All indicators flashing (But they're not LEDS!)
boredatwork
PostPosted: 21:27 - 19 Jul 2022    Post subject: All indicators flashing (But they're not LEDS!) Reply with quote
tldr: if i indicate left, invariably the right one starts flashing and vice versa. they aren't LEDs, they're incandescent bulbs.
hi
gsxr 750k4 due for its MOT and of course this weekend it starts doing this. when i indicate left, after a second or two the right lights flash in sympathy - eg left on, when the left goes of the right blinks a little weaker, then when it goes back to the left. If I take a bulb out, the "wrong side" still flashes. New relay hasnt fixed it. Ive checked the loom visually nothing obvious. Sprayed and cleaned all the various terminating blocks even tho no obvious corrosion. Even happens when I've disconnected the big connector to the front and the dashboard so i dont think its the diode/single indicator bulb issue.
I'm stuck any ideas gratefully received!
DAS/Test: Passed March 08!
Bikes: CG 125 and k4 750 gsx-r
Nobby the Bastard
Harley Gaydar
PostPosted: 08:17 - 20 Jul 2022    Post subject: Reply with quote
Bad earth causing the power to find an alternate route to get to earth, via the bulb rather than the earth.
Triumph Sprint ST 1050
sickpup
Old Timer
PostPosted: 09:14 - 20 Jul 2022    Post subject: Reply with quote
The indicators will share a common earth which is corroded somewhere in the loom.
As a quick dirty fix you could add additional earths to the indicators.
boredatwork
PostPosted: 18:12 - 20 Jul 2022    Post subject: Reply with quote
thank you both (i cant multi quote) - going out after dinner to have a look at the continuity again, but i think the 'new' earth will get me thru the MOT i'll report back
thanks
boredatwork
PostPosted: 13:45 - 22 Jul 2022    Post subject: Reply with quote
so just as an update- new earths didnt work.
but i've new information - if i disconnect the live from one of the bulbs, and select the other side to flash...both sides flash.clearly something is mega shorting so pulling it all apart to look at the wiring.
sigh.
Easy-X
PostPosted: 18:10 - 22 Jul 2022    Post subject: Reply with quote
I don't think there's anything particularly clever going on with the wiring (with regards to the original design) so for both sides to flash it'd have to either be:
1) a faulty indicator switch
2) the left and right wires corroded together somewhere (Black, Light Green)
3) diode array busted in the display, but you've already tested that by disconnecting
If you disconnect the switch cluster the relay wire is light blue (if I'm reading the right diagram.) Jab a wire between light blue and light green, light blue and black to simulate the indicator switch.
For corroded together wires you'd need to break out a multimeter.
forarainydave
PostPosted: 12:38 - 15 Aug 2022    Post subject: Reply with quote
Sounds like the switch needs investigating. Just check the continuity on the opposite side from the switch (i.e. check the right side wire from the switch when you select left), there should obviously be none. I think a bit of conducting crud may have built up and is shorting, especially if it's a bit of a weaker signal on the opposite side than the one selected.
JBM
PostPosted: 14:37 - 26 Sep 2022    Post subject: Reply with quote
I’m guessing you’ve got to the bottom of the issue by now, but if not, does your bike have an alarm?
There is a gap of 2 years, 222 days between these two posts...
boredatwork
PostPosted: 17:48 - 05 May 2025    Post subject: Reply with quote
sorry it's taken two years but..
yes it did have an alarm. and - god i wish i'd seen your post at the time, yes it was a faulty alarm unit!
sickpup
Old Timer
PostPosted: 13:46 - 06 May 2025    Post subject: Reply with quote
I wish you'd said you had an alarm.
Datatool alarms used to (don't know now) come with 2 diodes to be wired inline with the indicators when this happens.
Its caused by using the same live in the alarm to fire both sides indicators when arming and disarming.
The last post was made 1 year, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 64.7 Kb
