Tinnitus :(
c-m
PostPosted: 14:00 - 04 Oct 2022    Post subject: Tinnitus :( Reply with quote
I always use ear plugs/protection when on the bike, but noticed that even with 36 SNR dB plugs, or custom moulded plugs, IEMs with 29 dBA isolation, or Motosafe Race plugs, after a days riding I still get a get pretty bad ringing in my ears.
Anyone else have an issue when using plugs?
PostPosted: 14:23 - 04 Oct 2022    Post subject: Reply with quote
I have tinnitus anyway, but I use Max-Lite plugs and have done for years. The Tinnitus was there beforehand, and also is sometimes worse due to blocked ears/infection/allergy. I don't recall having ever taken earplugs out and noticed worse tinnitus though, so on that basis I'd say those earplugs are either not fitted properly, or they are shite.
xX-Alex-Xx
PostPosted: 15:41 - 04 Oct 2022    Post subject: Reply with quote
I always go for this type of silicone earbuds (both for just noise blocking plugs and earbuds for music). Never have issues either after riding or concerts etc:
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fwww.advancedmp3players.co.uk%2Fimages%2Fproducts%2F15225%2F12962%2F300x300%2Fer20xs-15225.jpg&f=1&nofb=1&ipt=1bbde3700b7179fff03f2897d64fbb8f4a40d1b2363359730ad0d1850db12880&ipo=images
DILLIGAF
grr666
PostPosted: 15:52 - 04 Oct 2022    Post subject: Re: Tinnitus :( Reply with quote
I use MACKS ear ammo plugs, I usually roll and insert so far I need tweezers to retrieve them, but they certainly
seem to help. Also they're cool because they look like bullets.
https://www.uttings.co.uk/p134861-mack-s-ear-ammo-18472/
I can still hear my Sena10S for music and nav etc but do need a high volume setting.
PostPosted: 17:00 - 04 Oct 2022    Post subject: Reply with quote
I know a lot of people don't like music while they ride but I wonder if a pair of good fitting noise suppression ear buds would be better than plugs?
Of course then you have the audio awareness of what's going on to consider.
Triumph Trophy Launch Edition
trevor saxe-coburg-gotha
PostPosted: 17:23 - 04 Oct 2022    Post subject: Reply with quote
xX-Alex-Xx wrote:
This style w/ olive oil. Like having your head underwater in the bath.
But yes I get tinnitus - have done all my life. I've had some VERY noisy jobs as well.
PostPosted: 18:09 - 04 Oct 2022    Post subject: Reply with quote
Maybe go and see an audiologist?
recman
PostPosted: 19:04 - 04 Oct 2022    Post subject: Reply with quote
I've found 3M expanding plugs to be the best. Just pull them out slightly to relieve expansion pressure and get rid of that underwater effect.
These plugs work particularly well in conjunction with the Sena speakers in my lids.
PostPosted: 19:09 - 04 Oct 2022    Post subject: Re: Tinnitus :( Reply with quote
If you've tried all those plugs then all you can do is get a quieter helmet.
PostPosted: 09:09 - 05 Oct 2022    Post subject: Reply with quote
I don't think so, no. They don't isolate the right frequencies. I have a set of plugfones ear buds that are like earplugs with built in speakers, and they are OK but nowhere near as good as normal earplugs for me.
MCN
PostPosted: 23:59 - 05 Oct 2022    Post subject: Reply with quote
Speak to an audiologist.
Specsavers are who I use for custom earplugs. About £80 a pair.
But get your hearing checked out too.
GET YOUR HEARING CHECKED OUT TOO.
chickenstrip
PostPosted: 00:50 - 06 Oct 2022    Post subject: Reply with quote
What did he say? Must get that appointment at Specsavers.
PostPosted: 10:01 - 06 Oct 2022    Post subject: Reply with quote
ARE YOU DEAF? WHY WOULD I WANT MY HERRING PECKED OUT?
blamski
PostPosted: 13:16 - 06 Oct 2022    Post subject: Re: Tinnitus :( Reply with quote
it looks more like a bag of tiny (maybe life size) Donal Trump penises
inexperienced but enthusiastic middle aged CB500X owner
sickpup
Old Timer
PostPosted: 18:56 - 06 Oct 2022    Post subject: Reply with quote
I think most people don't put ear plugs in correctly. They don't insert them in the ear canal, just sort of rest them in the ear which is one half of the problem.
The other is that most peoples helmets are too big for them. A loose helmet lets in more wind noise and has more freedom to move with the wind.
MCN
PostPosted: 20:40 - 06 Oct 2022    Post subject: Reply with quote
I posted before about ear plugs.
I've been wearing earplugs for donkey's years. I work in a high noise energy industry but always used earplugs.
My hearing tests are usual better than many people in the industry I work in.
I stopped using foam about 20 years ago and have used custom fitted since.
I upgraded to attenuated acrylic about 6 years ago and now find foam pafetic if I am caught short and need to shove foam in my lug holes.
Ear canal shape and size affects the fit of ear plugs too. So some foam won't seal perfectly so their protective qualities can be compromised.
And re-using plugs is never 100% effective as we plugs don't compress as well as dry plugs so fit is not as good.
The dB rating is under prefect conditions when tested so allowance needs to be made.
If you are riding a bike regularly or your job is noisy look at custom plugs.
Much more convenient.
Weisse Schlange
PostPosted: 09:31 - 11 Oct 2022    Post subject: Reply with quote
I have really loud tinnitus after years of bikes and guns, it's fucking sould sapping, knowing you'll never hear silence again.
Get fitted earplugs made or a good, soft foam disposable and use them, every ride.
Hing Oan
sickpup
Old Timer
PostPosted: 09:11 - 12 Oct 2022    Post subject: Reply with quote
I'm amazed that so many have tinnitus, did you all wear headphones with the sound turned up high, bad fitting crash helmets or what?
PostPosted: 09:15 - 12 Oct 2022    Post subject: Reply with quote
Not me. I've had it from a very young age. It can be to do with all sorts of things not directly related to hearing - e.g. earwax.
MCN
PostPosted: 12:57 - 12 Oct 2022    Post subject: Reply with quote
It's not common sense to not blow your hearing out.
It's a long process to damage hearing with everyday noise.
But... those earphoned pricks who sit on trains, planes and automobiles (motorbikes) with their shite tunes banging so loud that you can hear every clap of the high hat deserve the punishment.
Its such a pity that genetics takes too long to evolve things.
xX-Alex-Xx
PostPosted: 13:35 - 12 Oct 2022    Post subject: Reply with quote
I seriously don't get people who refuse to look after their hearing.. I don't think people realise the damage is cumulative and won't ever fix itself... My wife is constantly complaining about tinnitus, and yet when we go to concerts I get weird looks when I put in music/concert ear plugs... Practically impossible to speak with her afterwards for a day too cos she can't hear sh!t. Rolling Eyes I'm best part of a decade older than her and I can hear small or high pitched noises easily she has no idea are there.
DILLIGAF
Freddyfruitba...
PostPosted: 14:41 - 12 Oct 2022    Post subject: Reply with quote
I have a vivid memory of seeing Thin Lizzy at Sheffield City Hall, circa 1982. Believe me, they were LOUD. Despite being at the very back of the hall, my ears were absolutely burning. I ended up literally chewing up my ticket into papier mache and stuffing the bits in my ears so I could enjoy the gig (something I've never done before or since!). But - that's not the 'vivid memory'. At either side of the stage there was a stack of massive speakers about the size of a bus, and down in the mosh pit there was, unsurprisingly, a clear area of floor about 15 feet radius in front of each speaker where even the most hardened Lizzy fan couldn't venture. Well, all except one. This absolute tool, obviously off his head, was standing right in front of one speaker, with his head actually inside the cone. The mind boggles (and I'm sure his did).
recman
PostPosted: 21:24 - 13 Oct 2022    Post subject: Reply with quote
For the past few years I've been in an area of my work with less background noise so I don't use earplugs.
However, there is the odd occasion where I use an air chisel for a repair. Its obscenely loud, particularly when used on a vehicle so on go the big ear defenders.
I couldn't possibly stand the noise without the protection so you can imagine my amazement on one occasion when I'd just finished using the air chisel for a couple of minutes straight only to discover some idiot had wandered over to where I was to see what was going on.
I asked him how he could stand the noise.
You can guess his answer. Rolling Eyes
Kawasaki Jimbo
PostPosted: 22:17 - 13 Oct 2022    Post subject: Reply with quote
I’ve just bought my second box of ear plugs in nearly 25 years of riding. 200-pairs of Howard Leight Laser Lites. These will see me out. Without them my ears ring after an hour’s fast riding, and my Dad had factory-induced deafness so I was always aware of the hazard.
Originally I bought a selection pack of different types. Some were too big, too hard, too scratchy, but for me the Laser Lites were perfect. You do need to compress them by rolling between (clean) thumb and forefinger, and I then twist them down into the ear canal before they expand. Ah, but you know this.
I keep them in my jacket pocket and reuse each pair many times before I lose/drop/dirty one and have to break out a new pair. The manufacturer’s would have you believe they’re much shorter lived but I’ve never had a problem.
Oddly the ear plugs emphasise the bike’s bass notes, or maybe they just filter out the higher notes like chain rattles (and the breeze) so bassiness/rortiness is what’s left. Sounds mega. Recently I wondered if the ZX6R’s Remus exhaust needed repacking but the neighbours say my bike is quieter than the other two bikes in the street. I think half of what I’m hearing on board is lovely induction noise.
Also, Arai helmet, sportsbike fairings and screen. The R1 has a very subtle double-bubble MRA screen which was noticeably less noisy/turbulent than the original. The ‘99 ZX6R simply has a slightly larger fairing and screen which is very effective.
xX-Alex-Xx
PostPosted: 22:18 - 13 Oct 2022    Post subject: Reply with quote
https://entertainment.time.com/wp-content/uploads/sites/3/2013/06/hot-shots-1991-01-g.jpg?w=600
DILLIGAF
The last post was made 3 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 136.55 Kb
