| Ryan1984 |
 Ryan1984 L Plate Warrior
| MarJay |
 MarJay But it's British!
 Posted: 14:26 - 09 Jul 2022 Post subject: |
Diagnostic port. On an NC30.
My guess would be that the dash is a generic one, and not specifically for the NC30, in which case I'd just ignore those wires. I doubt the NC30 has any electrical connection to the gear selector mechanism, nor a clever enough ECU to 'know' what gear it's in by revs vs speed like more modern bikes do. I'm willing to be corrected but I'd be extremely surprised.
I do have the NC30 Haynes manual downstairs, so I guess I could look at the wiring diagram. Maybe I'll do that next time I'm in the garage. As I said though, I'd be extremely surprised if there is a legit method of calculating gear position using the bikes own electronics.
Maybe the dash has some intelligence in it to calculate it with revs vs speed? I know my gear position indicator on my CBR600RR needed calibrating when I first got it. In which case, it already has connections for the tacho and the speedo, it can use it's own brain to work it out, surely? ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| WD Forte |
 WD Forte World Chat Champion
 Posted: 14:13 - 10 Jul 2022 Post subject: |
There is also a good chance an NC30 is a Japanese home market model, in which case there is an optical switch inside the clocks hooked up to the CDI which cuts power to the rear two cylinders if you exceed a certain speed (which was manadtory in japan at the time they were made).
It's not as simple as disconnecting it or connecting the wires together, the CDI is looking for a specific output on the end of that wire. You usually need to either retain the optical switch or fit an appropriate voltage divider. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| redeem ouzzer |
The last post was made 4 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
