| C0rruptd0wnl0... |
 C0rruptd0wnl0... Derestricted Danger
 Posted: 14:24 - 03 Jun 2022 Post subject: Suzuki gsx s125 |
So I'm seeking advice.
I have a suzuki gsx s125 2017 gp, the issue I'm facing is the bike losing power and dieing after a short distance (has led to some rather long walks home pushing it).. I originally believed the issue to be the stator not charging the battery, however I have now replaced the stator, and still the same issue continues.
With a freshly charged battery, the bike starts and runs. There is a whine on the engine on acceleration and deceleration. The bike will run until it has drained the battery, and then starts to die a slow death. The abs light flicks up on the speedo to start with, even at 50mph, it will then slowly dim out as the bike seems like its starved for fuel and then seems to be misfiring, upon which gears no longer show on the speedo. Then engine then cuts out after a cough and splutter. All of this happens within 5 to 10 minutes. I've also noticed I no longer have low or high beam lights even when at full battery, the light on the speedo doesn't light up at all when switching between them or touching the yellow pass button..
Unfortunatly I am self taught with all of my mechanic ability and electrical knowledge, and this is leaving me stumped. A friend of mine thinks it could be the cdi. I thought to hit a forum and see if you beautifully minded people could advise before I go spending a lump of money on a new cdi.
Thank you in advance |
| Nobby the Bastard |
| C0rruptd0wnl0... |
| Bhud |
 Bhud World Chat Champion
| C0rruptd0wnl0... |
| Nobby the Bastard |
| C0rruptd0wnl0... |
| WD Forte |
 WD Forte World Chat Champion
| C0rruptd0wnl0... |
| C0rruptd0wnl0... |
| Robby |
 Robby Dirty Old Man
| jeffyjeff |
 jeffyjeff World Chat Champion
| C0rruptd0wnl0... |
| C0rruptd0wnl0... |
 Posted: 10:09 - 08 Jun 2022 Post subject: |
| Robby wrote: | Set it to DC volts. Connect to the battery.
With the bike all turned off, you should be seeing 12.5-13v. That's the voltage of a healthy, charged battery.
With the engine idling it should be around 13v, and stable. If the voltage is dropping, it isn't charging.
With the engine at 4000rpm (ish) it should be around 14.5v and stable. Generally if the charging system is knackered, you will see 12v and falling at this point.
So I checked the battery before putting it on the bike last night, I was at 12.5v. Once I'd put it on the bike it dropped to 12.2v, started the bike up and had the engine idling it dropped to 12v, with 5k rpm it dropped down to 11.8 and then climbed back to 12 and kept fluctuating between the 2 readings.
From everything I've checked following the flow chart, everything is pointing to the RR, so I've ordered a genuine suzuki rr for the bike. It arrives Friday, so I will post whether it has resolved my issue.. Thank you for all your time guys, youve been very helpful |
| Nobby the Bastard |
| C0rruptd0wnl0... |
| Nobby the Bastard |
| C0rruptd0wnl0... |
The last post was made 4 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
