2006 Suzuki GN250 Motorcycle Sidestand Switch
claynz
PostPosted: 23:45 - 11 Jun 2022    Post subject: 2006 Suzuki GN250 Motorcycle Sidestand Switch Reply with quote
Should my motocycle be moving off without stalling with the side stand down?
Faulty switch?
WD Forte
PostPosted: 01:27 - 12 Jun 2022    Post subject: Reply with quote
Probably, or it's been disconnected because it was playing up
or a connection has broken.
Haven't seen the wiring diagram, but most are linked to the ignition system/cdi/spark unit/whatever and disable the sparks
when in the down position.
If it were mine, I'd check the cables and connections first
then if that's ok, get a meter and test the switch functions ok.
It should go from dead short to open circuit ( or vice versa)
as the stand is lowered and raised.
bikers smell of wee
jaffa90
PostPosted: 01:34 - 12 Jun 2022    Post subject: Reply with quote
From my memory the engine should stop when selecting any gear with the side stand down, neutral switch comes into play as well.
claynz
PostPosted: 22:36 - 12 Jun 2022    Post subject: Reply with quote
Was told the GN 250 doesn't have a side stand switch, but clearly shows one listed on the Suzuki parts list!!
SWITCH ASSY,SIDE STAND
Switch assy, center stand Switch assy, side stand;
37840-44X50-000
The last post was made 4 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 38.66 Kb
