FZS600 Fork Seal Replacement
shadywiki
PostPosted: 16:56 - 14 Aug 2022    Post subject: FZS600 Fork Seal Replacement Reply with quote
Happy Sunday all….
So today I’ve replaced the seal on one of my forks, dismantled fine and the seal went in great.
Coming to put it back together, I insert the damper rod, spring and insert the bolt in the bottom to hold the damper in place. Once that bolt is in place, I can’t extend the fork to insert the main spring, spacer and top cap.
Am I doing something wrong? The spacer protrudes about 3 or 4 inches above the top of the tube and I can’t compress the spring to just get it to catch.
Am I missing something/doing something wrong!?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:09 - 14 Aug 2022    Post subject: Reply with quote
Have you put the fork leg back into the yoke to hold it still whilst you push down on the spring and cap?
Released the preload to it's minimum?
Triumph Sprint ST 1050
shadywiki
PostPosted: 19:14 - 14 Aug 2022    Post subject: Reply with quote
I can't even get close enough to the thread with the top bolt.
So I put the damper rod in, fork fully extended and the rod doesnt go anywhere near the bolt hole at the bottom. It's only when its compressed does it go near. And when its attached via the bolt, the fork leg won't budge to extend again...
I feel as though the damper should come all the way out of the bottom of the fork leg but its too wide for the hole.
This the first time i've attempted this and i've made sure to put everything back in its correct order. So please accept my apollogies if my explanations of parts and or procedures are some what off.
I'm trying to learn to do things myself but hitting a few snags as you can tell...
Many thanks for your reply.
Chris.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:38 - 14 Aug 2022    Post subject: Reply with quote
You could try answering the questions.
shadywiki
PostPosted: 19:48 - 14 Aug 2022    Post subject: Reply with quote
Sorry, yes tried attaching to the yoke and attempting to connect the top peice. I can't get anywhere near.
This is with no loading on it whatsoever.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:20 - 14 Aug 2022    Post subject: Reply with quote
What year?
You do know you need to put a quarter of the weight of the bike, you, any passanger and potential luggage on it to compress the spring?
to v or not to v
PostPosted: 21:19 - 14 Aug 2022    Post subject: Reply with quote
this video might be helpful-
https://www.youtube.com/watch?v=EEAnPT9CYEE&t=6s
Moto Guzzi V7.
PotatoHead202...
PostPosted: 11:08 - 15 Aug 2022    Post subject: Reply with quote
You need to put a LOT of weight into doing this. I fitted K Tech springs to my VFR and had to make a homemade fork spring compressor, put my entire 17 stone weight onto it and then get my girlfriend to do up the bolts while I held it together.
If I was doing this on any sort of regular basis I'd invest in a fork spring compressor.
Suzuki V Strom 1050XT, Honda CBF500 ABS,
Robby
Dirty Old Man
PostPosted: 17:13 - 15 Aug 2022    Post subject: Reply with quote
Sounds like the damper rod is getting hung up on something in the stanchion. Take it apart and see how you put a washer in the wrong place.
The last post was made 3 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 58.37 Kb
