| F0ulOli |
 F0ulOli Derestricted Danger
| stinkwheel |
 Posted: 00:54 - 15 Nov 2022 Post subject: |
Getting the spring rate and preload right is probably the most important thing. You can have the best damping setup in the world and it will still ride like a bagowank if the springs are wrong.
I don't think Dukes are regarded as having crappy suspension to begin with.
If we were talking something with shit-tier damper rod forks and preload only shock, then upgrading is definitely worthwhile.
What you're more asking is is upgrading mid-tier suspension to top-shelf stuff worth it? Probably not in a lot of cases. There comes a point where you're paying more for less weight and more adjustability. Rule of diminishing returns applies. Is it worth replacing a steel bolt with a titanium one?
At 18st, a re-spring will work wonders. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 MarJay But it's British!
| Ayrton |
 Ayrton World Chat Champion
 Posted: 10:57 - 15 Nov 2022 Post subject: |
I'd have a go at setting the suspension up yourself, it's not hard to do. Just involves sitting on the bike while someone measures the how much it moves to get your "sag" and then adjust the shock until it's where it needs to be. But like everyone else has said you may find you cant get the figures you need even on max preload so you'd have to get new springs.
Dave Moss has some really good videos on suspension
https://www.youtube.com/watch?v=_RuqhQf4xk4 |
| A100man |
 A100man World Chat Champion
 Posted: 11:06 - 15 Nov 2022 Post subject: Re: The reality of top quality suspension? |
| F0ulOli wrote: |
And before anyone asks, I like my pies and am the wrong side of 18st in my leathers. |
..what happens when you carry a pillion? ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion |
| Feasty |
 Feasty World Chat Champion
 Posted: 11:13 - 15 Nov 2022 Post subject: |
Firstly, I'm certainly no expert - but I'm also the high side of 18st by a few. The only time I actually noticed any difference in suspension settings was when I had a BMW F650 and the rear wheel was bumping up against the underneath of the seat, the shock just needed adjusting to the opposite end!
For every other bike I've ever had, I just adjust the shock to be as solid as it can be. I've never noticed when I've made smaller adjustments, I can still ride quick over bumps, round roundabouts etc whilst sticking to the road. I very much doubt I'd notice any real difference by spending a few hundred getting the setup to match me better.
I've always thought spending money/time on this kind of setup is more for professionals or track racers - but I'm happy to be convinced otherwise  ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
| stinkwheel |
 Posted: 11:54 - 15 Nov 2022 Post subject: |
AT 18st, adjusting preload alone isn't going to cut it.
I'm not far off 18st. I fitted the correct rate linear springs to my VFR and there was night and day of difference. Same when I fitted a wilbers shock with a spring rated to my weight.
Spring rate, THEN sag, then damping.
There are various online spring rate calculators or get a shop who know what they're doing to work it out for you.
Racking the preload up on an undersprung bike is just going to reduce the amount of travel available before bottoming, it'll be shite.
@Feasty. You are missing a trick. You don't have to spend a fortune getting someone to work it out for you, there are plenty of online spring calculators and the springs themselves aren't THAT expensive. If you go from riding around with the preload maxed-out to fitting the right spring will feel like you're on a magic carpet ride.
Caveat that I'd be terrified changing a shock spring unless I had a proper compressor tool, and even then I'd be a tad concerned about the whole affair. Fork springs are easy though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 12:23 - 15 Nov 2022 Post subject: |
| Feasty wrote: | Firstly, I'm certainly no expert...
I've always thought spending money/time on this kind of setup is more for professionals or track racers - but I'm happy to be convinced otherwise  |
Me neither, but upgrading the suspension on my Fazer 1000 was a revelation, although the upgrades I've done would be too extreme for many.
The standard rear shock on these bikes is shot after about 15k miles, if not before - well known among Fazer circles. So that got swapped out for a known better alternative. 2nd hand refurbished, inexpensive option. Night and day difference, allowed me to push the bike much harder.
But the real revelation came when I swapped out the standard front forks for those from an R1 which had K-Tech internals. This absolutely transformed the bike to the point where I thought it actually made it a much safer ride, and can now push very hard without worrying unduly about the road surface.
I'll leave it at that, because it isn't likely (nor necessary) for the OP to go that far, my point being that good suspension can make the world of difference even for an average rider like myself. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| sickpup |
 sickpup Old Timer
| Zen Dog |
 Zen Dog World Chat Champion
 Posted: 18:18 - 15 Nov 2022 Post subject: |
Short version is, your current suspension properly set up for you, is likely to be better than more expensive suspension on default settings. ____________________ Current - '94 VFR750FR (Dead), '00 VFR800FI, '11 600 Hornet - Previous - '11 CBF125, '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win
My bike trip around S.E. Asia 2010/2011 |
| F0ulOli |
| F0ulOli |
| Pete. |
 Pete. Super Spammer
| MCN |
 MCN Super Spammer
| stinkwheel |
| grr666 |
 grr666 Super Spammer
 Posted: 12:39 - 16 Nov 2022 Post subject: |
Last bike (Mk 1 MT09) had very basic suspension, it was ridiculous over 80mph on anything but the smoothest of roads.
A trip to JHS Racing for a setup made it feel a lot less fatal although James did also also suggest I ran at a different
tyre pressure settings to the manufacturers recommended pressures as well, since there was so little adjustment on the
suspension. The bike felt a lot better after this relatively minor fettle by someone who knows what they are doing. I
most certainly do not.
The new bike (Mark 2 MT10) has clearly better suspension components front and rear, and is fully adjustable. I wouldn't
know where to start in terms of adjusting it, on stock settings it feels loads better than my last bike did already but
I'm certain that it can be tailored to suit me even better so I'll be off to JHS again in due course, its only about 5 miles
from my house. I think a setup for around the 40-50 quid mark is worth a whirl first before you start buying new
components or changing your bike. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ste wrote: Avatars are fine, it's signatures that need turning off.  |
| PotatoHead202... |
 PotatoHead202... Scooby Slapper
| stinkwheel |
| MCN |
 MCN Super Spammer
| bacon |
 bacon World Chat Champion
 Posted: 00:05 - 17 Nov 2022 Post subject: |
On my previous bike, a 2016 MT09, I upgraded the front and rear end at fairly considerable expense. I did the fitting myself so only paid for parts (and a few tools).
Note that I am 75kg in gear with a backpack, barely.
I found the stock shock a bit springy, under damped and over sprung. In contrast I found the front forks soft enough, but when braking they would dive deep. Then they would unload when you pull away, almost like having a pogo stick at both ends.
I upgraded to K tech kit:
IDS20 fork internals and stock springs, given my weight, with some proper damping the springs should be fine.
Razor R rear shock, appeared to be on a standard fitment spring (whatever that was at the time, I don't recall the rating of the spring).
Well I found the whole setup a bit marmite, the fork internals were clearly designed for a track bike, which is a shame given the MT09 is very much a road bike by design. I found the shim stack was far too stiff, if you hit a big bump, it near clattered you off over the bars, it was awful quite frankly. So I reduced the oil level to increase the air gap, hoping it would help, but it didn't. FYI, I used 15.9cst oil in both fork legs, so it was very much on the light/middle end of the scale when it came to viscosity.
The rear shock spring was slightly too stiff to be honest, damping however and ride quality was superb. I just wish JHS had specced a slightly softer spring, I feel like I was given the copy paste solution.
In the end I sold off the fancy K tech parts, went back to stock.
If I ever go for fancy suspension components again, it will be from Maxton. I hear great stories about how they listen to your requirements and setup the parts accordingly with bespoke shim stacks, spring rates and damping settings, rather than the off the shelt approach of Ktech. |
| grr666 |
 Posted: 01:15 - 17 Nov 2022 Post subject: |
| MCN |
 MCN Super Spammer
| bacon |
 Posted: 09:21 - 17 Nov 2022 Post subject: |
Haha. I agree.
Mt10 suspension sounds like they've got everyone covered.
The high and low speed adjustment is significant, what I referred to above, when hitting big bumps and the forks effectively locking up, as they couldn't shift enough oil is effectively what your high speed compression adjuster can handle.
On less highly specced suspension components, my understanding is that they normally handle big bumps through the shim stack, they basically work like over pressure valves, that can let oil flow through when the normal valves can't handle the rate of flow after you hit something bigger than normal. Pot hole for example.
Low speed is your standard compression adjuster. |
The last post was made 3 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
