1987 KMX125 - Will not cold start
jamesymurray
PostPosted: 11:13 - 26 May 2022    Post subject: 1987 KMX125 - Will not cold start Reply with quote
Hello all,
I am currently trying to revive my old KMX125 which hadn't run for a few years.
The problem I currently have is that it will not start when cold. With a squirt of Easystart, it will kick over pretty easily, and will then run happily on petrol. If i cut the engine and restart it it kicks over no problem. Only seems to be when trying to start from cold.
Carb was removed and cleaned up (was full of varnish). Float bowl is getting fuel into it.
Old plug was changed for new, the only difference being that the new one is iridium.
I have noticed on taking the plug out that it is wet.
Any guidance would be welcome.
Thanks
Easy-X
PostPosted: 13:29 - 26 May 2022    Post subject: Reply with quote
What sort of choke does it have, manual or automatic? If the plug's wet after (failing) to start it maybe the mixture's too rich.
Also, is this fresh fuel? Old fuel loses the volatile components, Easy-Start is basically manually introduced volatiles.
redeem ouzzer
PostPosted: 14:16 - 26 May 2022    Post subject: Reply with quote
Choke circuit blocked?
Be a REAL MAN!
jamesymurray
PostPosted: 18:32 - 28 May 2022    Post subject: Reply with quote
Gah! Turns out it was old fuel. Drain tank and carb again completely, fresh load of unleaded and it cranked right over.
Thanks all!
bikenut
PostPosted: 09:40 - 29 May 2022    Post subject: T Reply with quote
Lesson learnt...
When cleaning carbs etc., Start at the fuel filler cap !
nuts about bikes
The last post was made 4 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 42.27 Kb
