| Feasty |
 Feasty World Chat Champion
 Posted: 08:21 - 14 Jul 2022 Post subject: Scottoiler advice |
I've recently been given a 2nd hand Scottoiler and added it to my FZS600. I had one previously I bought for a different bike so I know how they're fitted and supposed to work, and it was excellent.
But this one is being a pain and I'm wondering if it's faulty.
When I've filled it up and got the engine running, the oil doesn't move down the tubes unless I turn the dial to 'Prime', then it moves really quickly and there's loads of air bubbles in the pipe. If I turn the dial down to hardly anything the oil still speeds through the system full of air bubbles, and then turning the engine off it continues to feed oil through and I get a big patch on the floor.
Eventually it will stop, but then the same happens again next time and it's very quickly empty.
Any ideas please? ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
| jeffyjeff |
 jeffyjeff World Chat Champion
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 11:22 - 14 Jul 2022 Post subject: |
As jeffyjeff says, it's difficult to avoid sarcasm. Clearly, it is faulty. The real questions are -
Why is it faulty?
Can it be fixed?
Can you be arsed?
From the description, it sounds to me like the unit isn't sealing properly. Assuming its a vacuum pressure one (I haven't tried the electronic ones), is the diaphragm lifting when you start the engine? If there are bubbles in the delivery tube, there has to be a leak between the reservoir and the delivery point I think. Might be worth seeing if Scottoiler sell a replacement seal kit for the unit. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| jeffyjeff |
| steve the grease |
 Posted: 17:47 - 15 Jul 2022 Post subject: |
They are stupidly simple. You have a reservoir full of oil with a needle valve at the bottom then a pipe leading to the chain.
When it's off, the needle valve is closed and oil can't run out of the reservoir. Oil can't drip out of the tube because it's a column of oil in a tube which is sealed at one end by the valve. When it's on, the engine vacuum sucks a diaphragm open which is attached to the needle valve by an x-shaped plastic rod running the length of the reservoir. Oil runs out under gravity. The volume control sets how far it's opened.
If you have primed it, the reservoir is full and facing at least slightly downhill so the valve is covered in oil and are finding air bubbles in the pipe, there is ONLY one way that can be happening. You have an air leak in the deliver hose, either a pinhole in the hose itself or a poor fit round the bottom of the reservoir.
This will be why it is emptying when off too. The other reson for one emptying when off is if the needle valve isn't closing properly, either due to being held open for some reason or having muck or damage on the tapered needle seat. The latter would not cause air bubbles to appear in the hose though.
TL;DR, you have an air leak in the delivery hose. Either a pinhole in the hose itself or a poor fit at the base of the reservoir. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kawasaki Jimbo |
| DJP |
 DJP Crazy Courier
| trevor saxe-coburg-gotha |
| Ste |
 Ste Not Work Safe
| Kawasaki Jimbo |
| Kawasaki Jimbo |
| MCN |
 MCN Super Spammer
| Kawasaki Jimbo |
| Feasty |
 Posted: 09:42 - 18 Jul 2022 Post subject: |
Wot he said.
I've had bikes with and without Scottoilers, I'd go with every time. The regular maintenance of lubing the chain isn't so bad, but I've got red wheels and they look crap after 2 mins of riding after I've re-lubed the chain. Then it takes ages to clean off.
Never had that problem once the prime and set has been done on a Scottoiler, just leave it to it topping up occasionally and chains have lasted ages without needing changing or adjusting.
Thanks for the tips, I'll need to spend some time taking it all apart, cleaning and refitting whilst making sure there's no air leaks.  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
| to v or not to v |
 to v or not to v World Chat Champion
| Nobby the Bastard |
| Zen Dog |
 Posted: 13:58 - 18 Jul 2022 Post subject: |
| to v or not to v wrote: | do these oilers need specific oil? can you put used engine oil in them? |
According to scottoiler at least, yes, you need to use their oil. But people do use other oils. They're designed to work within a certain viscosity range, so as as you're within that, and it's not going to damage the seals/tubing etc., you can probably put gravy/olive oil/maple syrup in it if you want. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| Kawasaki Jimbo |
| UncleFester |
| Nobby the Bastard |
| Zen Dog |
 Posted: 21:44 - 18 Jul 2022 Post subject: |
I do like the scottoiler, but only really because it was free. It is less hassle, but it's not £120 less hassle, to me at least. Also having to have a vacuum line or wiring to operate it does seem unnecessarily complex. I'm tempted to try some of the alternatives next time.
Loobman is super cheap - https://www.loobman.co.uk/
I like the idea of the Tutoro "jiggle" system, but it's only slightly cheaper than a scottoiler. - https://www.tutorochainoiler.com/ ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
The last post was made 4 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
