What Grinds my gears archive B
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> Dear Auntie BCF... Goto page Previous  1, 2, 3 ... 85, 86, 87 ... 179, 180, 181  Next
PostPosted: 22:20 - 31 May 2022    Post subject: Reply with quote
Went to service and reassemble my clutch master cylinder today. I bought a master cylinder service kit and a new lever and set about assembling it.
Failed.
https://www.bikechatforums.com/files/honda-vfr750f-1997-v-england-clutch-master-cylinder_bigect4l41f__0500_d7df.gif
The service kit contains all the parts labelled 4.
The lever kit contains all the parts labelled 22
Neither contains parts 2 and 3. they have no direct mechanical connection to the assembly when the lever is removed, they are free to fall on the floor (and presumable have done at some point in the last 10 years).
They cost more than a good pattern service kit and lever combined off honda. Only one seller of pattern ones on ebay and even that was £15.
If you crashed the bike and broke the lever, these bits would be very likely to disappear and your replacement lever would be totally useless.
Diggs
PostPosted: 12:16 - 01 Jun 2022    Post subject: Reply with quote
Just got a NIP for doing 38 in a 30, in a Skoda. I'd have thought congratulations should be in order instead....
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
pepperami
PostPosted: 12:27 - 01 Jun 2022    Post subject: Reply with quote
Had plans to go out on a bike this morning.
Well that went pear-shaped Sad .
God must have unblocked his drains, cause it poured down here like the apocalypse Shocked .
Fug that sh*t! I’m not going out in that!
A100man
PostPosted: 12:31 - 01 Jun 2022    Post subject: Reply with quote
Was it an Estelle?
Diggs
PostPosted: 13:56 - 01 Jun 2022    Post subject: Reply with quote
A100man wrote:
Was it an Estelle?
A Scala. Its not the model so much as the pipe and slippers mentality Laughing
PostPosted: 14:12 - 01 Jun 2022    Post subject: Reply with quote
Is that still 'naughty boy, have a lovely lecture' territory or straight to 3 ponts and £100?
Triumph Trophy Launch Edition
Diggs
PostPosted: 14:17 - 01 Jun 2022    Post subject: Reply with quote
Apparently a course is offered for up to 38 in a 30, so I may just sneak in. I hope so, as having to remember points, date of offence etc when sorting insurance is a pain...
Diggs
PostPosted: 14:18 - 01 Jun 2022    Post subject: Reply with quote
Years ago I got a tug for doing 80-something on the A1 on my old Guzzi. I got congratulated by the Durham Constabulary for that one Thumbs Up
Fat Angry Scotsman
PostPosted: 14:41 - 01 Jun 2022    Post subject: Reply with quote
Unlucky mate, I was hooning it on the Edinburgh bypass and went through a fixed location speed camera, was doing over a ton when I seen it and was too late to significantly reduce my speed for it, was probably doing around 85 - 90 when it flashed.
Then again that was more than two weeks ago and nothing ever came through the post so I've got away with that one.
recman
PostPosted: 10:32 - 02 Jun 2022    Post subject: Reply with quote
The subscription on my Ring doorbell camera going up by 40%.
Unsubscribe.
Ribenapigeon
PostPosted: 11:29 - 02 Jun 2022    Post subject: Reply with quote
Unsubscribe.
https://www.google.com/amp/s/www.instructables.com/Low-Cost-Arduino-Smart-Doorbell/%3famp_page=true
Build your own. There's loads of wireless and internet connected doorbell plans out there.
grr666
PostPosted: 11:42 - 02 Jun 2022    Post subject: Reply with quote
Unsubscribe.
EUFY dual camera doorbell.
That is all.
PostPosted: 15:08 - 02 Jun 2022    Post subject: Reply with quote
Bastarding fucking computers. They get worse the longer time goes on.
This particular issue is not helped by the fact all our consultation PCs have been set to go onto a lock screen after 3 minutes so I have to log back into them every bastarding fucking time I want to do something.
Anyway. I'd forgotten to click a button that releases the record on our database to so the receptionist can charge it out.
As usual, fucking lockscreen. So I click it. Only I accidentally clicked one of the uneecessary bits of random shite microsoft insist on putting on their lockscreens so instead of going back into my terminal session, it opens the Edge browser to show me pictures of whateverthefuckitwas. Only nobody uses this as a PC, it's a terminal access point so edge has never been opened. Can you close it? No you fucking can't, so I had to go through all the fecking popover setup on edge, then close it, then log back into the terminal session, then log back into the database, THEN click the button.
Wait 3 minutes and I might have to do the same again. I have raised an IT ticket about the imminent danger of a thin client PC with monitor attached getting ripped off the wall and landing on top of someones car via an open window if someone doesn't at least triple the lockscreen timeouts.
PostPosted: 15:22 - 02 Jun 2022    Post subject: Reply with quote
^^^ Laughing Laughing Laughing ^^^
Go find a cows arse to stick your hand up. You will, I'm sure, feel much better.
Actually I'm totally sympathetic. Our Shell office computers ust to go to screen savers of happy Shell people all over the world if you so much as looked away from the screen. Thern you always had to log in again. Once a month it forced you to change passwords, cretinous system that it was.
PostPosted: 16:00 - 02 Jun 2022    Post subject: Reply with quote
So by the end of the year you're on 'Passw*rd12'?
UncleFester
PostPosted: 18:06 - 02 Jun 2022    Post subject: Reply with quote
Oh the new shite stops that. Different random non similar required each time. 16 characters, one special, one cap, one number etc. Passwords remembered for 2 years.
Yawn bored etc.
Doesn't stop some chunt from clicking on shite they shouldn't but does make everyone else's lives that bit more irritating.
2017 Z1000SX
PostPosted: 19:05 - 02 Jun 2022    Post subject: Reply with quote
Yawn bored etc.
Yeah, then a someone gets a keylogger on there and all they need to do is search for alphanumeric strings which don't appear in the dictionary.
Hong Kong Phooey
PostPosted: 19:40 - 02 Jun 2022    Post subject: Reply with quote
Password rules became so convoluted that they have in fact weakened passwords, and to get around this inane must be this that and the other, which nobody can remember as they're directed to change them often, people write them down, or save them in a file, so even fucking worse you can now get full access to all apps, rather than guess just one.
Islander
PostPosted: 19:42 - 02 Jun 2022    Post subject: Reply with quote
You wouldn't get that one past the filters on our system Laughing
Timeouts at 3 minutes are a tad extreme. We have ours set to 10 minutes which was a pragmatic decision on my part and we still get people thinking that it's too short. Not that they get any sympathy from me on that. Laughing
Islander
PostPosted: 20:03 - 02 Jun 2022    Post subject: Reply with quote
I set a policy about 10 years ago that requires unique passwords on reset with a history of, IIRC, 24. We have a minimum length of 10 characters for users and 16 characters for privileged accounts with a requirement for at least one upper case character, one number and a special character. change frequency is currently 60 days.
Oh and we always use MFA for external systems and any time the user isn't on premise
That's going to change to longer passwords with a recommendation of the usual 3 or 4 unconnected words and an upper case, a number and special character. The payoff will be that change frequency will be annual. Entropy trumps complexity every time Smile
I actively encourage the use of password managers and we offer Keepass on the corporate app store.
We operate a filter that detects and rejects commonly used easily guessable passwords.
Passwords are on their way out anyway - biometrics will supercede them.
PostPosted: 20:42 - 02 Jun 2022    Post subject: Reply with quote
It's getting to the point where I just don't do stuff because i can't be arsed tracking down the login. I've stopped using two of our labs because they use online submission forms. It's FAR quicker and easier to fill in a paper form and put it in the package. I actually challenged one of my nurses to a race to submit a blood test. Paper was twice as fast, and that was with the printer playing ball, which they often aren't.
Islander
PostPosted: 21:21 - 02 Jun 2022    Post subject: Reply with quote
There's no doubt that some systems just aren't fit for purpose. My OH works for the local GP as a medical secretary/dispenser and finds some of the systems immensely frustrating. It's always down to poor design and usually when some antiquated DOS based system has been bodged and patched over and over to bring it up to some sort of standard to operate on newer technology rather than investing in redesign to to the job properly. And of course the testers are the system users.
PostPosted: 21:52 - 02 Jun 2022    Post subject: Reply with quote
These lab interfaces are so thoroughly modern they have lost all functionality. The web interface has clearly been designed to be accessed on a touchscreen device by a fatfingered moron. There are so many mandatory fields you spend ages looking for irrelevant details (or just make them up). Think passenger locator form. You often actually can't find the product you are looking for because it relies on a "smart" search algorithm to offer you options, no option for a comlete list so if I don't call a test the same thing they do, it's as if it isn't there (so if I type 'pancreatic lipase', nothing comes up because it's actually under 'specCPL').
The clincher for me is if one did actually access it using a touchscreen device, I would then have to print out the resulting form and a postage label on two different printers. Printer connectivity and functionality is most definately not somewhere touchscreen devices excel. I have enough problems using a printer that's directly plugged into a desktop PC.
I have of course told them this directly at their last sales pitch but they aren't interested, so they just don't get any work from me.
I did have a chuckle when I recently had to sign a two page document outlining my security responsabilities when accessing a government database which will ONLY run on Internet Explorer. I have also pointed this out to our IT company because they're making noises about upgrading the windows version.
PostPosted: 22:04 - 02 Jun 2022    Post subject: Reply with quote
While I'm grinding gears.
Lying, bone idle, incompetant tradesmen.
The door lock at work is malfunctioning. It's secure but it rattles about and won't stay on the sneck so people keep being locked out. The current solution is a fresh piece of duck tape every morning.
Got a "locksmith" in to fit a new one. He fucked about for a bit then told us it's an obsolete door and they don't make locks for them any more so we need a new door Kthnksbye.
I smelled a rat so had a look. It's an aluminium door and has a high-end, totally industry standard lock plate with screw in locks. Too me all of 30 seconds to find all the exact, direct replacement parts for them online. The lock cylinders are absolutely fine, the lockplate is beyond worn out.
What he actually meant to say was "I'm really sorry, your lockplate is badly worn and I've burred out the head on one of the grub screws and stripped a thread on the door trying to overtighten them to take up the slack. Thing is, I'm too bone-idle to drill out the screw so I can remove it and too incompetant to fix the stripped thread."
I've told the practice manager I can fix it but it'll take me two hours now instead of the 15 minutes it would have taken because I'll have to centre burr and drill out a grub screw and fit a helicoil.
pepperami
PostPosted: 23:50 - 02 Jun 2022    Post subject: Reply with quote
Neuralgia , I’ve got it, my head fugging hurts Evil or Very Mad
The last post was made 4 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> Dear Auntie BCF... All times are GMT + 1 Hour
Page 86 of 181
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 139.79 Kb
