Chain Cleaner on Rear Tyre - please advise
KingKong
PostPosted: 19:43 - 24 May 2022    Post subject: Chain Cleaner on Rear Tyre - please advise Reply with quote
Lubed chain, got some on rear tyre, so I used chain cleaner (not lube) to clean tyre. Will this cause slippage on rear tyre?
Kwak 636 (2005)
Past - 2016 Ninja 300 (dark grey); K4 GSXR 600 (sexy yellow); 2002 CBR600FS; 2004 GSXR 1000; 2006 Kwak 636; 2005 Yamaha XVS 1100 Dragstar (facepalm); 2005 Kwak 636; 2011 Yamaha R125.
PostPosted: 19:56 - 24 May 2022    Post subject: Reply with quote
Depends what it is. As with almost everything, they way to clean it off is hot soapy water followed by clean water to rinse off the soap.
Kawasaki Jimbo
PostPosted: 20:10 - 24 May 2022    Post subject: Reply with quote
Clean tyres don’t slip so I guess you’re asking whether the cleaner itself will remain on the tyre. I was going to say no, it’s all highly volatile solvents, but looking at the safety data sheet for WD40 chain cleaners (for example), section 3 shows it is >80% non-hazardous ingredients (the rest is solvents, propellants and detergents). What the heck could that 80% consist of?
I just wipe the lubricant (gear oil) off the edge of the tyre with a dry rag, then go easy on the first few corners, just in case. What little remains soon scrubs off.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:17 - 24 May 2022    Post subject: Reply with quote
Unless I'd actually doused the tyre with chain lube I'd just ride it with no fucks given. Probably wouldn't even wipe the tyre.
It can't be any worse than riding home in the rain with a just fitted tyre.
Triumph Sprint ST 1050
Islander
PostPosted: 20:35 - 24 May 2022    Post subject: Reply with quote
If I'm concerned about some sort of contaminant on a tyre I just give it a wipe over with some solvent - usually isopropanol or brake cleaner. I usually have plenty of each laying around.
Stinkwheel's suggestion of hot soapy water and a rinse is, of course, the right way to proceed. Thumbs Up
KingKong
PostPosted: 21:02 - 24 May 2022    Post subject: Reply with quote
As stated, it is chain cleaner. I will go with yours and general consensus on here of soapy water.
Kwak 636 (2005)
PostPosted: 21:30 - 24 May 2022    Post subject: Reply with quote
Pics so we can see how much you've lubricated the tyre.
ThunderGuts
PostPosted: 21:56 - 24 May 2022    Post subject: Reply with quote
I use a stiff washing up brush with some car shampoo on it - if the cleaner is oil based then you’ll need a bit more oomph from the detergent. Then rinse off gently.
TG.
Bhud
PostPosted: 22:17 - 24 May 2022    Post subject: Reply with quote
Wire wool dabbed in petrol
c-m
PostPosted: 23:17 - 27 May 2022    Post subject: Reply with quote
Petrol is expensive, sounds like the OP was trying to improve his MPG.
The last post was made 4 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 63.12 Kb
