| claynz |
 claynz Derestricted Danger
| stinkwheel |
 Posted: 02:12 - 26 May 2022 Post subject: |
It's probably not the switch, that can't be supplying more power than the charging system can provide and the bulb wouldn't blow even if you connected it directly to the battery if it's all working normally.
Couple of possabilities that spring to mind.
1) Charging system fault leading to excessive voltage supply, usually a regulator rectifier failure. So one of the first things I'd do is check the voltage across the battery as the engine revs up. If it's going over 15V, this is the problem.
2) Intertmittant contact making the bulb flicker on and off, potentially in the switch or more likely the bulb holder.
3) Vibration from a loose bulb fitting, headlamp or just bad luck breaking the filament.
4) Wrong bulb. Like if you had a 6v bulb instead of a 12v.
I'd go with a charging system fault as the number 1 suspect. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| claynz |
| Nobby the Bastard |
| stinkwheel |
 Posted: 12:11 - 26 May 2022 Post subject: |
| claynz wrote: | Thanks so much for the advice, I will report back soon.
Apparently the regulator rectifier was replaced a few months ago due to battery charging problems.
He had to cut the old plug off and join up the wires, maybe wrong rectifier or cable termination?
Correct Part number for rectifier Suzuki is 32800-29B00-000, not sure what was installed!! |
Within a fairly broad definition, one 3-phase 12V reg/rec is much the same as another, they all do the same thing, some are more prone to failure than others but the only really model specific features are the position of the mounting holes and the connectors on the end. Some have 5 wires, some have 6 and you can fit either to most bikes if you know what you're doing. For example, I have a ZX6R rec/rec on my enfield bullet.
If it popped a reg/rec, you have to wonder if there is another fault in the charging system too, either one that cause the reg/rec to fail or that was caused by the failure. There are some fairly simple testing procedures to check this if you have access to a multimeter. As Nobby correctly says, poor earth connections can be a factor in this. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
| Polarbear |
 Polarbear Super Spammer
| claynz |
| stinkwheel |
 Posted: 23:45 - 26 May 2022 Post subject: |
| claynz wrote: | This is what was replaced 6 months ago (attached)
Could this be faulty or incorrect part supplied?
No, that'll work on pretty much any Japanese bike (with a few exceptions). The alternator or the wiring could be faulty. A charging fault could even have killed that new one (or the old one failing could have caused a charging fault).
Worth noting it's actually quite old-tech now, the SH prefix on the part number denotes it's based on something called a zennor diode. More modern ones are prefixed FH and use something called a MOSFET to regulate the voltage. Either should work perfectly well on most bikes though. If it was me I'd be fitting a MOSFET unit off a more modern bike rather than using the one it was designed for. However, even if it has gone, don't go replacing it unltil you've found what the issue is and ifg it hasn't failed, just keep using it, could well last another 20 years.
Looking at a wiring diagram (not sure if it's the exact right one), it's got that odd thing suzuki used to do of charging on two phases and adding in the third when the headlamp is on. It's possible if someone didn't know what they were doing, they might have wired up your switch incorrectly.
What colour wires attach to the reg/rec wires? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
| stinkwheel |
 Posted: 19:23 - 27 May 2022 Post subject: |
| stinkwheel wrote: |
What colour wires attach to the reg/rec wires? |
To elaborate further, some older Suzukis (and from googling wiring diagrams, certainly some of the GN models) have one of the charging phases wired through the headlamp switch. So when it's turned on, as well as feeding power to the lights, it also connects the third phase from the alternator to the reg/rec (the other two phases being hard-wired).
If the headlamp switch was mis-wired, it would be possible to be feeding unrectified, unregulated AC to the headlamp and 12V DC to one of the phases of the reg/rec when in the on position. This would stand a good chance of popping the bulb as revs increase.
If this had been done, it would not be possible to turn the headlamp on with the engine off. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| claynz |
| bikenut |
 bikenut World Chat Champion
| claynz |
The last post was made 4 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
