Portable battery packs
PotatoHead202...
PostPosted: 01:45 - 09 Nov 2022    Post subject: Portable battery packs Reply with quote
I've got heated gerbing gloves (12v) and want to be able to wear them on my old (6v) bike. Any recommendations on portable battery packs/power bank? Don't want to pay gerbing prices and not have any USB charging ability for the phone etc
Could i even just use a normal 12v bike battery in a pannier?
This will be for the Dragon Rally so needs to last more than an hour or two....
Suzuki V Strom 1050XT, Honda CBF500 ABS,
MCN
PostPosted: 02:57 - 09 Nov 2022    Post subject: Reply with quote
Anker seem to work well.
I use one to charge my phone.
The bigger the capacity the longer the recharge.
https://www.anker.com/collections/power-banks
Don't ask me how to get 12v from the 5v output.
Unless they make a 12v unit.
The companies that market heated clothing sell power packs.
This will not be an inexpensive venture either way.
A100man
PostPosted: 10:17 - 09 Nov 2022    Post subject: Re: Portable battery packs Reply with quote
Yes, why not.
They quote 2.5 - 8 hrs on their weedy 2.6AH 'Xtreme' battery so anything you have lying about will likely better that - best not run it completely flat if you choose lead acid though - it might not recover.
PostPosted: 16:36 - 09 Nov 2022    Post subject: Reply with quote
A lot of internet "makers" are using the Lidl "Parkside" battery packs designed for cordless tools as power packs. They usually 3d print up a simple connector for them.
There's an example of a very simple one here (he's doing a 20v pack, but you get the idea, they do 12V ones too): https://youtu.be/0oBbF3bcDck
Another option would be to convert your bike to 12v? Most of them it's as simple as fitting a 12v reg/rec and changing out the bulbs, horn and possibly condenser. Power demand is the same and the wiring is fine because you are halving the current.
As a veteran of over 20 Dragon rallies, I strongly advise bar muffs. Even if it's just 2 big milk bottles with the back cut out and cable-tied on there. Also thick PVC waterproofs, not gore-tex.
Easy-X
PostPosted: 18:26 - 09 Nov 2022    Post subject: Reply with quote
There's the Li-Ion jump start packs, 12V + 5V USB baked into most of them.
The last post was made 3 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 44.89 Kb
