Tip for diagnosis problems with ethanol/water in fuel
Robby
Dirty Old Man
PostPosted: 08:42 - 04 Jun 2022    Post subject: Tip for diagnosis problems with ethanol/water in fuel Reply with quote
This is for people who have a carbed bike and are paranoid or concerned about the ethanol mixing with water in the tank and dropping out of suspension in the fuel and leaving you stranded when you switch onto reserve.
Put a few drops of blue food colouring in the tank.
Food colouring will not mix with petrol. It will mix with an ethanol-water mix. So if there is a puddle of dilute ethanol in your tank, it will now be blue. If you're concerned about having this crap sitting in the bottom of your tank, run the bike on reserve for a minute.
If you have a fuel filter, you'll see that it now has blue in it. Alternatively, crack the drain screw on the lowest carb and see if blue stuff comes out.
For the truly paranoid, or for old bikes that spend a lot of time sitting, you can extract the ethanol using water. I mix a litre of water and food colouring with 10L of super unleaded in a plastic container, give it a shake, and leave it overnight. Next day I drain off the blue water and measure it. Super unleaded is up to 5% ethanol, so I can expect to have up to 1.5L of blue water (1L water + 500ml ethanol) to remove. In practice it's more like 300ml ethanol. Now I have ethanol-free petrol which is still high enough octane to work, my old bike only needs 91 RON and the stuff I'm left with should be around 94.
PostPosted: 09:20 - 04 Jun 2022    Post subject: Reply with quote
Although the dye is probably unecessary, you can usually see water droplets sat in the bottom with a torch or if you drain some fuel from the float bowl into a jam jar.
Some bikes used to have a sediment bowl on the fuel tap, you just unscrewed it to see if it had trapped any water or bits of muck.
Perversely, one of the fixes for water in your fuel is to add some ethanol and shake it up.
Robby
Dirty Old Man
PostPosted: 11:17 - 04 Jun 2022    Post subject: Reply with quote
The dye helps for seeing it in a transparent filter, or in low light.
sickpup
Old Timer
PostPosted: 02:19 - 15 Jun 2022    Post subject: Reply with quote
Pretty sure thats methylated spirits not ethanol.
PostPosted: 12:11 - 15 Jun 2022    Post subject: Reply with quote
Methylated spirits is 90% ethanol with methanol and some other stuff added to make it purple and nasty to drink.
sickpup
Old Timer
PostPosted: 13:43 - 15 Jun 2022    Post subject: Reply with quote
And it's those other bits from what I gather that means you end up with a mix that stills burns in an engine rather than water that sits separate at the bottom of the tank.
PostPosted: 14:07 - 15 Jun 2022    Post subject: Reply with quote
Not really, no.
Ethanol will form a solution with water and still burn down to about 40%. So if you had 60ml of water in the bottom of your tank and mixed in 40ml of pure ethanol, it would dissolve in the alcohol and still burn with a blue flame.
It's an actively hygroscopic process at higher concentrations, the ethanol is more stable below 70% so very pure alcohol will actively look for water to dissolve in. If you leave the lid off a bottle of 95% alcohol, it'll absorb water from the atmosphere until it's 70% alcohol, then it becomes more stable. Ethanol will still burn down to 40% at room temperature (you can light sambuca).
Methylated spirits are about 10% methanol too which has similar properties but is even more volatile, it's even more soluable in water but the bulk of it is ethanol.
The last post was made 3 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.72 - MySQL Queries: 15 - Page Size: 55.1 Kb
