Engine not drawing fuel in
Streaky100
PostPosted: 12:46 - 03 Jul 2022    Post subject: Engine not drawing fuel in Reply with quote
I am trying to get a 57 plate honda cg125 running. Will not even try firing even though I have new battery, fuel and spark plug. The carburetor works fine when I tested it on my other bike, but noticed that on this bike there is no fuel entering the engine, but instead is spitting out of the little hole under the choke flap and into the intake pipe towards the air filter. I checked the valve clearance and they are set at 0.08mm..... What have I f@#&ed up??????
Nobby the Bastard
Harley Gaydar
PostPosted: 13:13 - 03 Jul 2022    Post subject: Reply with quote
Cam timing?
Triumph Sprint ST 1050
WD Forte
PostPosted: 14:39 - 03 Jul 2022    Post subject: Reply with quote
what have you fooked up?
could be a lot of things, what are we, psychic?
Did you set the valve clearances on the correct stroke?
bikers smell of wee
Fat bloke
PostPosted: 12:27 - 06 Jul 2022    Post subject: Reply with quote
Have you done any engine work? A possible problem is that the valve timing is wrong where the inlet valve isn't opening on the intake stroke but opening with the piston on the way up therefore pushing air the wrong way through the carb. A totally blocked exhaust could potentially cause a problem like this. Difficult to diagnose without further information.
You're only supposed to blow the bloody doors off!
The last post was made 4 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 38.7 Kb
