am i BCFs biggest DIY cowboy?
to v or not to v
PostPosted: 22:13 - 29 Jul 2022    Post subject: am i BCFs biggest DIY cowboy? Reply with quote
today i made a 2nd attempt at carb balancing. after getting everything up and running, carbs 1 and 2 were out by a huge amount (due to my previous attempts).
on my bike you balance 1 and 2 carbs as a pair then the same with 3 and 4, the match the 2 pairs.
after spending about 20 minutes just trying to get a screwdriver onto the adjusting screw, i finally managed it and proceeded to back the screw off so much that it fell out!
tomorrow im going to have a real fun time trying to put it back in the carb Evil or Very Mad
is anyone else on here as useless as me, or am i alone in my misery?
what cockups have you made?
Moto Guzzi V7.
Keithy
PostPosted: 23:36 - 29 Jul 2022    Post subject: Reply with quote
Nah, you are fine. I can’t take a nut off without wondering which way on it goes when putting it back.
pepperami
PostPosted: 07:29 - 30 Jul 2022    Post subject: Reply with quote
Oh no! Not by a long way!
I used to think that mole-grips was an adjustable spanner Shocked Wink .
I’ve broken screwdrivers by using them as chisels Shocked
I repaired fairings with the plastic parts of an old window frame Shocked
I used to think Gaffa-tape and cable ties were a gift from God Smile
yen_powell
PostPosted: 10:36 - 30 Jul 2022    Post subject: Reply with quote
I was asked to look at a friends 125 Kawasaki and check he'd replaced the brake pads correctly as the wheel was hard to turn.
When I looked he had somehow managed to get both pads on the same side of the disc.
I asked how he had changed them and he said he had removed the front wheel to do it, then put the wheel back on rather than remove the caliper.
He's a fully qualified and chartered civil engineer.
XT1200Z and a DR350 in bits
struan80
PostPosted: 11:15 - 30 Jul 2022    Post subject: Reply with quote
Connected the battery terminals the wrong way round. Blew main fuse. Embarassed
Blah blah
PostPosted: 11:52 - 31 Jul 2022    Post subject: Reply with quote
I rode my KH250 (when they were worth peanuts) with a jubilee clip around the throttle, holding the throttle cable on because the end of the cable had broken off and I couldn't afford a new one. It stayed like that for many months. I won't mention how long I ran it for after the middle piston seized either !
I also managed to crack the top of a carb on an IL4 trying to get a seized bolt out. "yeah, I'll just stick a spanner on it and bash that with a hammer". I then took it to get it welded and the weld lasted about an hour before the crack re-appeared, it did however still run so I left that as well.
I could also mention the time I added some spot lights to one of my bikes, using a switch and only brown wire attached directly to the battery. No connectors, just wrap the bare wire around whatever it was being connected to and then lots of insulation tape.
Or the time a friend bought his AR80 to me as it was barely running, it turns out that the carb floats were split so we found a set that almost fit and bodged them on by wrapping a bit of wire around the pin to make up the difference in width (float height? What's float height?) and off he went
These were all some considerable time ago and I hope that I am a bit better now though Very Happy
chickenstrip
PostPosted: 12:03 - 31 Jul 2022    Post subject: Reply with quote
Have you ever spot-welded the front sprocket onto the output shaft? Then no, you're a long way from taking that title.
Come on BCF veterans, what have been the worst examples on this forum? Remind us, I could do with a laugh!
mentalboy
PostPosted: 15:18 - 31 Jul 2022    Post subject: Reply with quote
I doubt if anyone can better a good sprocket yarn. Laughing
How do feel about house wiring? Laughing
Make mine a Corona.
Fat Angry Scotsman
PostPosted: 15:21 - 31 Jul 2022    Post subject: Reply with quote
Who did that? Laughing link maybe please? Laughing
pepperami
PostPosted: 17:57 - 31 Jul 2022    Post subject: Reply with quote
Fish fingers?
trevor saxe-coburg-gotha
PostPosted: 19:49 - 31 Jul 2022    Post subject: Reply with quote
That account had several aliases over the years - I never really quite believed it was genuine tbh. Regardless, it was always pretty funny.
Most enduring name of the account was Warped, iirc.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:14 - 31 Jul 2022    Post subject: Reply with quote
That wasn't Warped.
Warped did the shit geezer In the fish finger factory.
Triumph Sprint ST 1050
PostPosted: 21:16 - 31 Jul 2022    Post subject: Reply with quote
yeah - true, and welding to a hundred thou
hellkat
PostPosted: 22:33 - 31 Jul 2022    Post subject: Reply with quote
No, the guy who welded his sprocket was the guy also who shat on someone's lawn at a bbq Thinking ... erm, I dunno, I was not there at either event Laughing
But is that the same guy as the one who likes to do fat old Essex hags up the poop shute in the back of his car ? Eh? Thinking
hellkat
PostPosted: 22:36 - 31 Jul 2022    Post subject: Reply with quote
I cannot think of a single incident in which I have fucked up doin some diy on the bike, because I almost never attempt shit like that.
Although on the couple of occasions that I have had to attend to such matters, it has come out surprisingly better than I had expected it to.
Islander
PostPosted: 00:07 - 01 Aug 2022    Post subject: Reply with quote
He's had a lot of different names notable ones are bodyguard, jivebunny and milfhunter.
Well known for posting photos with strangely screwed up proportions, shitting in laybys and various other amusingly unsavoury activities most of which are complete fantasy.
Islander
PostPosted: 00:13 - 01 Aug 2022    Post subject: Reply with quote
The lawn shitter was someone different - the name escapes me for now. Covdude?
The second description is on the money though - although the claims are pure fantasy IMO. Laughing
PostPosted: 04:17 - 01 Aug 2022    Post subject: Reply with quote
yeah lawn shitter was covdude - that was the '12 bcf bbq iirc
xX-Alex-Xx
PostPosted: 08:10 - 01 Aug 2022    Post subject: Reply with quote
Isn't that like 30% of people on here?
DILLIGAF
PostPosted: 16:53 - 01 Aug 2022    Post subject: Reply with quote
and the rest
Zen Dog
PostPosted: 11:25 - 02 Aug 2022    Post subject: Reply with quote
I've snapped more bolts than I can count, on the basis of "well it's not moving, but if I apply just a BIT more force.... oh it's snapped". Confused I'm getting better at drilling them out and cutting new threads though...
I am actively trying to be less of a bodger these days, mainly by taking more time and ordering the proper tools for the job where needed.
PostPosted: 11:45 - 02 Aug 2022    Post subject: Reply with quote
https://i.imgur.com/tECFFf7.jpg
Kawasaki Jimbo
PostPosted: 19:42 - 02 Aug 2022    Post subject: Reply with quote
Thankfully I can’t compete with that but I did once install front brake pads with the friction material facing the pistons. Only on the left calliper, I’m not a complete idiot… The ‘clack-clack’ sound as I pushed the resto out of the garage in what should have been a triumphal moment gave the game away.
slowasyoulike
PostPosted: 23:29 - 02 Aug 2022    Post subject: Reply with quote
Who was the dude who lost the keys of his 125, found them again but - for reasons best known to himself - continued to dismantle his bike, leaving it on its side on the pavement (pissing oil out) from where it was towed? That one one of the best threads ever IMO.
xX-Alex-Xx
PostPosted: 08:41 - 03 Aug 2022    Post subject: Reply with quote
I bet that rubbed you the wrong way.
DILLIGAF
The last post was made 4 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 131.98 Kb
