Frame surface pitting
struan80
PostPosted: 17:43 - 10 Jul 2022    Post subject: Frame surface pitting Reply with quote
Unfortunately my frame has been polished and there is some surface pitting, if pitting is the right word. Can anyone recommend a method for removing this? Seems to be loads of products so not sure which to try.
Thanks
https://hosting.photobucket.com/images/yy224/struan80/292747696_1352273848629274_8867079703852784024_n.jpg?width=undefined&height=undefined&fit=bounds
Shaft
PostPosted: 18:14 - 10 Jul 2022    Post subject: Reply with quote
My old favourite, Solvol Autosol
jeffyjeff
PostPosted: 19:32 - 10 Jul 2022    Post subject: Reply with quote
elbow grease Wink
PostPosted: 22:31 - 10 Jul 2022    Post subject: Reply with quote
Rub it back to a matt lusture with green scotchbrite then laquer it and never have to worry about it again?
jaffa90
PostPosted: 01:09 - 11 Jul 2022    Post subject: Reply with quote
If no joy with previous posts try s.s. pan cleaner.
struan80
PostPosted: 14:43 - 11 Jul 2022    Post subject: Reply with quote
I might try something that. Polished front frame and swing arm is putting people off. It would be good to get it back to original. Is that possible with Scotchbright of some description?
Original is best even though polished would have been fashionable back in 1993.
PostPosted: 16:41 - 11 Jul 2022    Post subject: Reply with quote
I've seen people use it to return polished fork lowers and comstar wheels to a factory finish. Try it on an inconspicuious part first though.
stevo123
PostPosted: 16:44 - 11 Jul 2022    Post subject: Reply with quote
+1 for Autosol. You might get a quicker result with a polishing mop on a power tool (be careful not to catch the frame with the tool).
Honda XL125-Yammy DTR125-Honda NSR125-Yammy TZR 250-Aprilia RS125-KTM RC 125-
KTM RC390-Kawasaki Ninja 636-KTM Duke 390
WD Forte
PostPosted: 22:31 - 11 Jul 2022    Post subject: Reply with quote
Autosol only lasts so long then it needs to be repolished when the oxygen gets at it again.
I'd go scotchbrite or wire wool then add a satin laquer oxygen barrier
so it looks light but not blingy
bikers smell of wee
MCN
PostPosted: 00:55 - 12 Jul 2022    Post subject: Reply with quote
Aluminininimumin polish consists of oilstwaxes and a more chunky abrasive media.
'Metal' polish such as Brasso will not cut the mustard when used on aluminium.
The oil/waxes in aluminium polish helps reduce oxidation (which happens instantaneously as the 'protective' oxidized surface is removed (with any surface imperfections).
The issue with aluminium is that it doesn't like paints. To get paint to adhere the surface must be acid-etched.
Lacquer is the gloss component of gloss paint without the pigments and background fillers.
A100man
PostPosted: 09:52 - 12 Jul 2022    Post subject: Reply with quote
It's a problem as old as the hills..
Polish and then re-polish every couple of months or lacquer then re-lacquer every couple of years - which is the biggest PITA?
I guess its the reason that nearly all alloy wheels these days are actually painted or powder coated. Lacquered ones even from the factory, only last a few years before corrosion creeps in.
The last post was made 4 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 68.94 Kb
