Cylinder head spark plug thread
David orr
PostPosted: 17:00 - 03 Jun 2022    Post subject: Cylinder head spark plug thread Reply with quote
Hi, I have a 3 year old Sym Symphony 125 and the spark plug blew out of the cylinder head as I was riding, I’m unable to screw it back in as it just keeps turning I have a new plug so it has to be the threads in the head is there any other solution for this other than a new head
Many thanks D
David
Nobby the Bastard
Harley Gaydar
PostPosted: 17:04 - 03 Jun 2022    Post subject: Reply with quote
Helicoil
Triumph Sprint ST 1050
WD Forte
PostPosted: 17:05 - 03 Jun 2022    Post subject: Reply with quote
this kind of thing comes to mind
https://www.ebay.co.uk/itm/393257074532?
bikers smell of wee
David orr
PostPosted: 17:05 - 04 Jun 2022    Post subject: Reply with quote
W D Forte,
That’s brilliant and cheap thank you.
I’m assuming the tap cuts the hole for the insert and the inside
thread of the insert is the correct size for the plug.
The head is off now just waiting for the tool.
Thanks again.
David
om15
PostPosted: 08:49 - 05 Jun 2022    Post subject: Reply with quote
I had the same with a BSA C15, took the head to GCS at Three legged Cross and the damaged thread was machined and a swaged thread was fitted, neater than a helicol.
They did a good job,
Address: 18 Thorne Way, Three Legged Cross, Woolsbridge, Wimborne BH21 6FB
Phone: 01202 826045
Alcohol doesn't solve problems, but neither does milk
om15
PostPosted: 08:53 - 05 Jun 2022    Post subject: Reply with quote
Just found this photo,
David orr
PostPosted: 13:48 - 05 Jun 2022    Post subject: Reply with quote
Thanks for that the problem is I live in Spain, I’ve got a trip back next month so will certainly consider that.
Thanks again
WD Forte
PostPosted: 14:11 - 05 Jun 2022    Post subject: Reply with quote
With the right kit and taking your time you can do it as well as any shop will.
Done lots of helicoils but never had to do a plug hole ( yet)
The one I indicated was an example which follows the same procedure, but I can't attest to the quality of that particular product.
I see some products have 'leader' threads to act as a guide
when cutting the new thread (Pic below)
I would advise to take care to follow the axis of the old thread
when tapping out the new one for the insert.
Thoroughly clean and de-grease the new thread and use thread lock when fitting the insert.
Note the inserts have a leading and trailing edge when fitting
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fcimg0.ibsrv.net%2Fgimg%2Fwww.ford-trucks.com-vbulletin%2F1437x751%2F80-helicoilsavathread_26ba52773ec4c1e368a0e75ba1aac8ded510a590.jpg&f=1&nofb=1
bikers smell of wee
PostPosted: 16:32 - 05 Jun 2022    Post subject: Reply with quote
Make sure you get the correct insert kit the bike seems to use CR7 plugs which are M10 x 1.0mm thread. The kits listed above are M14 for a B type plug.
WD Forte
PostPosted: 18:34 - 05 Jun 2022    Post subject: Reply with quote
Ooh! thassa good point.
hadn't considered those modern weeny plugs.
bikers smell of wee
David orr
PostPosted: 18:39 - 05 Jun 2022    Post subject: Reply with quote
Yes Pete it is a 10mm x 1.00 mm I will make sure when ordering.
W D Forte I will have a go myself I’ve found a good kit on eBay.es bit more expensive but I think worth it similar to the one you show it has a leading edge the same thread as the existing plug to follow what is left of the old threads then follows up with whatever the insert thread is.
I’ve got Loctite 638 that should do it.
Many thanks everyone you’ve given me the confidence to have a go.
David
The last post was made 4 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 65.74 Kb
