| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 20:05 - 24 Jul 2022 Post subject: Stupid Question - Camshaft Removal |
As part of the work I'm doing on the VFR 750, I'm doing the valve clearances, and I need to get the camshafts out to measure the shims. In the haynes manual, the procedure for doing this for the rear cylinders (1 and 3) is to set the engine to the TDC mark on cylinder 1, and then undo the bolts and remove the camshafts.
But when I set the engine to this position, the camshaft lobes for cylinder 1 are facing outwards (as you'd expect) and the timing marks on the cam gears are horizontal as they should be, but the lobes for cylinder 3 are one up and one down. You can see this in the pic below, which shows cylinder 3.
https://i.imgur.com/416azw7.jpg
Won't this mean that the intake camshaft on 3 (which is the one with the lobe pointing downwards), will have the valve spring pressure applied to it, potentially damaging the bolts/camshaft carrier when I try to remove it? Am I missing something? Or is that how it's supposed to be? ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| to v or not to v |
 to v or not to v World Chat Champion
| stinkwheel |
| MCN |
 MCN Super Spammer
| Nutty |
 Nutty Two Stroke Sniffer
| Zen Dog |
 Posted: 10:16 - 25 Jul 2022 Post subject: |
It's all a bit different (chain driven, VTEC nonsense etc.) but he does specifically mention that the valve springs will be applying pressure to the camshaft, so I think that I'm probably worrying unnecessarily, and I just need to make sure I relieve the pressure on the camshaft carrier evenly. Cheers!
| stinkwheel wrote: | Probably need to turn it another 360 degrees. You'll likely be on TDC on the exhaust, not compression stroke. |
See above, but will try this. I'd rather relieve all pressure if I can so I'll give it a go, but I suspect the result after doing it is going to be that Cyl3 will now have the exhaust lobe down and the intake lobe up.
| MCN wrote: | I think you check the clearance before pulling the shafts.
The clearance may still be within tolerance. |
You do. I have. And it's not. I'm onto the next stage of adjusting them now.
| Nutty wrote: | once you have TDC on #1 cylinder and T1 mark in place measure the clearances , for cylinder 3... |
Yep, that's the procedure for checking the clearances, but I've done that and they're in need of adjustment, so this is now about getting the camshafts out so I can measure the shims (and calculate appropriate replacements). ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
| Nutty |
| jeffyjeff |
 jeffyjeff World Chat Champion
| jeffyjeff |
| Zen Dog |
 Posted: 21:42 - 25 Jul 2022 Post subject: |
| jeffyjeff wrote: | Another quick recommendation. Check and record the shim dimensions on all your valves. In the future, when you measure a valve that is out of specification, you will know which shim dimension you need to correct the clearance before removing the cam. |
That is a very good suggestion. I wasn't going to bother removing the intake camshaft for 1 and 3 (they're all within tolerance) and taking measurements for those, just the exhaust ones, but I've done both now. Just need to store them somewhere I'll be able to find them in 16,000 miles...
They both came out and went back in fine btw, I just had to be careful when tightening the intake camshaft as the camlobes meant it naturally wants to be tilted. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
The last post was made 4 years, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
