| dsg10715 |
 dsg10715 Derestricted Danger
| davebike |
 davebike World Chat Champion
 Posted: 06:17 - 15 Jun 2022 Post subject: |
OK as a pro I have vacuum bleeder and a low pressure reverse bleed system
I never encountered a Honda that will not bleed with a simple Tube long enough to go from calliper bleed scared up as high as the master cylinder and back down
Most common problem as the master cylinder air locked and not pumping I remove lines and use a rag and finger to prime
What is your issue ?? ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| Nobby the Bastard |
| Ste |
 Ste Not Work Safe
| Easy-X |
 Easy-X Super Spammer
| Ste |
 Ste Not Work Safe
| P.addy |
 P.addy Formerly known as P.
| dsg10715 |
| dsg10715 |
| Easy-X |
 Posted: 15:39 - 15 Jun 2022 Post subject: |
Brake master => ABS unit => Brake pistons
And the ABS unit by default (unpowered) runs in bypass mode. It'd have to! If your bike dies and you have no electrical power you'd still want brakes
So unless you completely drain your brake system so there's air everywhere - including the ABS unit - bleeding the system as if the ABS wasn't there would just leave some old fluid inside the ABS unit. Relative to the rest of the system it's a thimble to a bucket, i.e. neither here nor there. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| dsg10715 |
The last post was made 3 years, 261 days ago. Instead of replying here, would creating a new thread be more useful? |
