Pillar Drill Recommendation?
DJP
PostPosted: 16:08 - 15 Jun 2022    Post subject: Pillar Drill Recommendation? Reply with quote
Can anyone recommend a decent(ish) cheap (ish) pillar drill for light and occasional wood/metal work?
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
WD Forte
PostPosted: 16:57 - 15 Jun 2022    Post subject: Reply with quote
You'll probably pick up a Clarke bench mounted one for a oner
from machine mart.
If its for hobby/occasional use it may well serve
There are cheaper ones on Ebay of course, both new and second hand.
As for quality it's hard to say.
You may find a cheapie does you fine
or you may find it doesn't have the depth of throat you need
or the chuck is a bit shit or the spindle has some run out
or the bed isn't quite 90 degrees to the spindle
or other 'features' that make you wish you had paid a bit more.
If it's for say 6mm drills through ally or mdf a cheapie will do
if you want to put an 18mm reduced shank bit though 1" steel
the cheapies may struggle and distort with hard use
bikers smell of wee
sickpup
Old Timer
PostPosted: 17:29 - 15 Jun 2022    Post subject: Reply with quote
I would recommend having a look on Gumtree and Ebay , lots of used ones about cheap and people won't post them.
Fat Angry Scotsman
PostPosted: 08:49 - 16 Jun 2022    Post subject: Reply with quote
WD Forte wrote:
You'll probably pick up a Clarke bench mounted one for a oner from machine mart.
I second this, Clarke tools are actually fairly good considering their firmly in the cheap end of the market. The Clarke pedestal drill, horizontal bandsaw and MIG welder I had was perfectly fine. The only really shit thing I ever got from Clarke was their mini-mill, that was fucking awful and a waste of money.
WD Forte
PostPosted: 10:33 - 16 Jun 2022    Post subject: Reply with quote
whatever you buy
I would add getting a good bolt down vise for it or a means of clamping down workpieces as a good idea
especially if you're drilling metal.
bikers smell of wee
blurredman
PostPosted: 13:51 - 16 Jun 2022    Post subject: Reply with quote
I agree generally, but I recall their tyre gauge I bought and then returned was reading 20psi under Laughing Shocked
The last post was made 3 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 49.78 Kb
