Suzuki ts125x headset bearing replacement
FlongVortn
PostPosted: 13:49 - 06 Jul 2022    Post subject: Suzuki ts125x headset bearing replacement Reply with quote
Hello everyone,
I have a problem with my suzuki ts125x. The bearings of the headset of my motorcycle are broken. There are also a few very significant marks on the inside of the bearing.
Is there some sort of replacement for this bearing? Or is it to bad to fix?
Thanks!
jeffyjeff
PostPosted: 18:24 - 06 Jul 2022    Post subject: Reply with quote
Of course you can replace the steering head bearing. You could get a bearing set from Suzuki, (upper and lower bearings) or an aftermarket set. I personally have had success upgrading to a taper-roller type bearing (similar to the front wheel bearings on a rear wheel drive car). All-Balls is a company that furnishes complete kits for steering head upgrade. The repair is not difficult. Some bikes have a notch located so you can easily drive out the race. Others do not, and you may find it easier to grind a small notch in the steering head in order to position a drift against the bearing race.
FlongVortn
PostPosted: 12:02 - 07 Jul 2022    Post subject: Reply with quote
Thank you so much for the help!
The last post was made 4 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 34.45 Kb
