Chain Tightening
MementoMori
PostPosted: 15:05 - 10 Apr 2005    Post subject: Chain Tightening Reply with quote
Is it better to increase chain tension yourself or get it done by a mechanic?
I don't have a paddock stand or much experience and really need my bike so don't want to bodge it up.
Thanks.
The tiger who came for a pint
mr.z
PostPosted: 15:15 - 10 Apr 2005    Post subject: Reply with quote
Its something you really need to be able to do yourself, its almost as bad as getting your mechanic to check your oil Razz maybe not quite, but if you plan on haveing a bike in future its worth learning to do the "little things"
A padock stand can be got for £30 easyly, adjusting the chain is not difficult once you have done it a couple of times, if in doubt get a knowlageable friend to help out, ALLWAYS have the propper tools, its worth getting them if you dont have them, much better in the long run...
PostPosted: 16:04 - 10 Apr 2005    Post subject: Reply with quote
Yes, do it yourself.
As long as the chain starts off in line then turn the adjusters the same amount on both sides (count the number of flats you turn each one) and the wheel will stay in line.
Black Knight
PostPosted: 16:17 - 10 Apr 2005    Post subject: Reply with quote
I had the same problem, tried to do it without a stand and it was very difficult.
Theres a place near rotherham selling them for £16 and they are good. I think he also sells them on ebay for this price plus postage.
Alternatvly, got any mates who could lend you one?
MementoMori
PostPosted: 16:44 - 10 Apr 2005    Post subject: Reply with quote
Just to demonstrate how little knowledge I have, I had a look at my dad's bike and found the adjusters fine but on mine? No such luck Confused
Could anyone tell me where they are if this pic helps at all...
Thanks for the info about paddock stands, I saw one for £16 but it was a New Year's deal which I thought was weird.
I'll have to ask my dad about the rotherham place. I know someone who will... probably have one.
Thanks.
Ant
PostPosted: 17:18 - 10 Apr 2005    Post subject: Reply with quote
Should be behind there.
Have you got a pic from the back??
04 ZX10R ~
MementoMori
PostPosted: 17:35 - 10 Apr 2005    Post subject: Reply with quote
Just taken a picture of what is behind the sprocket and found two allen bolts. Is this the adjuster?
If so, how would you go about adjusting the chain without knocking it out of line?
Thankyou
nick.h
PostPosted: 19:32 - 10 Apr 2005    Post subject: Reply with quote
Havent you got a manual for your bike?
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
instigator
PostPosted: 19:39 - 10 Apr 2005    Post subject: Reply with quote
On that note, what happens if your R clip went walkies?
PostPosted: 23:02 - 10 Apr 2005    Post subject: Reply with quote
Ah, RS50 (or AF1 50).
To adjust the chain find the small (~5mm) hole near the centre of the wheel. You put a bar through this into a matching hole in the bit in the swinging arm (you should be able to see if you look carfully), but it will only fit one way (ie, one rotation of the wheel).
Then slacken those 2 allen key bolts. Push the bike forward a touch and the wheel rotates the eccentric mount in the swinging arm so pulling the wheel back slightly. Check the chain tension and repeat until correct. Then tighten those 2 allen key bolts and remove the bar you used to lock the wheel to the eccentric. Then check the tension as you move the bike forward (problem of this system is that it is virtually impossible to adjust the tension at the tightest point).
MementoMori
PostPosted: 21:16 - 13 Apr 2005    Post subject: Reply with quote
Thanks Kickstart, I really appreciate it. Must give it a go this weekend.
Thanks Thumbs Up
The last post was made 21 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 69.28 Kb
