obd scanner not working
PostPosted: 15:56 - 27 May 2022    Post subject: obd scanner not working Reply with quote
hi,
ive managed to get it to pair, i think, but the light doesnt come on on the scanner box. weird. ive checked pin 16 and there is power. so it isnt the cable, fuse or a power problem. its an obd ii scanner and i bought it from a reputable dealer on ebay. i hope its not a fake. any suggestions?
https://www.ebay.co.uk/itm/284192696000?_trkparms=amclksrc%3DITM%26aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Dc8343a53a9b34cea8e654ec89b284a57%26pid%3D100675%26rk%3D5%26rkt%3D15%26sd%3D283645981441%26itm%3D284192696000%26pmt%3D1%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A2a877fc1-ddcd-11ec-b5c6-a265ee824b54%7Cparentrq%3A0604af481810a7b30b52fc25fffc1450%7Ciid%3A14
ive also tried 2 different apps and i get the same result. cannot connect... one was recommended on the box it came in and the other was recommended on the ebay page...
Nobby the Bastard
Harley Gaydar
PostPosted: 16:35 - 27 May 2022    Post subject: Reply with quote
You are following the instructions on how to connect via bluetooth? I have the same one and it works perfectly.
Triumph Sprint ST 1050
777
PostPosted: 16:46 - 27 May 2022    Post subject: Reply with quote
yes. im not sure its pairing to the correct device though, as no lights come on
Nobby the Bastard
Harley Gaydar
PostPosted: 17:09 - 27 May 2022    Post subject: Reply with quote
Once paired have you tried interrogating it with the app?
777
PostPosted: 17:15 - 27 May 2022    Post subject: Reply with quote
yes but it wont connect
WD Forte
PostPosted: 17:18 - 27 May 2022    Post subject: Reply with quote
Just because you paired it doesn't mean its talking to the bikes ECU
so it'll probably do jack shit until/unless it does.
bikers smell of wee
Nobby the Bastard
Harley Gaydar
PostPosted: 17:28 - 27 May 2022    Post subject: Reply with quote
Is your app set to use Bluetooth or wireless?
MCN
PostPosted: 18:33 - 27 May 2022    Post subject: Reply with quote
Right... First things.
The OBDII reader for nine Quid will be a very very basic code reader.
OBDII readers and the info contained in vehicle electronics must be available to vehicle owners.
The more dough you invest in a reader the more competent/capable the reader will be.
Depending on what you are plugged into can determine what you can see (and possibly change)
Snapon (for example) makebvery very good readers that can poke about almost 90% of vehicle systems and allow changes (where changes are permitted)
But they beasts cost a fecking fortune.
The second thing is what software you are using to BT connect to the reader.
I have a 6 quid reader and probably tried 6 different apps to read the hoowur with very.limited success.
OBD2 Scan master.
OBDII Check (Torque lite) is the best one on several vehicles.
I cant see enough in any vehicle to makebthe apps worth a payment for more functions as the 6 quid reader is shite.
Try more apps. (All the apps) and see if one or more connect with better success.
I use my 6 quid reader and the OBDII Check Torque Lite on several makes of works vehicles. It lets me maybe read some codes. But not switch anything on the vehilce.
Some readers wont see ever module either.
xX-Alex-Xx
PostPosted: 19:01 - 27 May 2022    Post subject: Reply with quote
If you're using an iPhone as well, you'll have much less success than with Android as apple dictate Bluetooth 4 for a lot of things, and lots of OBD2 readers only support v3. Had this myself, actually on one that looked very similar to the one in the link.
DILLIGAF
Fat Angry Scotsman
PostPosted: 09:42 - 30 May 2022    Post subject: Reply with quote
I've also ran into this problem with Bluetooth compatibility on iPhone, OP you should double check as this might be the problem.
Easy-X
PostPosted: 11:02 - 30 May 2022    Post subject: Reply with quote
iOS devices work much better with WiFi dongles.
Copycat73
PostPosted: 15:57 - 30 May 2022    Post subject: Reply with quote
mine works with a cable ... and guess what .. it works ... blue tooth or wireless give nothing but trouble ...
caveat emptor
777
PostPosted: 17:36 - 30 Jun 2022    Post subject: Reply with quote
i bought a self powered reader and it works
The last post was made 3 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.40 Sec - Server Load: 10.32 - MySQL Queries: 13 - Page Size: 75.96 Kb
