Dropping down in power
Irezumi
PostPosted: 16:29 - 10 Sep 2022    Post subject: Dropping down in power Reply with quote
Anyone changed bikes intentionally for a lower powered one, or even unintentionally?
I’m looking to from 110hp to about 75hp, sports to naked. Am I going to miss that much overtaking power or not really notice it fir normal riding? Is it a good or bad idea?
PostPosted: 16:31 - 10 Sep 2022    Post subject: Reply with quote
You might notice for the first couple of rides, but after a while your brain will adjust. I found that I ride like more of a nutter on my Street Triple as my GSX-S because when I get on it I feel it's lower powered so I thrash it.
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Nobby the Bastard
Harley Gaydar
PostPosted: 16:34 - 10 Sep 2022    Post subject: Reply with quote
Having dropped from 160 to 130 bhp, nope didn't notice in the slightest.
What I did notice was the fact that my elbows and shoulders work properly now because of the stress from the geometry has gone.
Triumph Sprint ST 1050
PostPosted: 16:55 - 10 Sep 2022    Post subject: Reply with quote
I drop[ped from a gen1 Busa to a STR, the old 675 version. So something like 170 to 110BHP. Of course I noticed a drop but the bikes were so fundamentally different it never felt underpowered, just different.
If I had dropped to something similar, then I'm sure it would have been more of an issue.
Triumph Trophy Launch Edition
xX-Alex-Xx
PostPosted: 18:04 - 10 Sep 2022    Post subject: Reply with quote
Current bike is a GSR750, had a 929 before that and a Gixxer thou before that. Definitely notice the power drop, but it's the torque of the thousands that I miss the most on the GSR.
DILLIGAF
chickenstrip
PostPosted: 18:15 - 10 Sep 2022    Post subject: Reply with quote
You probably will miss the overtaking power, but if the bike you switch to is good enough in other respects, it won't matter that much.
jeffyjeff
PostPosted: 00:21 - 11 Sep 2022    Post subject: Reply with quote
I did indeed downgrade from a VFR800Fi (5th gen) to a BMW R1150R. 110 hp > 85 hp. To be frank, the BMW is a bit of a pig, but it handles motorways really well and will cruise up to 100 mph easily without running out of wind. Do I miss that extra 25 hp... not really. An SV650 or an MT07 would probably be a better choice. Personally, I think I would be very happy with a lighter weight naked like the SV.
Blah blah
PostPosted: 07:12 - 11 Sep 2022    Post subject: Reply with quote
If you find the right 75hp then you won't miss the power and they will be more than enough in the real world
I have a modified 748 (853cc) and an S2r 800 Monster and they make those sort of figures
The Monster has more than enough power to get me past stuff or into triple figures and will keep up with most stuff down the back lanes - the 748 demands to be ridden everywhere much faster before it works and I'm quickly into license losing speeds. I've said it before on here that the 748 is too much for the roads (and got laughed at) but where can you actually go WOT for more than 3 gears?
P.
PostPosted: 10:11 - 11 Sep 2022    Post subject: Reply with quote
I literally just went 600 sports 100hp+ to 600 semi naked 76hp.
Yes I noticed. Instantly Laughing but the comfort and position was also miles better. I don't regret it and I'm actually looking forward to going for a ride.
PostPosted: 10:19 - 11 Sep 2022    Post subject: Reply with quote
Of course you'd notice but apart from the thrill of stupid accelleration and top speed what use is the extra. I've has all types of bike from singles to big-power turbocharged but the 95hp 100lbs/ft BMW i ride nowadays beates them all on my commute. The only way I'll stop using it is if they make it non-ULEZ compliant or someone produces a half decent electric bike, or I'm dead.
DrSnoosnoo
PostPosted: 10:49 - 12 Sep 2022    Post subject: Reply with quote
I went from 140 ish to 110 with some mad gearing that only allowed 125 mph max.
It just means you ride differently. With that gearing and power I could ride aggressively and use revs and it was a hoot to ride.
If I rode like that on the current 170 ish bhp now I'd be dead because no way could I handle that.
ThunderGuts
PostPosted: 10:55 - 12 Sep 2022    Post subject: Reply with quote
Anything over 50bhp is going to be adequate punch to do most overtakes. A naked will probably "feel" faster because you'll get the full windblast. As all the above really, yes you'll notice it, you'll soon get used to it, you *might* miss it occasionally, but motorbikes excel in corners not straights and you won't miss it when banked over.
TG.
woo
PostPosted: 23:15 - 12 Sep 2022    Post subject: Reply with quote
I went from an R1 to a Honda Grom 125cc
Still on the Grom might jump to a Honda CB300R
Elen sila lummen omentielvo!
blurredman
PostPosted: 07:47 - 13 Sep 2022    Post subject: Reply with quote
Dropped from 33 at the wheel to 20ish.
Yes I have noticed.
Mr. Green Mr. Green Mr. Green
Easy-X
PostPosted: 11:00 - 13 Sep 2022    Post subject: Reply with quote
What sort of bikes are we talking about? Going from an old litre bike to a new naked, e.g. carb'd to EFI, you might actually find the smaller bike feel quicker if it's got some nice torque-to-weight ratio.
ThunderGuts
PostPosted: 09:06 - 15 Sep 2022    Post subject: Reply with quote
Quite. The OP is saying 75bhp naked so presumably something like an SV650. But even a Street Twin, "only" 64bhp but with more torque than a lot of 100bhp+ sports bikes and very accessible low down, likely to feel quick in the real world unless bouncing off the limiter all the time..
TG.
P.
PostPosted: 11:53 - 15 Sep 2022    Post subject: Reply with quote
ThunderGuts wrote:
SV650. .... unless bouncing off the limiter all the time..
Unfortunately, the SV does that, it just gets going then brrrrrrrrrrr change gear please.
I just dipped from sporty 6 to boring 6, 100hp+ to 75hp and its fine.
I went 170hp+ to 100 and it was also fine. Going from the 170+ to 75 would have also likely been fine, its still much quicker than 4 wheels and aside from the 100mph first gear and the drop a gear and disappear of the litre sports, its much the same.
Zen Dog
PostPosted: 12:32 - 15 Sep 2022    Post subject: Reply with quote
For me, anything 75hp+ is fine. If it's on the lower end you just change gear a bit more and wring it's neck a bit more.
I tried a mate's 160hp Ducati Diavel the other day. I reckon I was at full throttle for about 0.2% of the trip. On my VFR for the same journey I reckon I'd have used full throttle for about 0.5% of it.
Current - '94 VFR750FR (Dead), '00 VFR800FI, 2011 CBF125 Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
Irezumi
PostPosted: 08:00 - 19 Sep 2022    Post subject: Reply with quote
Thanks for all the input. Found the drop in power was ok but the particular bike not quite for me.
Current bike is an SV1000s, was looking at an air cooled Ducati monster.
Jayy
Mr. Ponzi
PostPosted: 12:19 - 19 Sep 2022    Post subject: Reply with quote
Every time I get off the V4R (235bhp) to the 690 SMC-R (70bhp). There's a fair bit of difference there but both uniquely fun.
Old Git Racing
PostPosted: 19:02 - 22 Sep 2022    Post subject: Reply with quote
Jumping off the gixxer 1000 onto the street twin I certainly notice it but not in a bad way. Horses for courses. Even though the Triumph is only 64bhp its not slow and can be more enjoyable as you use more of it.
The gixxer is totally mental and uncomfortable, only take it for short blasts and probably use the street twin more but hell it makes me grin!
OGR
SpiritMr89
PostPosted: 03:23 - 24 Sep 2022    Post subject: Reply with quote
Surely it is more gearing than top end.
Right ratio's you'll still top a ton. But get there as quick. Plus have the pull to whip past.
Probably wrong here (correct me if so).
The R6 was faster than R1, because the shorter gears and weight?
It could boot round and out of corners when the R1was still slowwing down.
Reason I love V twin's. Plenty of torque to power out.
Hello
PostPosted: 07:29 - 24 Sep 2022    Post subject: Reply with quote
Just back from a tour of Northern Spain. I took my enfield bullet, not my VFR.
But it's all horses for courses, on the way down to the ferry, I think we'd all have swapped for my mates Blackbird. Once there and on the twisties, everyone wanted a go of the G310R rental bike Mrs stinkwheel had... Nobody wished they were on a 1200GS, despite almost literally every other bike we saw being one.
Bhud
PostPosted: 22:46 - 24 Sep 2022    Post subject: Reply with quote
That's pretty hardcore. Did you visit San Sebastian, Santander, Asturias, etc. all on that Enfield Bullet? What problems (if any) did you experience? Any restrictions in urban areas? I gather you rode it down to Portsmouth, right? I know they hold that bike thing annually at that hotel. Was it a planned route, or a series of escapades around the Picos with a central starting and end point?
PostPosted: 16:47 - 25 Sep 2022    Post subject: Reply with quote
I'm not ashamed to say I vanned it down to the ferry, 6 hours of motorway would have done neither me or the bike any good.
We dotted about the place having 2 nights in each stop, got down as far as Northern Portugal and also took in all the awesome passes in the Picos area. The Bullet was a great bike to do those on.
I had one issue which was a battery leadratling loose and becoming disconnected. I think it had been intermittantly connecting and disconnecting in the lead-up to that which in turn fried the reg/rec leaving me conked out at the side of the road with no electricity. One of the guys rode into then nearest town and grabbed me a spare battery. I just put it on charge overnight and ran on total loss for the rest of the trip.
The bike ran like a dream the rest of the time. I'm pleased I did a disc brake conversion in it!
Top of the San Glorio pass. 6,000 feet up.
https://lh3.googleusercontent.com/pw/AL9nZEVXUEpQFVciXd8broz4UwJQ5L7ofEEOCXLIkoJLeMpJy1RCweix3Xti1QzXze1RvGeFO6dqT4TNPuG8LfIwrWzQKaZ7jbd4QIupb8yaJ3a_ZfxDybE-b1mFP5Zh7nop2expKpEZb9Lcm2uAUKDuP4kP=w1576-h886-no
The last post was made 3 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 131.13 Kb
