| donvito7 |
 donvito7 L Plate Warrior
| ThunderGuts |
| Mysteriass |
 Mysteriass Nova Slayer
| Nobby the Bastard |
| Mysteriass |
| Nobby the Bastard |
 Posted: 15:40 - 15 Aug 2022 Post subject: |
| Mysteriass wrote: | Used to be a common issue on old YBR's that they'd have problems like this if parked in the sun. As it's a much copied bike then that issue could have transcribed itself into some chingchong models. |
Erm......
| Crofterspeed wrote: | Hullo!
Haven lurked for a while, I've just signed up to post about a problem I had a few months ago and this forum came up with lots of folk with the same problem and lots ideas how to fix it with little resolution.
So. The problem is with a YBR 125 (mind's an '09 for what that's worth), if it's been sitting warming in the sun it just won't start. You turn on the ignition and you don't get the usual wee noise of the pump pumping, and the bike won't start, starter coughs but the engine just won't fire. I replaced the spark plug, I fucked about with wiring, I tried this and that and everything in between. I even had to get breakdown recovered one fine sunny day.
What finally fixed it was replacing the fuel pump. Now, the next issue is a new fuel pump is ~£300 which is a fairly hefty portion of the bike's value! But you don't need the whole thing, just the pump (and possibly more likely the filter) and I got them off ebay for about £16 (far more reasonable!)
These live inside the tank so it's a bit of a job to replace. Drain tank, sides off, seat off, tank off, undo the allen bolts and you need a few wee prying tools to separate the two parts of the pump housing to put in thenew guy. But when you do,hey fuckin presto! She works! When you turn the ignition you hear the wee pixies whirring away pressurising or whatever it is they do in there and the bike will start no matter how warm the weather.
Anyway, hope this helps someone one day! |
https://www.bikechatforums.com/viewtopic.php?t=319962 ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
The last post was made 3 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
