| CorriganJ |
 CorriganJ Scooby Slapper
| stinkwheel |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| CorriganJ |
| ThunderGuts |
 ThunderGuts World Chat Champion
 Posted: 09:08 - 25 May 2022 Post subject: |
Yes, wattage is power and calculated by multiplying the current in amps by the voltage. So you're right, a higher wattage unit will drain more power from the electric system/battery. Barring relatively small differences in motor efficiencies and fan blade design, wattage is however going to be directly proportional to cooling capability, so if you're wanting to increase cooling you're going to increase power drain. If the issue was on the move, you could theoretically improve things with a second radiator (which wouldn't affect your power drain) but if your issue is with very slow riding and therefore not much air movement, you'll probably need a fan on it to move the air, so you're back to square one.
I would look closely at the state of the radiator you've got. If there are a load of bent fins from stone impacts over the years, or it's full or crud, or both, then it won't be as efficient as it could be. If it is in a bad state, I'd start with getting a new radiator which will be a lot less faffy than trying to install secondary cooling fans (which again won't reach their potential if the radiator is in a bad way). ____________________ TG. |
| jaffa90 |
 jaffa90 World Chat Champion
| stinkwheel |
 Posted: 10:56 - 25 May 2022 Post subject: |
In fairness, people ride the length of Africa on them totally standard so you have to wonder if there's another factor at play. In addition to the above, worth checking the thermostatic valve is fully opening too.
What about fitting a higher spec oil cooler? No power draw there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Easy-X |
 Easy-X Super Spammer
| CorriganJ |
 Posted: 15:19 - 25 May 2022 Post subject: |
| ThunderGuts wrote: | Yes, wattage is power and calculated by multiplying the current in amps by the voltage. So you're right, a higher wattage unit will drain more power from the electric system/battery. Barring relatively small differences in motor efficiencies and fan blade design, wattage is however going to be directly proportional to cooling capability, so if you're wanting to increase cooling you're going to increase power drain. If the issue was on the move, you could theoretically improve things with a second radiator (which wouldn't affect your power drain) but if your issue is with very slow riding and therefore not much air movement, you'll probably need a fan on it to move the air, so you're back to square one. |
Thanks. The bike already has 2 radiators (and a third, smaller, for the oil cooler) but only has a fan on one. It's a common mod to add a second fan, the only difficulty is building a mounting bracket to join it to the second radiator.
| Easy-X wrote: | There anything on the clocks/dash that can tell you the current coolant temperature? How hot is it getting? |
There is a temp guage, and I don't like it when it strays into the red. Not sure how hot it is, but red.
| jaffa90 wrote: | A fast tick over / idle speed with a very weak mixture could cause more heat. |
Could also be that yes, I plan to clean and adjust the carbs, but removing them is a big-ish job and I don't have a garage. ____________________ 1991 RD04 |
| tatters |
 tatters Exxon Valdez
 Posted: 17:31 - 25 May 2022 Post subject: |
My 1992 BMW R100GSPD would chuck along fine moving in Morocco/Sahara in heat in the mid 40,s but sitting in traffic in London the bike would start to overheat (oil temperature to the point the oil would start breaking down). Air movement makes a big difference on both air cooled and water cooled engines.
I have never had to fit a second fan before but have found that a manual override switch wired in parallel works very well to put the fan on long before the bike thermostat does. Both my ZZR600s had this for riding in heavy traffic.
I have also changed out the thermostat switch on a KLR650 to a lower range so the fan would kick on sooner at a lower temperature this worked quite well as a automatic solution without the need for a manual switch.
One interesting caveat with a manual fan switch is to make sure it is off when taking a dual-sport/dirt bike though deep water as the cooling fan will break if it water hits the blades while running. Not that many riders will face this but l have seen it happen on one bike. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 22:43 - 25 May 2022 Post subject: |
This guys done it,( link below) looks easy enough.
Going by his negligible voltage drop and the physical size of the fans
they don't draw much power.
It looks like he knocked up some brackets and fitted a
stock (SH?) one on the left rad.
Personally I'd go new as many bike fans don't lend themselves to
easy fitment of new brushes and you don't know what sort of life will be left in a SH one.
This 7" push/pull type on Ebay is just £17.50
https://www.ebay.co.uk/itm/284657635386?
It says it's 80W but I suspect that's Chinese watts, the
10" one on my old CX was more like 50W and didn't half shift some air
https://www.youtube.com/watch?v=7-w0xe2gYFs ____________________ bikers smell of wee |
| CorriganJ |
 Posted: 20:07 - 26 May 2022 Post subject: |
| WD Forte wrote: | This guys done it,( link below) looks easy enough.
https://www.youtube.com/watch?v=7-w0xe2gYFs |
Perfect, great to know the voltage drop isn't significant. And yes, that's how I was planning to mount it. Seen it done before and it makes sense. Also makes sense to get a new fan, sad in a way not to run stock but it seems silly to pay £40 for second hand, 30+ year old parts when it's such an unsubstantial/inconsequential part. ____________________ 1991 RD04 |
The last post was made 4 years, 147 days ago. Instead of replying here, would creating a new thread be more useful? |
