2002 Speedfight 2
andyjonc
PostPosted: 14:23 - 05 Aug 2022    Post subject: 2002 Speedfight 2 Reply with quote
The issue:
My scooter bogs out and has a horrible flat spot between slghtly open throttle and fully open.
Things I've done:
I have tried both the original (clean) air filter and an aftermarket cone filter, happens with both.
I have recently renewed the exhaust baffle (to get through MOT).
Fresh fuel and oil checked.
Question:
Does anyone have an ideas what could be causing the issue?
ThunderGuts
PostPosted: 14:45 - 05 Aug 2022    Post subject: Reply with quote
Sounds to me like a carb problem. I'd clean the carb thoroughly and try again. Do you have a fuel filter? What state is the inside of the fuel tank (assume it's steel), i.e. any rust/gunk? Has the bike been sat unused for any period of time recently?
TG.
andyjonc
PostPosted: 16:02 - 05 Aug 2022    Post subject: Reply with quote
In my hast to get the post... posted.. I forgot to add that it is a brand new carb and fuel filter.
The tank is plastic. The scooter has sat for a while, but it has fresh fuel and has been ridden a few miles now following passing the MOT.
But the almost binary power delivery is a bit of an issue, it goes, then lags, then gets power when you open the throttle. When in traffic or basically not WOT, it stutters
Easy-X
PostPosted: 17:15 - 05 Aug 2022    Post subject: Reply with quote
Brand new carb... any old carb or one specifically for this scooter, i.e. with the correct jetting?
andyjonc
PostPosted: 09:20 - 06 Aug 2022    Post subject: Reply with quote
the carb was ordered online and the speedfight 2 was listed as compatible model. I assume it has the correct jetting (I know one should never assume...)
Nobby the Bastard
Harley Gaydar
PostPosted: 10:13 - 06 Aug 2022    Post subject: Reply with quote
Why did you replace the carb in the first place? Were you the one who left it parked up or did someone else?
Triumph Sprint ST 1050
andyjonc
PostPosted: 19:05 - 07 Aug 2022    Post subject: Reply with quote
It has been a project bike of mine for some time. It has been started & runs pretty regularly but because it didn't have MOT I couldn't (legally) test ride it out on the open road.
Now it has MOT I have been on a few rides and noticed the bog. I replaced the carb with a new unit because the on the old one I noticed that the inlet pipe for the oil feed was actually broken so I was concerned that 2T oil was not going in (altho it probably was).
The last post was made 3 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.81 - MySQL Queries: 13 - Page Size: 52.93 Kb
