| to v or not to v |
 to v or not to v World Chat Champion
| Islander |
 Islander World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 20:35 - 05 Jul 2022 Post subject: |
They go from working to broken without any warning. Complete bastard to change too on most bikes. ____________________ a.k.a 'Geri'
| Nobby the Bastard |
| stinkwheel |
 Posted: 20:44 - 05 Jul 2022 Post subject: |
They are cleaner and less faff. But race bike have chain.
A well oiled plain roller chain is more efficient than a belt. I strongly suspect a waxed x-ring chain is not.
Enclosed chains are another good idea you don't see a lot of.
The cost and difficulty changing is more than made up for in my oppinion by their longevity. Would I rather replace a chain and sprockets 2-3 times (and adjust and lube it between times, and clean the lube off the rest of the bike). Or do a belt and pulleys once, but have to drop the swingarm to do so? I'd go belt every time.
People say they go with no warning, but so do chains. I wasn't expecting any of the several chain breaks I've had over the years. It's not exactly straightforwards to replace/repair a broken chain at the side of the road anyway. In the unlikely case you are carrying a spare splitlink, it's probably broken somewhere you can't use it, or the chain's gone missing, or broken some other part of the bike too. (and, would you want to continue riding on a chain that's already snapped once?) You're most likely getting recovered in case of a broken belt or chain. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pete. |
 Pete. Super Spammer
| stinkwheel |
| Easy-X |
 Easy-X Super Spammer
 Posted: 22:56 - 05 Jul 2022 Post subject: |
Harley seems to like them, reason enough to stay away
Seriously though not just swapping is a pain. Adjusting the slack requires a torque tool to deflect the belt with a pre-set force bit like using a torque wrench  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Shaft |
 Shaft World Chat Champion
 Posted: 23:13 - 05 Jul 2022 Post subject: |
| stinkwheel wrote: | | Pete. wrote: |
That is true but a badly maintained is easily apparent, a tired belt shows no distress until it parts. |
That's why there are service schedules.
What I've never quite understood is why the service life of bike drive belts is relatively short.
It's essentially the same tech as an automotive timing belt and, for example, on the VWs I work with at the moment, they have a service life of 125,000 KM.
OK, timing belts are generally much shorter than drive belts and they aren't usually as exposed to the elements/road debris, but they do go through much more severe heat cycles, plus they have to deal with substantially more torque input, typically measured in hundreds of lb/ft.
Apart from the need for greed leading to an imperative to sell spare parts, why can't bike manufacturers make their belts last more than 20,000 miles? ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Pete. |
 Pete. Super Spammer
| Polarbear |
 Polarbear Super Spammer
| Shaft |
 Posted: 00:06 - 06 Jul 2022 Post subject: |
| Evil Hans |
 Evil Hans World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| Robby |
 Robby Dirty Old Man
| stinkwheel |
| Shaft |
 Posted: 23:20 - 06 Jul 2022 Post subject: |
| Robby wrote: | | Shaft wrote: |
Apart from the need for greed leading to an imperative to sell spare parts, why can't bike manufacturers make their belts last more than 20,000 miles? |
It was my understanding they belts do last quite long. Plenty of anecdotal evidence from US harley forums, including tuned big twins, that belts last ages. Some of them seem upset to get less than 100k miles out of a belt.
Age would be a factor though. Rubber, UV light, sadness.
Harleys might be OK, but Buells less so and BMW F bikes seem to struggle to get past 30K.
I was very interested in a Hyosung Aquila 650, but the belt drive seems to be a problem on them, not least because it's a stupid amount of money, like £200+.
Then there was the fully enclosed drive belt on my Silverwing, which has an official service life of 16K (they can last longer) but is around 70 quid for something which is nothing more than a glorified fan belt.
Doesn't work well for me. ____________________ Things get better with age; I'm close to being magnificent........
| stinkwheel |
 Posted: 00:01 - 07 Jul 2022 Post subject: |
A high-end chain and sprocket set for a 600 supersport costs in the £150-180 ballpark. So a £200 belt, which I'd expect to last longer, isn't all that outrageous. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mentalboy |
 mentalboy World Chat Champion
| to v or not to v |
| MarJay |
 MarJay But it's British!
 Posted: 22:26 - 07 Jul 2022 Post subject: |
I had 3 Buell's with belts. The reason they aren't employed more is that the belt wheels need to be machined extremely accurately and finished with some kind of hardened finish. You might argue the same as a sprocket, but everybody and their dog produces thousands of sprockets every day, whereas that is not the case with belt pulleys.
The Buell pulleys were powder coated which could flake off with age, and then the belt would wear through. I had a couple of high mileage bikes with their original belts over 20,000 miles, but a single stone getting in between the belt and the pulley could snap the belt.
One advantage nobody has mentioned is that when it goes, it generally doesn't take the crankases out, or your toes off. It just falls to the floor and you lose drive. A belt also works like a cush drive absorbing power pulses, and is generally engineered so you never need to adjust the wheel alignment and also always have a consistent wheelbase. Also when you replace the belt you don't need new pulleys unless they are worn for other reasons. I think the Buell belts at one stage were about £60 which is a lot cheaper than a chain and sprockets. Buell quoted 12000 mile life on them though, although as I mentioned I had a couple that lasted 20,000 miles. Replacing the belt wasn't too bad either as my bikes had aftermarket springloaded tensioners.
More downsides though... the pulleys are heavy and compared to sprockets I Mean HEAVY. This is of course counteracted by the lightness of the belt itself. Also the stretchiness that provides that beautiful cushioning effect means that big power can stretch or break them, although the Buell 1125R had 170 odd BHP and worked OK. The race bikes had chain conversions though.
I like a belt for a road bike, and I'd have another with a belt, but it would never be a deal breaker not to have one, or a deal breaker to have one.
Chains are so ubiquitous ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
| pepperami |
 pepperami Super Spammer
The last post was made 4 years, 98 days ago. Instead of replying here, would creating a new thread be more useful? |
