject: Reply with quote
WD Forte wrote:
/interest
ahm oot
Yup. Have fun with it OP.
DILLIGAF
Robby
Dirty Old Man
PostPosted: 15:24 - 23 May 2022    Post subject: Reply with quote
Is it still under warranty? If so, go to the dealer.
If not, you need to get a code scanner.
777
PostPosted: 15:39 - 23 May 2022    Post subject: Reply with quote
its not
Fat Angry Scotsman
PostPosted: 15:42 - 23 May 2022    Post subject: Reply with quote
its not
You've been told by a few people now that you need to get the fault codes to further diagnose the issue. As such your options are now:
1. Flounder around more on other forums and get told the same thing then proceed to do one of the rest of the options anyway, or,
2. Take it to a dealer to diagnose and fix the issue, or,
3. Buy a code scanner from eBay, Amazon, etc then report back here with the codes (or on another forum more specialised to your bike's manufacturer),
4. None of the above and mess about with it more yourself anyway.
slowasyoulike
PostPosted: 17:53 - 23 May 2022    Post subject: Reply with quote
You're not going to progress this unless you do as everyone has said and BUY A CODE READER. The socket on your Benelli should look like this:
https://www.lonelec.com/wp-content/uploads/2021/03/Benelli_Delphi_ECU_Diagnostic_Socket-510x394.jpg
If it does, buy one of these:
https://www.lonelec.com/product/benelli-obd2-plug-adaptor-delphi-ecu/
Now you can connect any OBD2 code reader to the bike.This £6 one will do:
https://www.ebay.co.uk/itm/125094678727?hash=item1d203950
Put the app on your phone, follow the instructions and post your findings Thumbs Up
A100man
PostPosted: 18:55 - 23 May 2022    Post subject: Re: benelli bn 125 starting problems Reply with quote
777 wrote:
hi,
Plugs - plural?
https://www.devittinsurance.com/bike-reviews/benelli/benelli-bn-125/
777
PostPosted: 01:33 - 24 May 2022    Post subject: Reply with quote
very useful thank you
777
PostPosted: 01:37 - 24 May 2022    Post subject: Re: benelli bn 125 starting problems Reply with quote
A100man wrote:
777 wrote:
hi,
Plugs - plural?
yeah it has twin spark plugs
777
PostPosted: 16:59 - 07 Jun 2022    Post subject: Reply with quote
ok, i got p2127 as an error code. i think that means its the throttle position sensor, which im gonna replace. i hope that is right
yen_powell
PostPosted: 17:28 - 07 Jun 2022    Post subject: Reply with quote
I'd unplug and check and clean all the terminals then plug it back in before replacing.
XT1200Z and a DR350 in bits
777
PostPosted: 17:52 - 07 Jun 2022    Post subject: Reply with quote
i did and its a 3 year old bike so they r all good. one weird thing i did notice though is the sensor has a white line drawn on it, so it may be second hand or was identified as faulty in the past
PostPosted: 18:39 - 07 Jun 2022    Post subject: Reply with quote
Judging on the fact its a 125, its not japanese and its clearly owned by someone who ignores code readers for many posts, 3 year old means absolutely nothing.
Don't buy stuff willy nilly. Take it off, clean everything with anything less than shiny metal and try again
777
PostPosted: 22:36 - 07 Jun 2022    Post subject: Reply with quote
it just took me ages to find the correct reader. i ended up getting 4 of them till i found the correct one. it had to be self powered
777
PostPosted: 12:56 - 12 Jun 2022    Post subject: Reply with quote
ok, so ive fitted the new throttle position sensor and it has cleared the error code. although the engine warning light comes on sometimes still and it has roughly the same problem when trying to start it from hot.
apparently this is a design problem from benelli :-
https://www.benelliforum.com/threads/y-wont-it-start.1446/
777
PostPosted: 17:36 - 30 Jun 2022    Post subject: Reply with quote
ok i got it fixed, it was the head temp sensor
Easy-X
PostPosted: 17:50 - 30 Jun 2022    Post subject: Reply with quote
Thanks for letting us know Thumbs Up
adywood45
PostPosted: 17:59 - 16 Nov 2022    Post subject: benelli cutting out Reply with quote
What code reader did you get as im having the same problem i think as my reader says theres no codes stored in the ecu yet if i hold the throttle at a steady 3000 rpm it will surge 3000 to 3500 then return to 3000 rpm if i go out on the bike the eml light will come on and the engine will cut out it will re start runs really rough couple of revs it clears it's self then of you go again until the eml light comes on again and the engine just cuts out again iv'e checked valve clearances and there 0.10 ex 0.8 inlet any one got any ideas what it could be.
The last post was made 3 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 126.54 Kb
