Rust
Easy-X
PostPosted: 00:42 - 25 Sep 2022    Post subject: Rust Reply with quote
So we've probably all seen some video where some old rusty shit-heap gets stripped down, sand blasted and repainted and if it's several decades old rust is unsurprising. Something less than 10 years old though...
Fair enough if the powder coating or paint layer is damaged but I was watching someone doing a Harley swing arm (yes, yes, harley shite and all that) and the paint was coming off in sheets with surface rust underneath! How do such things happen?! Is the case that the manufacturers have such thin layers of paint that it's barely any protection at all?
The swing arm on my XSR for example. It had a little bit of rust bubbling up in areas where water might collect. So what? Surely the paint layer would fuck that off. (BTW I sanded the affected areas, dabbed on some rust converter and repainted. It's been fine ever since.) Anyhoo, how did it start to rust in the first place? Thinking
doggone
PostPosted: 07:24 - 25 Sep 2022    Post subject: Reply with quote
Poor quality paint won't help there has been a lot of reformulating to be more 'eco friendly' though they ought to be getting a handle on what does and doesn't work by now.
Even the slightest damage like almost invisible stone chip allows moisture to attack the metal then progress in dampness below the paint if it isn't perfectly adhering.
trevor saxe-coburg-gotha
PostPosted: 08:42 - 25 Sep 2022    Post subject: Re: Rust Reply with quote
How often do you wash your bike, and what's your method, etc.?
As for your question more generally, I actually think it's down to poor quality materials rather than anything much that happens after a bike has been nailed together. By which I mean, I think some steel is quite low grade and has incipient pitting which in turn often means oxidation - albeit at an almost microscopic level. Over several years and depending on other factors such as detergent use, slight chips and abraded areas, the whole process of oxidation is accelerated and soon its visible to the eye. But yeah - the original metal itself. I think the cause might be there.
That said, and this is an interesting case study (of two acquaintances): Two Kawasaki bikes - ER6 and Versys 6. Both ridden all year-ish (avoiding rain where possible), but through winter. One shows various signs of rust, the other none. The rusty bike owner says they're not going to buy another Kawasaki; the other owner is really happy with their purchase.
The single biggest variable: One washed their bike a lot, using various latest greatest products (Muck Off, blah blah etc etc); the other avoided detergent at every step, and tended towards a more trad oily rag, greasing pivot points, a spray of WD or GT85 here and there, etc.
I'm not sure what the actual cause is, but I thought this was interesting cos it's not often you get the chance to compare two similar bikes of similar age and see how different approaches to ownership bring about different results. It is a small sample though!!
doggone
PostPosted: 08:46 - 25 Sep 2022    Post subject: Reply with quote
My XSR is one of the early ones (2016) and though it rarely goes out in salt I don't avoid rain. It only gets a wash before MOT day once a year then spray of ACF or similar. Not a spot of rust on it.
PostPosted: 10:22 - 25 Sep 2022    Post subject: Reply with quote
It's 90% down to application in my view. I've seen ships painted in drydock and the paint has lasted the 5 years till the next dock and in other cases it's been coming off in months. Humidity, temperature and a load of other things are critical.
You would expect all painting in a factory to be critically controlled and I expect it is but if they have issues for whatever reason i doubt if they are going to reblast and put through a load of components if they look ok.
Triumph Trophy Launch Edition
Easy-X
PostPosted: 11:47 - 25 Sep 2022    Post subject: Re: Rust Reply with quote
I'm also in the "wash infrequently, ACF50 after if I do" camp. BTW the swing arm rust spots were there when I got the bike. Things that have gone rusty in my ownership are annoying little brackets here and there, the stuff that routes pipes and cables.
I suppose it's one of those "in this day and age" things. Shouldn't we all have flying cars by now?! Nope, and we can't even manage to stop shit rusting Sad
PostPosted: 17:36 - 25 Sep 2022    Post subject: Reply with quote
I think a lot of parts have flash-rusted before they ever get painted in the first place.
Kawasaki Jimbo
PostPosted: 17:59 - 25 Sep 2022    Post subject: Reply with quote
Labour costs have pushed all but specialist steel manufacturing to the Far East, and cheap (badly made) steel corrodes from the inside. Even some Harley Davidsons are made there now.
Fat Angry Scotsman
PostPosted: 11:17 - 26 Sep 2022    Post subject: Re: Rust Reply with quote
I guess it's the ER6 that's rusty because mine is too Laughing
A100man
PostPosted: 11:44 - 26 Sep 2022    Post subject: Re: Rust Reply with quote
I'll bet that Harley swinger was powder coated. That tend to happen if the surface is damaged and water (salty water) can creep under the coating. Paint chips but the corrosion is more localised is my understanding.
Bhud
PostPosted: 02:02 - 27 Sep 2022    Post subject: Reply with quote
I've dealt with quite a few of them now, and I have a great appreciation for old Kwaks. They were painted in thick paint. Very high quality paint. I have more faith in them than in modern bikes. 40+ year old Kawasaki is usuallyt in better condition than 20-year old Kawasaki. They started using much thinner paint about 20 years ago. Thinner steel as well. However, the welds on the old bikes were sufficient but not as good. The welds were iffy to the point of having bits of wire stuck to the frames. Nevertheless, the steel was thicker, stronger, than was needed. And that's why they're still here today.
The last post was made 3 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 74.04 Kb
