| MahatmaAndhi |
 MahatmaAndhi Traffic Copper
 Posted: 09:25 - 01 Jun 2022 Post subject: Battery Woes - Aprilia Sportcity 250 Scooter |
Hi all,
It's been a while since I posted here, but I now I'm back on two (motorised) wheels, I figured I'd give it a shot.
I bought my 2008 Aprilia Sportcity 250 a few weeks back. It was a fixerupper but (with my meagre mechanical skills) managed to get it up and running.
I'm currently on my third battery from Halfords though. The first simply didn't fit. So that went back.
The second (a Yuasa YT12B-BS) fit, but wouldn't start the bike. The bike has a volt meter on it and it said, out of the box, it was around 7.5 volts. I tried charging it overnight, but it never exceeded 11.5V. Given that this was meant to be a fuss-free battery, I took it back and exchanged it for another Yuasa YT12B-BS.
This one has been fine. For about a week. I've done about 100 miles on the bike, all on this battery. I thought all was well. However, yesterday I went to get on it and it the bike wouldn't start. The lights and dashboard all lit up, but when you pushed the starter, it gave a single 'cough' and died.
I can't remember what the volt meter showed. I think it was 7.5V again. But I can't remember.
I've taken the battery off and put it on charge where it has been since around 7pm last night (about 14 hours). It's still charging now.
Any ideas what could be wrong? Is it another duff battery from Halfords? Does my bike have an electrical problem that I need to diagnose?
One thing worth mentioning is that there's a Meta alarm system on the bike. I'm not sure which model, but I have the key and the fob and they're very annoying to have to use. Could this be the culprit? I saw that you can get bypass kits online so I am planning on doing this anyway when I figure out the model.
That's the only thing that I can think of that isn't stock. But, again, I've very limited experience and so I wouldn't know for certain.
Thanks! ____________________ 2008 Aprilia Sportcity 250 |
| P.addy |
 P.addy Red Rocket
| MCN |
 MCN Super Spammer
| MahatmaAndhi |
 Posted: 21:59 - 01 Jun 2022 Post subject: |
Thanks for your help so far. Apologies for being a dullard, but here's the update.
I have a multimeter. It's a bit of a crap one from Amazon.
I haven't been to Halfords yet, but with a freshly charged battery I went and did what you said. Or at least my interpretation of it.
https://i.imgur.com/vJv99EMm.jpg
Big version: https://imgur.com/vJv99EM
I think I've misunderstood somewhere along the lines.
When I put the battery back in the bike started up fine (it's been charging for 24 hours.) However, when I turned the ignition off again I noticed a noise. It was really faint, but sounded what I imagine an electricity current to sound like (as hard as that is to explain).
The noise was coming from somewhere under the seat. And, when I removed the negative cable, the noise stopped completely.
If it's the alarm/immobilizer system, then I'm happy to get rid or bypass it. I've just got to identify the model number first, by whipping off the tupperware until I find it. That's a job for the weekend. ____________________ 2008 Aprilia Sportcity 250 |
| WD Forte |
 WD Forte World Chat Champion
| MahatmaAndhi |
 Posted: 12:38 - 02 Jun 2022 Post subject: |
Ahh yeah, I see what I did there.
I did as you've suggested (I hope). It settled at 0.01, but did jump up to 0.11 at times.
That pesky noise is still there though whenever the battery gets fully connected.
https://i.ibb.co/xL17Q6h/20220602-114724.jpg ____________________ 2008 Aprilia Sportcity 250 |
| WD Forte |
| MahatmaAndhi |
| Polarbear |
 Polarbear Super Spammer
| WD Forte |
| MahatmaAndhi |
 Posted: 14:17 - 03 Jun 2022 Post subject: |
I found the alarm and took it off. Using this video of a guy with the same model, I managed to bypass the alarm and immobiliser with some dynamo cable. It's still starting, which is nice. However, that noise still persists. And it's made no difference to the draw from the battery.
I'm going to order an isolator switch for the time being so I can quickly disconnect the battery when the bike's not being used. At least until I can figure this out.
As for insurance, I didn't have the bike when I set up the insurance, so I said 'No' to alarms, immobilizers etc. ____________________ 2008 Aprilia Sportcity 250 |
| WD Forte |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| MahatmaAndhi |
 Posted: 11:26 - 04 Jun 2022 Post subject: |
I've done as you said.
When the battery is connected but the key is off, the reading is 13.34v.
When the key is turned, but the engine is still off, it drops to 12.65v but moves about a tiny bit.
Then, when the engine is on, it settles around 14.35v.
That noise could potentially be the fuel pump, but it never seems to turn off. I've had the battery connected, but not started for about 20 mins and it's still been there.
I've also heard it after a ride, once I've switched the engine off.
What I'm thinking is to put the battery on and carry on as normal. This has only happened once and the alarm is now off. Maybe that fixed it and the noise is unrelated (wishful thinking).
The bike has a volt meter built in which seems pretty accurate, matching the multimeter, so I can check it daily to see if there's an overnight drop.
If the problem persists, perhaps it's time to call in the professionals.
If you've any more suggestions, I'm happy to keep trying. And I really appreciate the help. I'm learning as I go, and regretting the amount of time that I skived off school. ____________________ 2008 Aprilia Sportcity 250 |
| WD Forte |
| MahatmaAndhi |
| WD Forte |
 Posted: 15:32 - 04 Jun 2022 Post subject: |
| MahatmaAndhi |
| WD Forte |
| MahatmaAndhi |
| sickpup |
 sickpup Old Timer
The last post was made 4 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
