| ThunderGuts |
| Freddyfruitba... |
| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 15:24 - 31 Oct 2022 Post subject: |
I'm going for a reynolds o-ring chain next time on my VFR. I put one on the bullet this summer after the side plates on the swift x-ring it had fitted started splitting through the pin holes. They are seriously chunky, no fucking about chains and relatively inexpensive to-boot (like under £50).
Only available in "imperial" sizes. but 5/8" x 3/8 " = 530. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| ThunderGuts |
| Ste |
 Ste Not Work Safe
| redeem ouzzer |
| Polarbear |
 Polarbear Super Spammer
| ThunderGuts |
| Grubscrew |
 Grubscrew Scooby Slapper
| davebike |
 davebike World Chat Champion
 Posted: 09:20 - 01 Nov 2022 Post subject: |
I suspect the paraffin is rotting the x rings WD40 dose even if the makers say it should not
Me, I a scottoiler fan and use silkolean chain cleaner spray never had a problem but seen several on customers' bikes ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| DJP |
 DJP Crazy Courier
 Posted: 10:06 - 01 Nov 2022 Post subject: |
As above: Paraffin rots some seal materials.
I once used paraffin to clean some engine o-rings. The next day they'd turned into a sticky mess.
Do not put paraffin on chains. ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
| sickpup |
 sickpup Old Timer
| A100man |
 A100man World Chat Champion
 Posted: 15:19 - 01 Nov 2022 Post subject: |
| DJP wrote: | As above: Paraffin rots some seal materials.
Do not put paraffin on chains. |
I wonder what they were made of.. afaik Nitrile and Viton are both fine with paraffin. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| MCN |
 MCN Super Spammer
| DJP |
 DJP Crazy Courier
| Nobby the Bastard |
| Fizzer Thou |
 Posted: 14:33 - 05 Nov 2022 Post subject: |
I have seen the same situation on the newish DID X ring chain on my Exup-R.I do not use a brush to clean it,or parafin.It has only occurred on one link,which was not the soft link.The back wheel is in alignment and the sprockets are both Renthal.
https://i.postimg.cc/FKXwvnHt/20150730-190118.jpg
https://i.postimg.cc/Vk20knxP/20150730-164026.jpg
I have the same specification chain on my 5JJ-R1 and my 3XW-FJ,which are both doing okay.
I would have to look up in my records as to how many miles the Exup-R and 5JJ-R1 have done since fitting the new chains and sprockets,but I do know that the 3XW-FJ chain,again with Renthal front sprocket but a steel rear,has only done around 3,000 miles since fitting back in 2019,just before Mrs.Fizzer and I rode down to Italy,in all weathers. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| ThatDippyTwat |
| Fat Angry Scotsman |
 Fat Angry Scotsman World Chat Champion
 Posted: 16:04 - 07 Nov 2022 Post subject: Re: DID X-ring failure (again!) |
| ThunderGuts wrote: | When I was cleaning the chain on Saturday, usual routine (spray a bit of paraffin, then use a Muc-Off chain brush which is nice and soft, followed by a microfibre towel to clean it down afterwards, then lubed). Noticed on two links (not adjacent) a bit of rubber X-ring was poking out of the link, indicating they've torn/failed. This is the second time this has happened with the Crossrunner, but I figured the previous chain was neglected by the previous owner. This chain has been on for about 2.5 years and has only covered about 7k miles, most of which are fair weather.
Am I doing something wrong, or is this a fact of life? I know I can just keep lubing it and it should be fine, but it's still a bit irritating when I hear stories of people having chains last for 20k miles or more. |
A bit unrelated but I've noticed something weird about my DID X-Ring chains. The first one I got was put on the little 125cc and it looks pretty fucking pristine. The second one I got on my 650cc and it needs cleaned way more often, literally every week otherwise it gets fucking crusty. I don't do anything different in terms of cleaning or lubricating them but the one on the 650 needs way more attention. I put about the same amount of miles on both bikes and put them both under rain covers so I don't know why there's such a big difference between them (especially as the one on the 125cc is almost a year older). ____________________ PRESENT: 2018 BMW S1000XR SE Sport.
PAST: 2009 Kawasaki ER-6F. 2021 Zontes ZT-125U. |
| ThunderGuts |
| ThatDippyTwat |
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 23:17 - 09 Nov 2022 Post subject: Re: DID X-ring failure (again!) |
| Fat Angry Scotsman wrote: | A bit unrelated but I've noticed something weird about my DID X-Ring chains. The first one I got was put on the little 125cc and it looks pretty fucking pristine. The second one I got on my 650cc and it needs cleaned way more often, literally every week otherwise it gets fucking crusty. |
I'd say this is more likely to be that your 650 is, for whatever reason, spraying more water and road crap onto the chain, than a difference in the chain itself. Also, if your chain is instantly manky again after you've cleaned it, it could be worth checking your front sprocket cover isn't full of road dirt and old chain lube. Mine definitely is.
| ThatDippyTwat wrote: | I had an obvious fake, but bought from a reputable retailer. |
I got sold fake EBC Clutch plates a couple of months ago on ebay. My own fault really, the seller didn't post a pic of the actual item, and when they arrived there was no packaging, and the plates themselves were crude, of varying colour and non-EBC lettering. It wasn't a hard spot. Despite the seller claiming they were "totally legit" he processed my return, and I bought genuine ones from someone who posted a pic of the actual item.  ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
The last post was made 3 years, 329 days ago. Instead of replying here, would creating a new thread be more useful? |
