BMW F800 ST vs VFR800 VTEC
Irezumi
PostPosted: 13:56 - 29 Jul 2022    Post subject: BMW F800 ST vs VFR800 VTEC Reply with quote
Anyone owned either of these long term? Does the BMW have enough power up to 80-ish and for overtakes? What needs checking when looking at second hand in particular?
What's the VFR like in terms of the VTEC (have ridden pre VTEC before), is it possible to service at home as I normally do all work myself? Anything in particular that causes problems apart from reg-rec?
Finding more and more I want to carry stuff so panniers and top box and my current bike isn't too comfortable over long distances hence the sensible change.
Thanks for any help.
ThunderGuts
PostPosted: 14:28 - 29 Jul 2022    Post subject: Reply with quote
Can't comment on the BMW although I'd imagine it has "enough" power but the viffer is still 25% more powerful.
The viffer is reasonably home friendly in that it's pretty reliable, but the valve clearance checks are a royal PITA as their frequency I think is 16k miles on that model (I stand to be corrected) and because of the engine layout it requires a lot of dismantling.
That said, I'd choose on the VFR out of that pair all day long (I have a newer VFR, although the engine has only been mildly reworked over the years, hence why it got killed off by the latest EUROX emissions regs).
TG.
Zen Dog
PostPosted: 14:43 - 29 Jul 2022    Post subject: Re: BMW F800 ST vs VFR800 VTEC Reply with quote
I haven't so all the following is at least second hand info.
The BMW. I always the fancied one, and my dad seriously considered one but a test ride put him off. He said the engine was boring. But YMMV. I don't think they have any particular reliability issues, though engine paint is a bit flaky. 80mph should be no problem.
The VFR. Apparently the VTEC "step" is really noticeable on pre-2006 models but was smoothed out later. You'll probably need to service it at home because it's such a hassle most mechanics can't be arsed. Might be worth noting that the underseat pipes can cook your arse, and cause complications when fitting panniers etc.
trevor saxe-coburg-gotha
PostPosted: 15:23 - 29 Jul 2022    Post subject: Reply with quote
i test rode that bmw and it was the worst bike i've ever been on - and i've ridden some sh1te
boring, gutless, vibey, crud
Irezumi
PostPosted: 19:26 - 29 Jul 2022    Post subject: Reply with quote
So you're open to persuasion then? Laughing Just to put it in context, what's the second worst bike you've ridden? Shocked
Anyone have any other ideas for a goo bike to ride which can tour? Prefer more upright, only want to spend around £3k but can go higher if it's suitable.
PostPosted: 19:58 - 29 Jul 2022    Post subject: Reply with quote
cb125td was pretty bad because it needed revving so hard, but felt like it couldn't take it
PotatoHead202...
PostPosted: 21:17 - 29 Jul 2022    Post subject: Reply with quote
Apart from the charging issues (can be sorted and possibly already has been) I'd choose the VFR every fucking day of the week. You'll get a MUCH, MUCH, MUCH, MUCH higher build, component and paint standard over the BMW.
Suzuki V Strom 1050XT, Honda CBF500 ABS,
kgm
PostPosted: 11:11 - 30 Jul 2022    Post subject: Reply with quote
I used a 2012 vfr 800X for commuting, touring and hooning over 4 years. It's was reliable engine wise, never a bother. With regard to valve checks it is DIYable, but it is time consuming so you need a good place to do it. You need a special tool which is basically a little insert for the VTEC valves and isn't hard to get. I just paid to have it done by a trustworthy independent because I couldn't be arsed devoting the time.
Other than normal consumables the only issues I had were a front brake disk that was showing cracks, fork seals and the chain adjuster mechanism in the rear hub seized necessitating dismantling, cleaning and reassembly. All easy to sort and I never had charging or battery issues. That bike was used regularly in horrible weather and rose conditions and tbh it helps up much better than any other bike I've had. The brake disks were expensive though! I also powder coated the exhaust heat shield beside the foot peg as those rot quickly.
Only sold it recently because my opportunity to ride longer rides has reduced and I fancy a lightweight hooligan tool instead. There isn't much that makes a better all rounder IMO. Do consider the crossrunner variant as they can be had cheap and are better suited to daily use by virtue of the riding position (at least to me). The gen 2 is the better to have (I had the gen 1)
Irezumi
PostPosted: 21:08 - 31 Jul 2022    Post subject: Reply with quote
Good suggestion but didn't want to go above £3k as not sure it's a style of bike I will enjoy. If I'm going to spend more then would look at getting a Ducati Hyperstrada which I may well hold out for and do.
kgm
PostPosted: 22:06 - 31 Jul 2022    Post subject: Reply with quote
I just sold my mk1 with full luggage for 3275, could probably get cheaper. The ride is very similar to the normal vfr, just the riding position is more upright and it's a little easier handling at low speeds.
ThunderGuts
PostPosted: 15:44 - 01 Aug 2022    Post subject: Reply with quote
Mk1 crossrunner isn't pretty which is why it didn't sell particularly well; you might get a bargain vs the 800F. Second gen 800X are much better all round, but are a lot pricier; out since 2015 so unlikely to be in budget.
I'd look at either a gen1 800X or an older (late 2000s) 800F.
TG.
Zen Dog
PostPosted: 22:20 - 01 Aug 2022    Post subject: Reply with quote
Triumph Sprint ST's are in budget. And that 1050 engine is a peach.
Irezumi
PostPosted: 22:31 - 01 Aug 2022    Post subject: Reply with quote
Had a Sprint ST 955 (2000 model) and forever put me off large engine Triumphs. Could shift but so agricultural and unrefined. Thanks for the suggestion though.
Will maybe look into the crossrunner but think I will just up the budget and look into a Hypermotard or more likely a Tracer 900.
Zen Dog
PostPosted: 11:19 - 02 Aug 2022    Post subject: Reply with quote
Fair enough. I haven't tried a 955, but one mate has a 1050 Speed Triple and another a Sprint GT (very similar to the ST), and it really is a stonking engine in either bike. Just a massive slab of torque at any revs. You can pull off on the GT without bothering to use the throttle, just feed the clutch in and off it goes, just idling along at walking pace.
But I can understand, earlier 955 bikes used to lunch their sprag clutches and so on, and if you've been put off you've been put off. Thumbs Up
ThunderGuts
PostPosted: 13:02 - 03 Aug 2022    Post subject: Reply with quote
To be honest, as you move from £3k to say £5k, your options increase almost exponentially; you can pretty much choose what you want then, plus younger bikes will be in reach.
Don't discount a Viffer; they are Swiss Army Knives of bikes and have bucketloads of character with that V4. Upping your budget can net you something tidier.
Latest (last) gen with LED headlights, heated grips, traction control, ABS (and NO linked brakes!): https://www.autotrader.co.uk/bike-details/202207298273669?make=Honda&year-from=2014&postcode=w1a1aa&model=VFR800F&sort=relevance&advertising-location=at_bikes&include-delivery-option=on&radius=1500&page=1
TG.
Irezumi
PostPosted: 15:21 - 04 Aug 2022    Post subject: Reply with quote
I do like the look of the last model. Only ever rode a pre vtec VFR (and an NC30 which is a different thing). Found the engines a little underwhelming even when I had relatively little bike experience.
Be willing to give it another go though Thumbs Up
The last post was made 4 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 93.72 Kb
