Intermittent sticky valve
PotatoHead202...
PostPosted: 23:27 - 04 Aug 2022    Post subject: Intermittent sticky valve Reply with quote
Newly rebuilt cbf500 cylinderhead. Valves were lapped in, new seals and shims adjusted. Bike starts very easily, revs to redline without issue, doesn't seem down on power. Brand new plugs.
However, particularly when cold I'm getting a puff through the intake on cylinder number 2. Told this suggests a sticking valve. I'll stress that it's intermittent, not consistent in time between it happening, and largely disappears when warm and higher in the revs.
Any idea why this could be happening? I'll admit the fuel was at least 3 months old. Could one valve clearance be too tight? Dirty valve stem?
Suzuki V Strom 1050XT, Honda CBF500 ABS,
stevo123
PostPosted: 21:15 - 05 Aug 2022    Post subject: Reply with quote
I would doubt a sticky valve given that a good run normally rids sticky valve of being, well, sticky!
Maybe a quick, non invasive check, moght be a compression check and go from there. Sorry I'm not much moe use to you mate.
Honda XL125-Yammy DTR125-Honda NSR125-Yammy TZR 250-Aprilia RS125-KTM RC 125-
KTM RC390-Kawasaki Ninja 636-KTM Duke 390
Nobby the Bastard
Harley Gaydar
PostPosted: 21:56 - 05 Aug 2022    Post subject: Reply with quote
In my experience sticky valves quickly turn into broken valves....
Triumph Sprint ST 1050
PotatoHead202...
PostPosted: 16:35 - 06 Aug 2022    Post subject: Reply with quote
Right so I did a comp test and both running around 185psi.
I plugged up the carb balance holes/pair take off and it ran FAR worse than with them open. Puffing MUCH more.
Unplugged the TPS and it's almost completely stopped the puffing.....
jeffyjeff
PostPosted: 00:47 - 07 Aug 2022    Post subject: Reply with quote
Is it fuel injected or carbureted? Since it has ABS (your signature line) I might assume that it is fuel injected. If not, why would it have a TPS? If it is indeed fuel injected, perhaps your issue is a fuel injector not atomizing 100%.
xX-Alex-Xx
PostPosted: 07:16 - 07 Aug 2022    Post subject: Reply with quote
Advance the timing.
edit: 2004 CBF500 for example:
https://www.motorcyclespareparts.eu/en/honda-parts/2004-cbf500-motorcycles/e-19-carburettor-assembly
Part 9.
DILLIGAF
PotatoHead202...
PostPosted: 12:56 - 07 Aug 2022    Post subject: Reply with quote
No carbed. Your guess is as good as mine lol.
I assume it's something to do with the PAIR system?
Gave it a run today. Idled fine to begin with. Mile up the road getting fuel it started again. Took the tps out and it was better but not solved.......
Doing my head in.
jeffyjeff
PostPosted: 17:24 - 07 Aug 2022    Post subject: Reply with quote
OK, so I did a quick google search:
https://forum.allaboutcircuits.com/threads/what-does-tps-on-a-carburetor-do.165842/
Apparently the TPS advances or retards ignition timing to better match spark timing to engine load. WOT = fully loaded, part throttle = part load. Maybe there is an adjustment on the TPS, or perhaps an open on the resistance slide. Maybe you can disassemble and clean it with electrical contact cleaner. At the very least, you can take it off and check it with an ohm meter across its range of motion.
PostPosted: 21:34 - 07 Aug 2022    Post subject: Reply with quote
If you're seeing puffs in the inlet, I assume you are running it without the airbox and filter. Try putting them back on. Maybe that "puff" would normally become a resonance wave?
PotatoHead202...
PostPosted: 09:24 - 08 Aug 2022    Post subject: Reply with quote
No, standard airbox and filter.
WD Forte
PostPosted: 12:59 - 08 Aug 2022    Post subject: Reply with quote
My lovely lovely scooty has a tps on the carb
It's connected to the spark unit to give it some advance
as the throttle opens in a roughly similar way that old cars had those vacuum advance devices on the distributor.
When I tested it, I didn't find the silky smooth resistance transition from closed to WOT I hoped for, but signs of a somewhat notchy track.
new ones are 2-300 quid as I recall so sod that, I'll live with it
and have plans for a diy one in store when/if it goes bad.
I reckon the puffing may be carb related, mebbe ignition but
dont like the sticky valve idea much
Poor seal on the seat causing blow by at low revs maybe,
It has just been improved hasn't it?
bikers smell of wee
PotatoHead202...
PostPosted: 14:36 - 08 Aug 2022    Post subject: Reply with quote
Gave it a good run yesterday.
Started fine without the puffing issue (albeit trouble idling until it was warm). Got down the road to the petrol station and it started it again quite badly as i pulled in slowly. Filled up with V Power and pulled the TPS out. It then was fine until I'd slow down for roundabouts/junctions etc whereupon it'd puff once or twice coming to/at idle then every 40/60 seconds or so if i sat there.
It doesn't seem to do it (not that I can hear/feel anyway) when it's above 3k ish which is where iirc the main jet takes over?
I did a compression test and both cylinders were registering just under 190psi.
It's driving me absolutely mad though!
xX-Alex-Xx
PostPosted: 23:11 - 13 Aug 2022    Post subject: Reply with quote
Have you actually tested the TPS with a multimeter? Service manual should give the expected resistance readings for fully open/closed.
DILLIGAF
PotatoHead202...
PostPosted: 11:10 - 15 Aug 2022    Post subject: Reply with quote
Finally managed to get hold of the guy who originally advised it could be a sticky valve. Took it to him and after searching for a while a can of WD40 with a nozzle extension found a slight air leak at the back of the carbs - seems to have sorted it. Originally tried updated coils which vastly improved it but not 100% so I think it was a combination of this and the air leak.....
The last post was made 3 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 80.48 Kb
