Honda Shadow C2 - Fork seals leaking
Richde
PostPosted: 07:45 - 10 Nov 2022    Post subject: Honda Shadow C2 - Fork seals leaking Reply with quote
Hello,
I need any info on what may cause front fork seals on my 2009 Honda Shadow C2 to leak. They have been replaced 3 times and our mechanic is stumped. He says the forks look fine and is about to put a forth set of seals in. I was hoping someone in this forum may be able to shed some light on the issue.
Thanks
this adult cams hub is like a 24/7 strip club in your pocket, except the girls actually fuck themselves on live sex cams. click any room, see shaved cunts, big clits, oil shows, you name it. free chat is wild-models flash ass for tips, then pull you into private xxx chats for face-down-ass-up pounding close-ups. webcam models here hustle hard, they want that cum as bad as you do
https://maturecams.cc - https://pregnantcams.net - https://bbwlivecam.net - https://liveteensex.org
if you're into real orgasms, hit up these sex cams where amateur girlfriends and top pornstars both stream live sex. watch em edge for hours or cum in 2 mins if you tip the magic number. categories are nuts-pregnant, feet, anal gape-so whatever kink you're chasin, webcam models got it. no paywall teasin, just raw adult cams action and filthy xxx chats that leave ya drained
davebike
PostPosted: 08:33 - 10 Nov 2022    Post subject: Reply with quote
If the bike does little they will fail often as the seals stick and tear after standing
If used Replace the bushes in the forks
If it still fails the tubes are worn whatever they look like! new tubes new bushes again and new seals!
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 09:01 - 10 Nov 2022    Post subject: Reply with quote
Inspect the fork legs for pitting, if they are pitted, they can damage the new seals.
As above, worn bushings can cause seals to fail quickly.
So if it was me, I'd replace the seals and the bushings.
I have also had limited success with aftermarket seals and bushings. I reckon about 1 in 3 aftermarket seals I have fitted fails quite quickly. Aftermarket bushings can also be a very poor fit and require filing/fettling to set the correct end-gap. As such, I would recommend using genuine honda parts, which usually aren't as expensive as you'd imagine.
Bhud
PostPosted: 14:51 - 10 Nov 2022    Post subject: Reply with quote
I'd suspect the bushings. I would always replace bushings with fork seals, because I've had the same problem before. It's a hassle taking them all apart again.
Also, as mentioned above, aftermarket ones are a waste. Fork seals from Honda are what you want. Those cheap aftermarket ones on Ebay seem very hard compared with genuine parts. I don't like the fact your mechanic was stumped. Surely he must have had some ideas? If not, then how do you even know he knows how to fit them correctly.
PostPosted: 14:59 - 10 Nov 2022    Post subject: Reply with quote
Also, if this is the third set of seals, the bushings have now been in and out three times so if they weren't knackered before, they probably are now.
Kawasaki Jimbo
PostPosted: 20:45 - 11 Nov 2022    Post subject: Reply with quote
My local mechanic said he’d had success with K-Tech seals where other brands had failed, and he reckoned they were “extra tight.” I’d already had my stanchions rechromed due to pitting. Apparently it’s not unusual that they develop a slight curve which won’t help, but which the rechromers can address too. The bike still wrecked a few sets of OE and Pyramid Parts in quick time, some fitted by me, some by the mechanic. Finally he reckoned the new chrome was a fraction too thick at the bottom bushing and had them machined. I think that’s what fixed the problem but I thought the comment about K-Tech was interesting.* If the forks pitted again I think I’d just go for replacements from Wemoto.
* Edit: oh wait, according to K-Tech’s website,
K-Tech front fork oil seals are manufactured by NOK and are a direct replacement for the original equipment parts. NOK are chosen as original equipment by all Japanese suspension manufacturers for their quality and durability.
The last post was made 3 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 50.16 Kb
