Giilera runner 50sp carb problem
IDOTNY This post is not being displayed because the poster is banned. Unhide this post / all posts.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:04 - 30 Jul 2022    Post subject: Reply with quote
Anhero into the side of an building so that we don't have so suffer the appalling abuse to the English language.
Its your throttle cable that's sticking BTW.
Triumph Sprint ST 1050
jaffa90
PostPosted: 10:48 - 31 Jul 2022    Post subject: Reply with quote
Does the piston valve slide up and down freely on its own using the groove and locating pin?
Is the needle valve vertical and central with the piston valve before fitting?
Is the return spring damaged in any way?
Sanding parts is not the way to go. Shocked
Islander
PostPosted: 11:03 - 31 Jul 2022    Post subject: Re: Giilera runner 50sp carb problem Reply with quote
IDOTNY wrote:
So sometimes the needle that alows more gas and air into the engine aka the throttle sometimes get stuck in the carb have sanded it down gets stuck less but i am worried it will go full throttle in the city and get stuck any suggestions thanks in advance!
You'll need to replace the needle then. Sanding it will change the profile and it's a precision component.
If the needle appears to be sticking then it'll either be the throttle cable as Nobby suggested - that's the most common cause, or the slide/piston sticking because of oxidisation or some other build-up. DON'T sand it or any other carburettor part.
The last post was made 4 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 46.83 Kb
