Advice on a pathetic main dealer service
Bunzena
PostPosted: 18:08 - 05 Nov 2022    Post subject: Advice on a pathetic main dealer service Reply with quote
Hi. Need some advice on problems with a recent main dealer service. [Honda].
It's a relatively new bike - so to keep the warranty going - just had the first, full-year service done by my local dealer - last Tuesday.
Where I bought the bike in the first place.
I then rode the bike home [around 12 miles] and it's sat in the garage since then.
Just gone out to discover a large pool of oil under the bike.
Crawling underneath - I discovered the sump plug hadn't been tightened. So loose I could rotate it with my fingers.
I'll be going back to the dealer on Monday to rant about this.
But my question relates this the next issue.
I spy the oil filter - which has been changed.
There are copious amounts of red grease around the seal - enough to be spilling over on to the crankcase/oil pan. It's like it's been applied with a butter knife.
It's ugly and filthy. I have a slight suspicion that there's a little oil leak there too.
My question is this.
Whenever I've replaced an oil filter, I NEVER use grease. Just a little rub of engine oil on to the o-ring and then tighten it up - gently.
I understood that using grease is completely the wrong thing to do - and can even damage the o-ring.
Maybe they had to use grease because they over-tightened the oil filter when fitting it in the first place? Like plumbers putty. The filter certainly feels tighter than 'hand tight'.
It feels as if the whole service has been done by the trainee - no care or attention paid.
Before I go back to the dealer on Monday and let rip - any thoughts on this?
Thank you.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:16 - 05 Nov 2022    Post subject: Reply with quote
First off, red grease won't damage seals. It's meant for brake seals and fluid so won't affect the engine shit.
Secondly, Immediately call dealer and reject it for not being fit for purpose.
Do not touch it. You want them to collect and return your money.
Edit:realised the 12 miles is not the total miles done.
Speak to the dealer and explain about the pool of oil and demand it's fixed and the mess cleaned up.
Triumph Sprint ST 1050
Bhud
PostPosted: 18:26 - 05 Nov 2022    Post subject: Reply with quote
I've never seen any manual, whether manufacturer's own, or Haynes, that advises to put grease on the oil filter seal. The O-ring seal is designed to hold oil and seal up any leaks.
On the type of oil filter which is fully enclosed, I can't think of any purpose for slathering grease on an oil filter seal.
If the technician routinely does this with fully enclosed oil filters, then I believe that in the past he's had problems caused by O-rings that didn't seal, either because they have come loose while tightening the oil filter and got twisted up, or because there was dirt in between the seal and the filter, or the seal and the engine. The proper way to avoid leaks is to clean up all mating surfaces, then fit the filter. Some people put fresh oil on the O-ring, because they believe the O-ring will swell and make a better seal like that. However, I've never heard of anyone using grease. Grease is not designed to form a hermetic seal anyway.
On some bikes (which use non-enclosed oil filters), the oil filter rests on a disc with a holed bolt to flow oil in the centre, which also holds a little spring that pushes up the oil filter. I don't know if don't have one of those, but in that case the disc has its own O-ring seal - different from the one on the oil filter. This must be replaced whenever the oil filter is replaced - you shouldn't just order an oil filter alone for those bikes, but one of those additional O-ring seals as well. I don't know if the technician had one to hand. If he didn't (just speculating here) maybe it didn't seal properly when he fitted the new filter, and it started leaking, so he had to dump the oil again and refit it, and tried to solve the issue with grease. If he did have one, then there's a bit of a knack to getting the new O-ring seal into the recess on the disc. Not rocket science, but everything has to be clean and dry, then you coax it in with your fingers. It pops out here and there. If you aren't patient then you may be tempted to use grease as a sort of glue to stick the O-ring in place and stop it sticking out. That may or may not work, but it isn't necessary.
Bunzena
PostPosted: 18:54 - 05 Nov 2022    Post subject: Reply with quote
Thanks Bhud, thanks Nobby. Good thoughts and advice.
It's a cartridge type filter - so I think there are two O-rings.
A small one on the feed and a larger one on the perimeter.
Also aware that a cartridge filter shouldn't be over-tightened - or else it will leak.
My suspicion is [like yours Bhud] - that the numpty who did the service has had problems with leaks after fitting the filter before - so now uses grease like plumber's putty to stop that happening.
To be honest - this is not the first problem I've had with this dealer.
PostPosted: 19:50 - 05 Nov 2022    Post subject: Reply with quote
Grease is "engineers glue", commonly used to hold things like an o-ring in place while they are put where they are supposed to be. The o-rings on oil filters are designed to cope with hot engine oil, grease is pretty much just thick oil so a smear of grease on the o-ring on a filter will not do it any harm.
In my experience, if a filter o-ring on a modern japanese bike is going to leak, it will do it almost immediately and in large quantity.
A loose (or worse, stripped!) sump plug is super dangerous though, first it dumps oil under your rear tyre, then -if you manage to stay on- it seizes your engine.
Robby
Dirty Old Man
PostPosted: 14:02 - 06 Nov 2022    Post subject: Reply with quote
My thinking is that if they failed to tighten up the sump plug, what else could they have fucked up.
Luckily, being a first service, probably not very much. I assume the whole service is basically an oil change and a check over.
Either way, call the dealer. I would expect them to be quite apologetic and want to get it back in for a proper check over by a different mechanic.
Bunzena
PostPosted: 14:36 - 06 Nov 2022    Post subject: Reply with quote
Robby - these are my thoughts too. As you say - apart from a long list of things that they supposedly checked - just an oil and filter change.
However, this is not the first time I've had problems.
Bike originally supplied [new] with a scratched screen. They did replace but forgot to re-fit a number of the nylon spacers. [Only discovered when I fitted a larger screen replacement].
Bike also supplied with the drive chain over-tight. [Less than 15mm of movement - measured correctly]. I simply adjusted it myself.
Bike supplied with scratched section on handlebars - with scrapes and paint missing. Only discovered this later as it was on the bottom surface. Fixed this myself.
Had some extras fitted after a month or so [weren't available at the time I collected the bike from new]. Discovered that some of the bodywork pop-studs were missing. Fixed that myself.
A week or two later I discovered a blanking plug that was removed to fit a USB charger jammed between the crankcases and injector unit. Presumably where it had simply been dropped during fitting.
Of course I should have complained about each of the above - but I didn't. Lack of time, distance to the dealership, etc. So maybe part of all this is my own fault.
At this stage, I don't want them near the bike again. So rather than getting them to fix it - I want my money back for the service and then I will correct the problems.
However, I will vent my 'disappointment' with them face to face.
PostPosted: 14:41 - 06 Nov 2022    Post subject: Reply with quote
They could also have over-tightened it and stripped the threads?
Bunzena
PostPosted: 15:01 - 06 Nov 2022    Post subject: Reply with quote
I have been able to torque the plug down correctly - so threads look okay. They also re-fitted the sump plug washer - so at least that's something.
I am slightly concerned about the oil filter and all that red grease 'gloop' around the seal. Perhaps that's been overtightened and the threads are stripped?
We'll see.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:20 - 06 Nov 2022    Post subject: Reply with quote
The grease won't hold on a filter if the threads are stripped, it's there purely to help the seal to slige nicely so it can be tightened correctly and get a good seal.
Kentol750
PostPosted: 15:59 - 06 Nov 2022    Post subject: Reply with quote
Did they re-use the old washer or fit a new one? It's normally standard procedure to fit a new one.
Some bikes.
Bunzena
PostPosted: 16:03 - 06 Nov 2022    Post subject: Reply with quote
On the sump plug? Can't tell yet - but good point.
MCN
PostPosted: 16:13 - 06 Nov 2022    Post subject: Reply with quote
Jesus.... these folk are trying to run a business, to provide them and any of their investors with profits.
Don't be so bloody harsh on them you heartless sod.
They won't be paying their mechanics a fair day's pay so they will be struggling to hire competence.
I haven't been near a dealer for Service in over ten years.
There was no point in me helping to keep their workshop lights on all thpse years, as when I had significant issues with new-ish bikes they stopped being courteous and turned into devious kunts and bastirts.
Bunzena
PostPosted: 17:10 - 06 Nov 2022    Post subject: Reply with quote
A point nicely made. Sad though isn't it?
There's a sickness here that people/businesses want our money - but don't want to do even a half decent job.
Not everyone - but enough to get my goat.
Robby
Dirty Old Man
PostPosted: 14:40 - 07 Nov 2022    Post subject: Reply with quote
I would not be concerned about the red grease. It sounds like the sort of thing done by an experienced mechanic to make sure the O-ring stays in place. Just in this case, an experienced mechanic who was rushing and made silly/sloppy mistakes.
Getting a refund is going to be like pulling teeth. I would aim for getting it done right without making any threats - let them think they're trying to retain a customer. Then go somewhere else for future servicing.
Easy-X
PostPosted: 18:40 - 07 Nov 2022    Post subject: Reply with quote
Short sighted greed. I got fucked over by a local spanner shop and subsequently they're missed out on years and years of MoT and service work for 2 cars and the bike plus I tell everyone I know how shit they are at every opportunity. Capitalism in action Smile
Bunzena
PostPosted: 21:19 - 07 Nov 2022    Post subject: Reply with quote
Thanks to all the advice given. Very helpful.
Went back to the dealer today and saw the owner - armed with pictures, a video of the not-even-finger-tight-sump-plug and a letter detailing the issues from this service and six or seven others from previous ham-fisted work done. Checked over by a solicitor.
He tried to say they could do nothing until "properly investigated".
I stood my ground and got all my money back there and then. To be honest - he knew the game was up.
The owner claimed that this was a complete one-off. If you Google their reviews - this is clearly not the case.
He had a go at me for not mentioning ALL of the previous problems and - instead - fixing some myself.
I explained I had a life to lead and a job to hold down rather than be their Quality Control department. And that Quality Control was something that should happen before crap work is handed back to the customer - and then become their responsibility.
My next nearest main dealer is more than twice as far away - but I won't be going back to this one.
The plan always was to service and fix the bike myself when out of warranty.
gbrand42
PostPosted: 21:59 - 07 Nov 2022    Post subject: Reply with quote
Seems to be a lot of this I am hearing about lately. A bit off-topic (car related) but my Mrs has just had a main dealer service on her 3 cylinder car and I looked at the invoice and saw they charged her for 4 spark plugs at £18 a throw plus VAT. IF they do that every time a 3 cylinder car comes in for work thats a lot of £20's. Of course they claimed an honest mistake and refunded straight away, but how many slip through the net I wonder.
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
PostPosted: 23:12 - 07 Nov 2022    Post subject: Reply with quote
Well done for standing your ground.
As above there's nothing to worry about a bit of grease although not all red grease is rubber/seal grease there's a wide variety of greases. The main thing is that they are all (if automotive) compatible with your filter's nitrile o-ring. Personally I use a smear of oil and I think most do the same.
A100man
PostPosted: 23:57 - 07 Nov 2022    Post subject: Reply with quote
Hmm so I see that..
Kent Motorcyccles
Maidstone Honda
and 21st Moto
all have 4.6 * google review.. coiuld be out of teh frying pan...
..didn't I read once that as long as you use genuine parts an independent can service without affecting warranty
MCN
PostPosted: 04:07 - 08 Nov 2022    Post subject: Reply with quote
A100man wrote:
Hmm so I see that..
Kent Motorcyccles
Maidstone Honda
and 21st Moto
I smell a rat with that argument (Although this case was tried in the EU courts and that was what the courts said.)
It's the dealer who submits a warranty claim to the OEM.
If you piss off the dealer by not giving them service work they may not be encouraged to 'assist' in claims.
But since BMW dealers don't reward repeat business and leave customers to fite BMW that service yersel deal may be another thing one would have to build a case for in court.
Dealers and OEMs are a shower of wee kunts when they feel they have wiggle room.
xX-Alex-Xx
PostPosted: 09:08 - 08 Nov 2022    Post subject: Reply with quote
A lot of the time warranty work is only paid at a small fraction of what they could charge a customer, so dealers typically hate doing it unless it's for a regular customer who usually drops wads in their store.
DILLIGAF
Bunzena
PostPosted: 18:16 - 08 Nov 2022    Post subject: Reply with quote
A100man wrote:
Hmm so I see that..
Kent Motorcyccles
Maidstone Honda
and 21st Moto
Fair point. I think there's a measure of luck with all these things. I've had great service from companies that - subsequently - I've seen with lots of bad reviews.
It's about expectations.
I'll take a grubby bike after a service, perhaps with a drive chain that hasn't been tightened - and probably not complain.
I wonder how many customers - in the real world - complain about the little things? The hassle, the time it takes?
But when crap stuff happens on more than one occasion and then they leave the sump plug loose - and the potential dangers that creates - enough is enough. Dealing with some of the loony car drivers round here is dangerous enough without the service department trying to kill me.
Looking at reviews for one of those dealers, seems to suggest that there is a track record for what I would call critical mistakes. It's not a huge number - but it's there.
In my 'discussions' yesterday with the owner, at no time did I sense he felt there was a bigger issue.
But - as many of you have said here - do the dealerships and manufacturers really care?
I spent an hour or so yesterday trying to find the name of anyone senior at Honda UK with 'Customer Service' in their title.
Still looking.
fw750x
PostPosted: 19:12 - 08 Nov 2022    Post subject: Reply with quote
I would NOT Waste any time Contacting ANYONE at Honda UK . In the Early 90,s I bought a BRAND NEW Honda Transalp from an Approved Honda Dealer In Belfast , With around 200 Miles on the Clock ( there was 16 Miles ) On the Clock when i bought it , The Chain Snapped when i was Slowing Down in a 30 Zone for a Traffic light. This was after about 6 weeks of Ringing and Calling into the Stealers to get my Service Book as they could not find it and would get me one. I asked for a New Chain and was told the Drive Chain is Not covered under warranty and they would not even meet me half way with the Cost of a New Chain. I went to another Shop and bought a Chain there , I went home and fitted the Chain and was wiring in a Ciggie Lighter Socket to power my Air Compressor and when i took off the Side Panel there was the Service Book. I took it out and Opened it to fill it in and It was Already Filled in Someone else Had Bought it some months earlier and Suprise Suprise His bike was Red and White and my Bike was the Blue and white Model . I was Fuming and Rang the Guy and he told me the Bike broke down when he was going home hence the 16 Miles already on the Clock and Rejected the Bike and Got his Money Back. I contaced HONDA UK about the Chain Breaking and Being Sold a Second Hand Rejected Bike , I had to send the Chain at my expence to Honda UK so that they could decide what caused the Chain to Snap , They wrote back and said something got into the run of the Chain and broke it So it was not covered by the warranty . The Fact that a Honda Approved Dealer was Selling Second Hand Bikes as Brand New Bikes was Nothing to do with them and to take it up with the Stealer ( The Body work was Swapped ) off another bike . I vowed then i would Never buy another Honda Product either New or Second hand , So Honda UK have missed out on 3 Brand New Bike Sales and Servicing THERE Loss not mine . It will be a Complete waste of your time contacting them as they dont want to know . Cheers Francis
Nobby the Bastard
Harley Gaydar
PostPosted: 19:35 - 08 Nov 2022    Post subject: Reply with quote
fw750x wrote:
THERE
THEIR.
The last post was made 3 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 136.85 Kb
