Honda NSR 125 stuttering after switching from pump to mix
Simon13245
PostPosted: 10:04 - 13 Jul 2022    Post subject: Honda NSR 125 stuttering after switching from pump to mix Reply with quote
Hello there guys Smile
It's been a while since I last posted. During that time my NSR broke two times Razz After the first breakdown, I changed the wossner piston, to a new OEM nicasil cylinder. The second breakdown required a new crank and everything that goes with it. Huge thanks to Alain for all the guidance.
After the second breakdown, my mechanic told me to ditch the oil pump and just go with the mixing of gas/oil. I'm using Ipone Samourai 2T Racing 50:1. After the repair and after ditching the oil injection, it struggles to go past 6-7k rpm on full throttle. It stutters, it shakes, and after a couple of seconds, it finally manages to go past 6-7k rpm, and then it pulls until the red line with no problems.
No carb settings were changed, everything is the same. Before the repair there was no problem, it was quick and had no problem going from 4-5k rpm to the red line with full throttle.
What do you guys think? Does it sound to you like too much fuel? I've read a lot of posts about premix, and I'm confused. What would you do? Maybe dropping the needle one notch down to limit the fuel?
Honda NSR 125R (1999)
Easy-X
PostPosted: 10:08 - 13 Jul 2022    Post subject: Reply with quote
Possibly the reverse: too little fuel - you've replaced a small volume of the petrol with oil. It does sound like the needle position would help. I'd try moving the clip down (needle up.)
Zen Dog
PostPosted: 10:12 - 13 Jul 2022    Post subject: Reply with quote
This sounds EXACTLY like a problem I had on my NSR years ago. Took me an age to figure out.
The actuator for the powervalve had been put back on the wrong way around, so it was closing when it should have been opening. Think I just flipped the pulley thing the other way round (we're accessing the deep recesses of my memory now) and it was instantly fixed.
A100man
PostPosted: 10:21 - 13 Jul 2022    Post subject: Reply with quote
Who's Alain?
Zen Dog
PostPosted: 10:30 - 13 Jul 2022    Post subject: Reply with quote
A100man wrote:
Who's Alain?
This guy - https://www.bikechatforums.com/profile.php?mode=viewprofile&u=3362.
Our resident French NSR guru. Posts very rarely, I didn't know he was still around to be honest, but if you've got an NSR125, he's the man to speak to.
PostPosted: 11:26 - 13 Jul 2022    Post subject: Reply with quote
Get a new mechanic as he doesn't have a clue what he's talking about. I've had countless Japanese two strokes over the years, and I've spoken to countless people who've had Japanese two strokes and I've NEVER heard of an autolube pump failing in that time.
Honestly, run away, find a mechanic who is actually good.
A100man
PostPosted: 11:34 - 13 Jul 2022    Post subject: Reply with quote
Zen Dog wrote:
A100man wrote:
Who's Alain?
Cool
Simon13245
PostPosted: 12:24 - 13 Jul 2022    Post subject: Reply with quote
I think you are right, it makes more sense than just giving it less fuel. I will try that out, thank you.
That may be possible. Maybe the mechanic mounted those cables the other way around. I will check it out as well. Thank you.
He said that because the rod was in a shape of an egg. I did everything right (I think) in terms of the oil pump. I repaired the rubber part that was leaking, I bled the air out of it, I set it just like the manual says, and yet the rod somehow got extremely hot and deformed.
My mechanic is also racing on two strokes, typical dirt bikes and that's why he recommended to me to just switch to premix. I was just as surprised as you because I have NEVER heard a bad story about NSR pump, and also the piston and cylinder were in perfect shape.
blurredman
PostPosted: 12:41 - 13 Jul 2022    Post subject: Reply with quote
You'll get a lot of contention in regards to premix vs pump.
Just go with what you like. Pump is convenient and also variably economic in oil consumption.
But pre-mix is a lighter throttle, and it is fine. Put a blanking plate for the pump mount. Carry the bottle, do the maths at the pump.
You can change carburettor settings if required, but i've never done so. 1-2% less fuel is not going to blow engines up. However- if we have a resident NSR expert I would fully use him Cool
PostPosted: 14:02 - 13 Jul 2022    Post subject: Reply with quote
Yet, he doesn't know you need to change the jetting when you change to premix? The mixture of fuel and oil actually makes the engine run lean because the mixture is a mixture rather than pure pterol
Zen Dog
PostPosted: 14:37 - 13 Jul 2022    Post subject: Reply with quote
There is nothing preventing it just being put on the wrong way around if I remember right, so it's easily done.
redeem ouzzer
PostPosted: 14:59 - 13 Jul 2022    Post subject: Reply with quote
Junking the oil pump is a good move, less weight, better throttle response and you know the engine is wet at maximum welly.
But yep you'll be needing to go up on the pilot and main jets by a size or two.
Be a REAL MAN!
Simon13245
PostPosted: 16:02 - 13 Jul 2022    Post subject: Reply with quote
I don't know man, he probably does know. I'm really struggling to find a solid mechanic around here. He is my 3rd try. He did the piston + cylinder for me, and now he did the rod. Overall I'm quite happy with him.
I did some testing, and it seems that the cables are the right way.
Also, I changed the position of the needle to give the bike more fuel, it did make a difference. It still struggles a bit but it's much better now.
Yeah, that is probably the ultimate solution. I will have to upjet a bit because the needle position helped but it's not perfect.
Thank you for all the suggestions, you helped me to get on the right track.
B1N
PostPosted: 22:01 - 13 Jul 2022    Post subject: Reply with quote
I'm not familiar with the NSR oil system but if you delete any oil pump you need to make sure all 2 stroke oil ways from the pump to the engine are plugged and air tight.
If not the engine will draw air in where there used to be oil leading to lean fuel/air mix.
PostPosted: 08:38 - 14 Jul 2022    Post subject: Reply with quote
Changing the needle won't let more fuel squirt through the hole... Changing the jetting however is a must.
Simon13245
PostPosted: 12:03 - 14 Jul 2022    Post subject: Reply with quote
Thank you for the tip. The hose that goes to the carb is sealed so that there is no extra air getting into the engine.
I agree. Right now the jets are:
- 138 main,
- 65 choke,
- 42 idle,
- 65 power jet.
I am planning to change to main, idle and power jets to a bigger ones.
I also noticed that there is quite a lot of black sludge coming out of the exhaust. It's quite interesting actually. Needle up (more fuel) helped a lot, but now it's producing tons of black spooge from the exhaust...
Seriously I like this motorbike but I think it's time for a modern injected 4-stroke.
The last post was made 4 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 99.75 Kb
